06-29-2011, 08:48 AM | #1 |
Pebble Pounder Join Date: Nov 2010 Location: Alabaster
| Gearing
Okay so after a long long trail ride my stock 20t just smoked and gave out. I got home to see what was the problem with it but still worked so im guessing it just got hot. i put it in there with a either 14 or 15 cant remember but still running hot. i was wanting to go to Holmes BR-XL and then i don't know which motor inrunner or outrunner what is the difference. My second choice is the velineon system running it on training mode but what gearing should i go with. My last question is what would be the best system out of all of them that has okay speed but good crawling aspect.
06-29-2011, 11:22 AM | #2 |
Take a look at the Wraith beginners guide it touches on all of this. I will say that I am not that happy with the VXL system. The no drag brake makes it pretty useless. If you want any crawlability you need to go with a sensored inrunner motor and I would stay below 3000kv. Gearing won't be too big of a deal once you put a new motor in. The stock will be fine but you could always go back to the 87/14 we ran in the SCX10 trucks which will work great. |
06-29-2011, 01:43 PM | #3 | |
By under 3000kv you mean like 2700 and so forth. Since you have had it longer than pretty much anybody what would you suggest the holmes hobbies puller or what. Im wanting something that is gonna stay very cool and still have decent speed but all the torque you will ever need | |
06-29-2011, 02:27 PM | #4 | |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
My plan is to get a 17-20 turn handwound from Mr. Holmes. After using 4 different motors in the Wraith now I think that will be the best choice. | |
06-29-2011, 02:38 PM | #5 | |
06-29-2011, 03:43 PM | #6 | |
I am going to the 5 pole 13 turn which is close to a 27 turn 3 pole motor. Speed should be good with stock gearing but crawling should be much better. | |
06-29-2011, 04:06 PM | #7 | |
I never really said anything about crawling, I just said more torque. The Wraith to me is a rock racer, its not the best at crawling or going fast, but it does both really well. I have comp rigs, class 2, class 3, short course, rally. I don't need another one of those the Wraith is a rock racer to me. So for my intended purposes the 20 turn 3 pole will be fine. Hell I made the stock motor, then the HPI 15 turn last over 30 miles of driving. If your not crawling comp lines, stalling out the motor or over volting, there is no reason a 20T will not last a long time. | |
06-29-2011, 04:06 PM | #8 |
Pebble Pounder Join Date: Jan 2008 Location: el paso
How would a novak 35t rockstar work with the stock axial esc has anyone tried that.
06-29-2011, 04:09 PM | #9 |
06-29-2011, 04:18 PM | #10 |
the novak rockstars are hand wound also if I am not mistaken correct??
06-29-2011, 04:34 PM | #11 | |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
I will be dropping the pinion size 1 or 2 teeth to see if I can drop the temp a bit. | |
06-29-2011, 04:43 PM | #12 |
Rock Stacker Join Date: Mar 2011 Location: Mpls
It was my understanding that the rockstar is not handwound, just priced like one....
