Thread: pins in dog bone
Old 08-13-2011, 05:44 PM   #1
Default pins in dog bone
any one have the pin move or slide on the end of the dog bone? mine has done this twice now locking up the front end from turnig and steering..
swood74 is offline   Reply With Quote
Old 08-13-2011, 05:48 PM   #2
Havent had that happen but have had the dogbone come out of the c cup and locked everything up and caused a tranny gear to fail.
michael is offline   Reply With Quote
Old 08-13-2011, 06:43 PM   #3
zonkerd's Avatar
pull the inner axle out put a small o-ring on it slide it back in,this keeps it in cup deeper
zonkerd is offline   Reply With Quote
Old 08-13-2011, 09:42 PM   #4
deeper in the cup wont help....its like there needs to be a set screw in the end of the axle to hold the pin in place
Old 08-14-2011, 02:30 AM   #5
Aren't the pins press fit into the dogbone end? If so you may have had enough stress on it to wear and get sloppy.
SC Convert is offline   Reply With Quote
Old 08-14-2011, 08:25 AM   #6
zonkerd's Avatar
because on full turn the pin comes out of the cup causing it to bind. deeper in the cup will correct this
Old 09-07-2011, 09:46 AM   #7
From the sounds of what the OP is saying the pin actually came loose from the dogbone itself.
Old 09-07-2011, 10:08 AM   #8
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Correct. You need to get that axle replaced, there isn't going to be another easy fix for it.
Harley is offline   Reply With Quote
Old 09-07-2011, 10:10 AM   #9
Center the pin and put a dab of red locktite on it. Let it sit for a day before you use it. I've done this on a TLT dogbone before. It's worth a try.
War Pig is offline   Reply With Quote
Old 09-07-2011, 07:28 PM   #10
Get some loctite 609 its a Retaining compound made for stuff like this. Its some Real tough stuff.
clayton78 is offline   Reply With Quote
