10-06-2011, 01:36 AM | #21 |
Rock Stacker Join Date: Jun 2009 Location: Denmark
Nice bild |
10-07-2011, 02:35 AM | #22 |
10-07-2011, 10:40 AM | #23 |
Pebble Pounder Join Date: Feb 2006 Location: San Marcos, TX
I'm looking at ordering the same Vanquish rims you have on Wraith but I am not sure which wheel width to order. Which one are you running? And am I correct that you are running the .225 hubs? Thanks for your help.
10-07-2011, 11:01 AM | #24 |
RCC Addict Join Date: Oct 2008 Location: Alpine,CA
| I'm running the 1" wide version, And your correct - .225 Hub's.. Seems like some have had rubbing issues with the .225's - but i have none. So ? Lol. Seems like the next size up is popular.
10-07-2011, 03:49 PM | #25 |
Thanks for the info. And since I am here asking questions, let me ask you another one. I see you are running the lowering kit on yours. At full compression on mine, the top of the servo arm is hitting the very front cross-member of the frame. Does yours tuck inside of it? Seems like with a lowered truck, it would limit it quite a bit.
10-07-2011, 06:52 PM | #26 | |
10-13-2011, 03:13 PM | #27 |
Chop, Cut , Throw money at it. Had John cut me some Delrin ring's for my SLW's. Dig the look - just need some more hardware. Also did some cage cutting, Used 106mm link's. Look's OK. Lil' bit more jeepish. Last edited by DiEzel; 10-13-2011 at 03:17 PM. |
10-13-2011, 11:35 PM | #28 |
Those V6's looked wicked cool with the delrin rings... |
10-14-2011, 12:48 AM | #29 |
I wanna be Dave Join Date: Nov 2008 Location: Chillin in Utardia
That is sick with the rear wheels steer....the wheels look even better as well. Nice work.
10-16-2011, 09:10 PM | #30 |
So there is also a little back story as to why i purchased these rings aswell. See my SLW's for whatever reason kept shitting beads every 1-2 packs. I thought.. "Ok, Maybe a different ring will bite the bead a little harder, and i can change up the look a bit." Well, Here i am after my first weekend with the new rings.. Still shitting beads. Bout tired of reseating em after every 1-2 packs, Let alone im sure the tire beads are loving life by now. Yes, The hardware is tight, Yes the bead is correctly in the groove. This isn't my first set of beadlocks (I've purchased 9 pairs of SLW's, as well as lots of other various wheels) and ive never, ever had this problem... And sure, My rig's got some horsepower - But most the time im watching the bead rip out on a nice slow tight turn when the bead has a bunch of load. Here's some pictures, 1 with each ring (I wont include all 16 pictures of the beads) Aswell as the Ripsaw bead, and SLW bead... But - I'd like to make it very, very clear it happens with Both R35's and Swampers. Inner, and Outer beads. It looks like the wheel's bead groove is to large. |
10-16-2011, 10:02 PM | #31 |
RCC Addict Join Date: Mar 2011 Location: Katy / west houston
sweet wraith, i cant wait to start building mine.
10-17-2011, 12:38 AM | #32 |
Well that is a bit unsettling...I have a set of slws on the way. I bought them becausee the xr10 wheels I tried are NOT going to cut it. Man I hope they seat like my old DHs
10-17-2011, 08:12 AM | #33 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
What is the bead width on the wheel. I am sure someone from VP will weigh in on if it is correct.
10-17-2011, 10:23 AM | #34 |
Mounted up a set the other day and had no issue at all. Even when at high RPM I didn't lose a bead. Very weird.
10-17-2011, 10:42 AM | #35 |
Sometimes, I make things. Join Date: May 2009 Location: Mt. Upton
My guess would be the tolerance on the wheels is a little off frrom the area where the ring will bottom out, and the surface that pushes on the inside of your tire bead against the outer ring (I hope that makes sense). I have had this on other wheels but not any of my VP wheels, but it is machining, these things happen. I would try to take a nice fresh and flat pc of sandpaper, like 220-300 grit, and lay it on the most solid, flat surface you can find, like a plate of steel or very smooth and hard wood, just make sure the surface is perfectly flat, as well as your sandpaper,, and sand down the face of the wheel itself, where the ring bottoms out and the holes are tapped. Try sanding about .005 or so off (about the thicknes of a pc of paper) and try that out and if it still spits beads, sand a little more off until it clamps them tight. I had to do this on some delrin beadlocks I had and one set of aluminum wheels. Just make sure you won't hit the surface of your wheels spokes, I haven't had any V6 SLW's so I don't know if the surface I am telling you to sannd is flush, above or below that area, just check it on a flat surface and see if the tapped face sits farther out than your spokes, if the spokes sit out too far, you may need to use a lathe and a turn tool to get the same effect.. |
10-17-2011, 12:13 PM | #36 | ||
10-17-2011, 03:42 PM | #37 | |
Then you might need to find some tires with thicker beads, or get different wheels, they wont fix themselves. | |
10-17-2011, 04:01 PM | #38 |
10-17-2011, 04:27 PM | #39 |
Quarry Creeper Join Date: Oct 2011 Location: Georgetown, On
thats a bit strange... ever thought of running loctite on the beads then clamping them down? i had the same problem with my scx10 1.9's. it seemed to work pretty good, and its not to bad to remove. I use it on my output shaft for the pinion to stay in place, takes side cutters to remove. great looking build by the way! id love to sink tons into my truck, i need to sell my slash and summit first. I want to dedicate my RC fun to crawling and helicopters. Next on my list is a scale warn winch, winch plate, forward battery mount and a metal steering setup. the steering ill make, i think i found a nice easy way. |
10-17-2011, 04:33 PM | #40 |
RCC Addict Join Date: Dec 2010 Location: middle,tn
I would not use loctite on bead screws hell they strip easy enough as it is.. If thats the problem which I don't think it is use silicone it works great and breaks free as easy as without but holds great.. I believe you have a set of wheels with some machining error it happens. I'd get with vp and find a solution I'm sure they'd be more than happy to work with ya J-bird |
