Thread: 1st Run w/ Wraith
Old 09-10-2011, 04:39 PM   #1
Default 1st Run w/ Wraith
I have had 3 good runs, bone stock, using 2800mah 2S Hyperion 20c. Fun fun fun.
Just taking it easy, crawling around the backyard on the rocks, and a little WOT on the lawn. The motor seems pretty warm and I'm only running about 10 minutes. Normal for these brushed motors to get this warm? Thanks for helping a Wraith newb.
Wavekatcher is offline   Reply With Quote
Old 09-10-2011, 04:41 PM   #2
Drop to a 19t pinion. It is geared to tall from the factory, Then your motor will run cool.
mwscooters is offline   Reply With Quote
Old 09-10-2011, 06:16 PM   #3
Ok, 19t it is then.
The stock pinion is "48dp 20T"........will a PRS "48P 19T" work? I'm still learning and I'm not sure what dp or p stands for. Also found a Robinson Racing 19T "48P" for sale. Any help would be appreciated
Old 09-10-2011, 08:53 PM   #4
youll be fine
Desert Rc is offline   Reply With Quote
