Thread: Rear axle short shaft issue?
Old 10-05-2011, 02:17 PM   #41
Scale Detail Engineering
Originally Posted by LumTheMad View Post
I am having the issue with all stock parts.
well that stinks.
johnnyh66 is offline   Reply With Quote
Old 10-05-2011, 03:40 PM   #42
Just saw this thread today, I have the same problem and actually wound up stripping the hole on my axle trying to screw together. Ordered a new axle yesterday, guess I will try the dremel technique.
Adamsdad is offline   Reply With Quote
Old 10-05-2011, 05:16 PM   #43
Could this problem be why the stock motor runs so HOT?
Wavekatcher is offline   Reply With Quote
Old 10-06-2011, 10:33 PM   #44
Looks like we lost a few post in the rcc crash.
Originally Posted by Bullitrockcrawl View Post
What puzzle me, is that all 3 were built with the ring gear on the wrong side compare to the manual.
Does everything fit if you run the motor/ring gear on the wrong side?
Can someone post a pic of the dremeled out locker?
What bit did you use?
Old 10-06-2011, 10:58 PM   #45
Im going to take a look at mine a little closer here in the next couple of days and figure out where I need to machine. From the sounds of it, they are saying the problem is where the flat flange on the inside end of the axle shaft acts as a stop against the locker. If I understand correctly, that "stop" is about a 1/16th off location.. So, machining or dremeling deeper into the locker will allow the shaft "stop" to sit further into the locker, thus allowing the lockout to sit flush against the housing..along with everything running smoothly, free of any binding.
Im going to have to look into it.
Die-Laughing is offline   Reply With Quote
Old 10-06-2011, 11:04 PM   #46
sounds spot on.
if you get it, gtg at your shop this Sunday!
Old 10-07-2011, 01:29 AM   #47
322
I ran into this on my kit build tonight too
322 is offline   Reply With Quote
Old 10-07-2011, 02:23 AM   #48
Try to Bend it
Highlucks's Avatar
While I know this should not be happening and it is not right. But couldn't you just rotate the lock out by a couple of splines and drill new holes for the screws in the axle casing as a short term fix. It wont be pretty but it should work.
Axial have not come this far by short changing their customers. I have every confidence they will make this right. Thank you axial for you awesome products and the great innovations you have provided to our chosen addiction.
Highlucks is offline   Reply With Quote
Old 10-07-2011, 05:52 AM   #49
I also ran into this with my kit last night. It doesn't like much at all, I'm thinking I'll just slightly drill the ring gear hole deeper to accept the axle flange. Hopefully that will do the trick.....
Ernie W is offline   Reply With Quote
Old 10-07-2011, 05:54 AM   #50
Just grind the flange on the shaft for the inside bearing or diff case and the shaft will go in farther and everything will be fine.
I have run my Wraith like that for long time now and everything is fine for the rear, I just keep blowing front shaft.
Bullit
Bullitrockcrawl is offline   Reply With Quote
Old 10-07-2011, 07:08 AM   #51
Looks like alot of us are having the same issue....
I started my build last night as well, when I got to the rear axle I ened up removing the shaft stop... I just used a dremel and took about 2min.... quick and easy fix...
Build thread to come....
Losi6821 is offline   Reply With Quote
Old 10-07-2011, 12:48 PM   #52
I saw these pics in the kit build blog on Axial's site. you can see the amount of space where the lockout had to move. Mine has about the same space after the mod I did.
And one this pic, if you can photoshop the two shafts and put them together, the flange is machined closer to the end on the short one vs. the long one.
So what's my point? Nothing really, just wanted to spread the word so people won't be baffled when they build their kits with that terrible bind.
redbones is offline   Reply With Quote
Old 10-07-2011, 01:20 PM   #53
Every one having this issue it's important to let axial know... they will come out with a fix no doubt... they have a great rep. I"ll just wait till they come out with the fix... I'm in no hurry I'll just build my BJ this weekend instead of my scaler.
The issue with taking the stop off is the axle can now "float" into the diff and it now uses the hex out side to hold it from going to far in. Hex rub a while on the lock out and eventually the plastic will wear away. You're better off doing what Highlucks said and rotate the lockout a few splines and re drilling it if you need to get it going now!
PipeDreams is offline   Reply With Quote
Old 10-07-2011, 10:04 PM   #54
Why isn't Axial posting in this thread to acknowledge?
1.55Yota is offline   Reply With Quote
Old 10-08-2011, 09:29 PM   #55
x2
Axial, when can we get replacements?
Old 10-08-2011, 10:52 PM   #56
Someone should just make some beefy ones that are the right length hint...hint....poke....poke
highlandcrawler is offline   Reply With Quote
Old 10-09-2011, 06:51 AM   #57
They know about the issue because I have emailed them... if you have the issue you're best off to email them so they can add you to the list of people they need to send parts too.
Old 10-09-2011, 07:51 AM   #58
Hell's Gnome
I'm not sure it's a parts issue. I'm wondering if it is a directions issue. Now that it is together the short side of the FRONT axle is a totaly sloppy fit and the long side has no play. This leads me to think if the center carriers were taken out and installed reverse of the directions, the problem may be solved. Don't care enough to try it though.
In my opinion this is the worst build I have ever done. Maybe I should have gone RTR on this one. Not happy with it.
LumTheMad is offline   Reply With Quote
Old 10-09-2011, 12:41 PM   #59
The carrier is designed to work with the gear on either side! It's not an instruction issue. It is clearly a parts issue. The problem had been found and the solution is a new short axle. We are waiting on axial to make and send out new ones
Old 10-09-2011, 12:46 PM   #60
Did you get a reply from Axial?
