06-21-2011, 06:03 PM | #1 |
Quarry Creeper Join Date: Sep 2006 Location: Orange, CA
| AX30794 WB8 Driveshaft Set The WB8 Wild Boar Driveshafts are the factory units used on the Wraith™ are THE perfect upgrade for all SCX10/AX10's. We named this driveline system after your driving style – WILD BOAR. Yes, we watch YouTube and see your super thrash 'n' bash style SCX10 & AX10 abuse! We've watched you drop kick your clutch, throwing caution to the wind and your rig into the gnar-gnar where only the wild boar can go without an ounce of fear! We love that you trust the Axial brand, but there is neither gold, glory nor any photographer hundreds of miles into the forest. We want to give you that extra security to be able to drive home and tell us about it. The Axial R&D team took all of this into account when working on a new driveline system solution that would not only be great for the Wraith™, with the next level of driving style we are sure your vehicle is to see, but deliver a factory system that is an easy-to-install mechanical upgrade for all SCX10/AX10's to make sure you come back home from the epic journey. The WB8 Wild Boar Driveshaft Set is THE ONE simple system that will universally work across the whole Axial family of rigs. Yes, we said "simple system", as in – Super Easy Assembly! No more pry bar pliers! No more snapping Y-Yokes! The WB8 Wild Boar Driveshaft Set is a much simpler solution to assemble, tear-down and inspect. Other features include: - Constant Velocity Joint Design [CVJ] - Full Metal-To-Metal Construction for the CVJ-Housing - Friction Free Movement / Smooth Articulation - Metal Ring Protection & Capture for the CVJ-Pin - Easy Assembly & Maintenance - Three tube lengths for various applications [Wraith™ / AX10 / SCX10 Dingo™ & Trail Honcho™] OPTIONAL: We recommend using [AX30435] along with [AX30408] to utilize the cross pin design for secure pin attachment. The Axial R&D team worked on a solution that would not only be great for the Wraith™ but would also make a great upgrade for all SCX10/AX10's. Visit the link below for more information http://www.axialracing.com/ftp/ax307...shaft_set.html Part Info AX30794 WB8 Driveshaft Set (2pcs) AX30166 Pin 1.5x11mm (6pcs) AX30408 Input Shaft 5x29mm (2pcs) AX30435 Steel Outdrive Shaft Set (2pcs) AX30463 WB8 Universal Joint Rebuild Kit (2pcs) AX30784 WB8 Driveshaft Coupler Set AX30786 WB8 Driveshaft Retainer Ring (Aluminum) (2pcs) AX80084 WB8 Driveshaft AXA0175 Screw Shaft M3x2.5x11mm (10pcs) |
06-21-2011, 09:44 PM | #2 |
Quarry Creeper Join Date: Sep 2009 Location: redding ca
| saweettttt!!!!!!! good job axial with everything new about this crawler and its parts design
06-22-2011, 05:16 PM | #3 |
Quarry Creeper Join Date: Nov 2005 Location: Italy
What about compatibility with the steel R&P? AX10 ones haven't hole for crosspin. Will the next batches have holes too? May we secure those new driveshafts with the "old" single grub screw on "D" shaped shafts, or is there any no-no? |
06-22-2011, 06:04 PM | #4 |
| Yes, these are designed to work with the non-cross drilled style similar to the old driveshafts. This set includes 4 cross pin set screws as well as 8 total M3 set screws. We included the M3 setscrews so you can use 2 per yoke to hold them to the stock output shafts on the current SCX and AX10 line of products.
06-23-2011, 01:03 PM | #5 |
Any possibility of the upgraded R&P's to start having the crosspin hole? It's just a better design.
06-28-2011, 03:07 PM | #6 |
06-28-2011, 03:21 PM | #7 |
I wanna be Dave Join Date: Feb 2011 Location: Atlanta, GA
Very nice! Will be one of my first upgrades when I get my Wraith.
06-28-2011, 03:46 PM | #8 |
