07-29-2011, 08:40 PM | #1 |
Pebble Pounder Join Date: Jun 2011 Location: Sonoma, Ca
| BRETT's wraith
Brett's Wraith for anybody who wonders how i can afford this as 15 year old, i have been working and upgrading this rig since the day i got it. Also i have a weekend job and go crazy with chores. so here is what I got: VP C-hubs (2) VP Knuckles (2) VP ackerman Ti tie rod (2) VP Ti drag link (2) VP upper and lower links VP diff covers (2) Freq-e skins props to Harley G-made Piggy-back xd 103mm (2) PL TSL Super swampers 2.2 (2) Mayhem Eng. re-machined 2.2 Monsters 4pl with 4WS Tekin 3300kv pro 4* VP axle(2) VP truss VP CMS VP Panhard VP transfer case RRP 56t spur RRP idle and bottom gears Axial HD dif gears stock gearing (2) MMP MIPs Axial UNIs (2) BWD motor plate SS Top shaft CC BEC pro robitronics Hitec servo horns (2) traxxas spring slash 4x4 clutch rebuild kit Team fast eddy bearing kit RCScrewz for Wraith GH front shock mounts GH bearing hoder CFM panels CFM inners and boat sides CFM custom rear brace with top and lower tray HR unibody locker (2) Future parts: hitec 7980 hitec 7950 4340 steel outputs VP VVDs (when unis break aka need an excuse) Last edited by sullivanscx10; 08-02-2012 at 08:59 PM. |
07-29-2011, 09:07 PM | #2 |
Newbie Join Date: Jul 2011 Location: south/north louisiana
Love the 4ws!! What all is needed to set that up? And can it be done with the stock radio?
07-29-2011, 09:14 PM | #3 |
U need atleast a 3channel remote an extra servo knuckles chums all the hardware from the front end (check in instruction manual) a servo plate and front dogbone and bearings and im probably missing something
07-29-2011, 10:11 PM | #4 |
Rock Stacker Join Date: Mar 2008 Location: honolulu
Where did you get your links from?
07-29-2011, 10:29 PM | #5 |
| http://i1120.photobucket.com/albums/...96C96-orig.jpg http://i1120.photobucket.com/albums/...C3438-orig.jpg http://i1120.photobucket.com/albums/...63B77-orig.jpg http://i1120.photobucket.com/albums/...t/720DA396.jpg http://i1120.photobucket.com/albums/...82D63-orig.jpg http://i1120.photobucket.com/albums/...B1AA0-orig.jpg http://i1120.photobucket.com/albums/...DEC82-orig.jpg http://i1120.photobucket.com/albums/...E4D2C-orig.jpg http://i1120.photobucket.com/albums/...FEBF7-orig.jpg Last edited by sullivanscx10; 07-29-2011 at 10:37 PM. |
07-29-2011, 10:38 PM | #6 |
| http://www.vanquishproducts.com/wraith.html they're great nice support from thomas and good shipping |
07-29-2011, 10:43 PM | #7 |
get the full size link codes to post the pics directly in the thread. and I hope you mean 13t crawlmaster not tourqemaster!
07-29-2011, 10:55 PM | #8 |
Pebble Pounder Join Date: May 2011 Location: Santa Cruz, Ca.
Is it going to be a crawler or a basher? Just curious...
07-30-2011, 12:28 AM | #9 |
07-30-2011, 03:04 PM | #10 |
07-30-2011, 05:26 PM | #11 | |
| Quote: | |
07-31-2011, 02:06 AM | #12 |
04-21-2012, 12:59 AM | #13 |
| Re: BRETT's wraith
Alright after saving and spending a tun of money on my other RC's im getting back into the Wraith. A lot has changed and my wraith wont be done for a while but itll be worth the wait, so far i have got: VP C-hubs (2) VP Knuckles (2) VP ackerman Ti tie rod (2) VP Ti drag link (2) VP upper and lower links VP diff covers (2) Freq-e skins props to Harley G-made Piggy-back xd 103mm (2) PL TSL Super swampers 2.2 (2) Mayhem Eng. re-machined 2.2 Monsters 4pl with 4WS Tekin 3300kv pro 4* VP axle(2) VP truss VP CMS VP Panhard VP transfer case RRP 56t spur RRP idle and bottom gears Axial HD dif gears stock gearing (2) MMP MIPs Axial UNIs (2) BWD motor plate SS Top shaft CC BEC pro robitronics Hitec servo horns (2) traxxas spring slash 4x4 clutch rebuild kit Team fast eddy bearing kit RCScrewz for Wraith GH front shock mounts GH bearing hoder CFM panels CFM inners and boat sides CFM custom rear brace with top and lower tray HR unibody locker (2) Future parts: hitec 7980 hitec 7950 4340 steel outputs VP VVDs (when unis break aka need an excuse) Last edited by sullivanscx10; 08-02-2012 at 08:54 PM. |
04-21-2012, 01:09 AM | #14 |
| Re: BRETT's wraith |
06-16-2012, 04:51 AM | #15 |
so i finally have my axles bullet proofed got almost everything vp can offer, other parts are integy alloy lower chock mounts axial UNI's a HD bevel and pinion diffs hot racing locker and waiting on wheels and tires. My wraith still has a lot to go next is the transmission and then the pro 4 mmp 7980 7950 YouTube - Wraith 4WS Update Just got the MMP and alook at the wraith, using drift wheels for EX, waiting on my Mayhem Eng 2.2s Got a few goodies in the mail today New g-made Piggyback xd 103mm (2) Wraith MIPs robitronics Hitec servo horns VP star lube wheel weights and Mayhem Eng Monster 2.2s they were totally worth the weight! Last edited by THX_138; 05-22-2013 at 12:33 AM. |
07-04-2012, 08:32 PM | #16 |
| Re: BRETT's wraith
So i finally put some money (about $300) into my transmission. All i need to finish are 4340 steel outputs, and and a small plastic piece for the topshaft. Parts in the trans: RR bottom gear RR idle gear RR 56t spur/slipper traxxas spring slash 4x4 clutch rebuild kit Team fast eddy bearing kit FOFF BWD motor mount VP AX-10 Transfer case |
07-05-2012, 01:34 AM | #17 |
Pebble Pounder Join Date: May 2012 Location: Eastern Sierras
| Re: BRETT's wraith
your not messing around! Nice rig
07-05-2012, 03:32 AM | #18 |
07-11-2012, 11:59 PM | #19 |
07-12-2012, 02:48 AM | #20 |
