07-28-2011, 12:58 PM | #1 |
Pebble Pounder Join Date: Aug 2009 Location: emporium
| Moving battery tray to front
I have seen a few on here that have had the battery tray relocated to the front. I was wondering if this is worth doing and also did you use the stock battery tray? Thanks
07-28-2011, 03:40 PM | #2 |
Newbie Join Date: Jul 2011 Location: Louisiana
i just got my wraith yesterday and i already moved the battery tray to the front. I will be using mine for crawling so i wanted the battery weight up front. i used the stock tray with little modification to it.
07-28-2011, 03:57 PM | #3 |
Newbie Join Date: Jul 2011 Location: south/north louisiana
07-28-2011, 04:21 PM | #4 |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
07-28-2011, 05:00 PM | #5 |
RCC Addict Join Date: May 2010 Location: The heart of the south
I moved my batteries to the front but I run with 2 X 2S or a single 3S and they fit perfect in the space the stock sped control was. I moved to an HH ESC and 35T motor and put them in the battery box in the rear and made a fuel cell/deck cover to hide them. |
07-28-2011, 06:22 PM | #6 |
here are the pics, had to trim the interior some to fit the battery tray. relocated esc and ran all wires underneath. |
07-29-2011, 01:26 PM | #8 | |
07-30-2011, 05:27 PM | #9 |
Pebble Pounder Join Date: Jun 2011 Location: Central California, Pismo Beach/San Luis Obispo
I was going to do this but the nut that holds in my esc is stripped. Any idea how i can get that out?
07-30-2011, 07:56 PM | #10 |
Mine was stripped also I ended up taking the whole truck apart and using a dremel with a cut off wheel to cut a grove for a screw driver. Hope this helps. Has anyone else had a problem with stripping the hexes, I am using a good send of wrenches to. |
07-30-2011, 11:39 PM | #11 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
Ive had mine for 3 weeks or so and never put the battery in the rear battery tray. My comp scx10 batterys are 1300 m amps. I started with the passenger footwell on the transmission side. Then i modded the front underhood between the shock towers. Ive got to pull the hood off to switch the battery. And it only has a run time of only 10 minutes. Ive got a Max Amps 6500 m amp lipo on order (due in next week)? Where do i put it? The wraith is so well balanced i dont want to chance that?
