06-12-2016, 04:39 AM | #1 |
Rock Stacker Join Date: May 2016 Location: Australia
| Spawn Rock Racer Kit - Build Completed
Hi, New to crawling and looked at the amazing builds from the members of this forum to inspire my newb build. Love this truck. Good dynamics and very capable form the factory, however in my view a little low on quality if you want to run brushless. My objectives were simple coming from a HPI Savage... Strength, power, speed in that order without spending too much. Anyhow I consider this stage one. Would appreciate any tips you want to share with an apprentice crawler Last edited by Mendoza; 06-14-2016 at 04:39 PM. |
06-12-2016, 04:58 AM | #2 |
| Re: Spawn Rock Racer Kit - Build Completed
Had a blast building the kit. But little dissapointed in how much cash you have to spend to get it up to this standard... Which after 5 hours of running has been awesome - bashable, reliable, no breakages and heaps of fun The Savage is built much better but is one dimensional vehicle compared to the Spawn. Phase 1 parts list 11.1v 3S venom 35C, 5000mah Tekin Roc412 3100 Orion Pro r10 ESC Vanquish links top/bottom/steering Spektrum 6280 servo (364oz @ 6v) waterproof Axial HD 36/14 overdrive ring/pinion diff gears MIP drive shafts Spektrum SRS4200 waterproof receiver Vanquish rear lockouts RR transmission gears Traxxas 4mm drive shaft pins Traxxas body mount mod |
06-12-2016, 05:11 AM | #3 |
Phase 2 parts list (arrived yet to be installed) Axial lighting system (cheaper 6 light system $24) Vanquish chubs / knuckles Vanquish servo mount Vanquish shock/axle mounts Beef tubes Proline slash rear shocks all round (soft/soft progressive springs - 25wt oil) ...really, nicely made shocks and the dual rate is cool I've spent $1150 total including the kit and everything on the two lists. And I am wrapped in the Wraith. I've geared this thing to have a good top speed for bashing and low enough to be capable for crawling. This motor and ESC are super smooth low down - basically crawling a little faster than a lug at a time. Very pleased with it. The phase 3 is going to be a Holmes Hobbies, 540puller Pro 3500. Mainly to see how much better it is than the Tekin and to do some video comparisons. Parts |
06-12-2016, 05:49 AM | #4 |
| Re: Spawn Rock Racer Kit - Build Completed |
06-12-2016, 06:30 AM | #5 |
Newbie Join Date: Dec 2015 Location: Pine knot
Awesome built!! Do yourself a big favor and ditch those proline foams for crawler innovation foams. Keep the pics coming, I can't wait to see your comparision of tekin 412 and hh puller 3500kv comparision. |
06-12-2016, 08:59 AM | #6 |
Thanks mate |
06-12-2016, 12:35 PM | #7 |
Pebble Pounder Join Date: Jun 2015 Location: Netherlands
That looks great |
06-12-2016, 04:49 PM | #8 |
Quarry Creeper Join Date: Dec 2015 Location: United States
If the inserts are memory foams and since you're mounting the tires on wide Pro-Line beadlocks anyway, use the stock foams a little to see how you like them. The memory foams in the Super Swampers I have do good job of supporting the tire while allowing it to conform to obstacles. The memory foams that came with the BF Goodrich KR2's were a little too big and a little too firm so I opted for the Pro-Line #6172-00 two stage foams for them. If they're just standard open cell foams then you'll probably want something else. |
06-12-2016, 07:48 PM | #9 |
Thanks Yonzarig! And very much appreciate your advice Soldat Vaillant... I actually bought the super swampers before even trying the Maxxis Trepadors which have turned out to be really good IMO. I wasn't aware PL make 2-stage foams... Do you think medium for rear and soft fronts? I was thinking running the same all round?? Basically because I am heading toward a 50/50 weight distribution for the truck.
06-12-2016, 10:04 PM | #10 |
Pro-Line only has one 2-stage crawler insert and it may not be big enough for the XL Super Swamper. Description says they fit 5.2" - 5.5" diameter tires and the XL is 5.8". I've been fine with the same inserts front and rear, but others prefer the stiffer foam in the rear tires. I just haven't tried mismatching front and rear foams so I can't say if you would benefit from the mismatch or not.
06-13-2016, 03:29 AM | #11 |
Finally received my programmer box for the ESC - looking forward to fine tuning Hope to get some spare time to fit the PL shocks, Vanquish chubs/knuckles,lights and beeftubes this weekend. Thanks for your advice and comments Last edited by Mendoza; 06-14-2016 at 04:25 PM. |
06-14-2016, 04:36 PM | #12 |
Couple of short running videos. Sorry I don't know how to embed them yet and I had to hack them down to 45 seconds in order to upload... These are my first running test videos on about 50% battery which I will update with some proper crawling video soon. Video 1 - Slow http://vid1072.photobucket.com/album...psbyn7wqks.mp4 Video 2 - Faster (half - 3/4 throttle) - few small jumps http://vid1072.photobucket.com/album...psf3rnwufm.mp4 |
06-14-2016, 05:03 PM | #13 |
Last point of weakness in the truck are the plastic locker housings... Any of you crawlmasters put the Vanquish floating locker into the AR60 plastic axle housings? Is it a straight fit, are there an alternative metal option-do you guys think this is a must for a wraith? Main reason is to achieve max strength possible, without all metal axle housings. Once this upgrade is done.. I think I'll be close to BP HD trans gears HD ring/pinion Beeftubes Lockers Yeti 60T metal spur Gmade 13T pinion Any advice fellers? |
06-14-2016, 07:40 PM | #14 |
Quarry Creeper Join Date: Jun 2015 Location: Athol, Massachusetts
| Re: Spawn Rock Racer Kit - Build Completed *SALE EXTENDED* BMRC Axial Solid Axle Spools The vanquish 2 piece locker is good but you have to run there front axles to use the set screws in the front. The back axle was fine but the small axle in the front didn't reach all the way in. I put the blue monkey locker in the front and life is good. |
06-14-2016, 07:57 PM | #15 |
You're running brushless so I'd say yes, HD lockers and ring and pinion is a must. Plenty of great choices for lockers available. I've personally tried Locked Up RC FI spools, Grip Fab spools, VP old and new version, and Blue Monkey 300m spools. These are all great spools from great companies and yes, they are all a direct fit. I'd also suggest sticking with Robinson Racing for pinions. Also, you might consider running HD underdrive, 43/13, ring and pinion in the axles to reduce torque twist and go with a Robinson Racing 56t Slash slipper with one of SuperShafty's beefy top shafts. I run that slipper and top shaft in all 7 of my trucks and have never had a single problem. The slipper spur is easily tuneable and does exactly what it is supposed to do, save the driveline without having a "cheap plastic weak point" waiting to fail on you at the worst time. I don't like having to change batteries in the middle of a run let alone tear the entire truck apart to replace a crappy spur with another crappy spur. JMHO
06-15-2016, 02:17 AM | #16 |
Thanks a bunch for taking the time guys. I should have been clearer... That list above is already bought and would be my set up once I have installed everything. The only decision I have outstanding is the locker. And I'll now be checking out the options you guys have made. Screamer, I couldn't agree more - I want to avoid failures where possible and your honest opinion is highly valued - I only wish I had asked earlier...thank you.
06-19-2016, 06:39 PM | #17 | |
| Re: Spawn Rock Racer Kit - Build Completed Quote:
06-29-2016, 01:37 AM | #18 |
I ordered some double deuce mediums all round, before seeing your post! I have some work to do - like installing the upgrades I talked about earlier ... problem is I'm having way too much fun learning to crawl, and to take it off the road for wrench work for any period of time ... And with the upgrades I already did, i am finding it hard to break anything even with my amateur rock driving skills. You'll notice I'm a bit aggressive on the acceleration when something gets in the way - hope you guys can forgive an ex MT basher - old habits die hard Short video update from the nature reserve at the back of my place... https://www.dropbox.com/s/ay4g7t8f9e...%20PM.mov?dl=0 I'll post picks of the completed truck soon and get a cameraman to follow me on the trail. Need my waterproofing done as well, so I can do a river crossing in the next video. Last edited by Mendoza; 06-29-2016 at 01:50 AM. |
10-02-2018, 04:58 AM | #19 |
Been a while but after moving house, having a second child and getting my 5 yr old son a yeti jr ... I’ve finally thrown on those parts I bought 2 years ago. Vanquish chubs, knuckles and diff covers - love the black on black look! Proline wheels and XL tires Proline shocks Simple light kit Couple of mods done including the fast back using the spawn kit alloy links and in process of moving battery up front and cleaning up the rest of the rig. Also cut up a HPI Savage Chevy C10 longbed body which I’m painting and will put on “honcho” style. I’ll post up the pics once it’s done. Last edited by Mendoza; 10-06-2018 at 07:43 AM. Reason: Auto correct |
10-06-2018, 06:40 AM | #20 |
The proline Chev C10 body cut and fit. I bought for my Savage years ago but never used it - was hoping to fit it somehow...not too bad? The 72 model is one of the best looking pick-up trucks ever built IMO. And I wanted to minimise cutting to maintain its great shape. I’ve kept the rear tray and will experiment to see if I can fit it, but I think it will look better as a truggy. Now to mask and paint. Probably going to have to use wider yeti hubs to clear the guards with the XL swampers I’m running. Or I may pick up a set of Pitbull growlers or Ottsix Voodoos which are shorter and more narrow. Last edited by Mendoza; 10-09-2019 at 05:02 AM. |
Spawn Rock Racer Kit - Build Completed - Similar Threads | ||||
Wraith Spawn Kit Build Up | tc1 | Axial Wraith | 34 | 01-20-2018 01:47 AM |
Wraith Spawn Kit Build Front Diff Clicks when stopping hard | 4x4Jay | 2.2 Scale Rigs | 7 | 05-17-2016 11:10 PM |
RichMTB01's Wraith Spawn KIT Build | RichMTB01 | Axial Wraith | 0 | 05-13-2015 08:35 AM |
[Video] Joe's SCX10 Kit Build Completed | joerc2013 | Axial SCX-10 | 8 | 03-04-2015 10:42 AM |
rock racer kit | vito | Newbie General | 4 | 12-29-2011 03:20 AM |
