Thread: Harley's Wraith Sportsman
Old 10-12-2011, 01:30 AM   #101
this is looking great Harley, how strong are the wraith axles compared to upgraded SCX10 axles?
Landcruiser 110 is offline   Reply With Quote
Old 10-12-2011, 06:09 AM   #102
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Depends on what you call upgraded. Unless you are using Super 300's I would say that Wraith Axles with universals is stronger. If you do AX10 with long Beef Tubes and XR10 universals would be about the same and a better width for a sportsman. This truck is wide.
Harley is offline   Reply With Quote
Old 10-12-2011, 05:48 PM   #103
20K Club
Harley's Avatar
Starting to dig in.
Old 10-12-2011, 06:34 PM   #104
20K Club
Harley's Avatar
Hmmmm, just not liking this setup :-/
The Wraith axles are just too wide. Link mounts are causing suspension binding that I'm not liking mostly. It would require some much more complex bends.
This project may have to turn into something else....
Old 10-12-2011, 06:58 PM   #105
Don't give up that easy Your Awesomeness.
Drill out some bent XR rod ends to 4mm. Should fix the binding at the axle without needing to go crazy with the links.
Almighty Malach is offline   Reply With Quote
Old 10-14-2011, 08:11 AM   #106
Looks good. Can't wait to see it built.
dogzpolo is offline   Reply With Quote
Old 10-14-2011, 08:53 AM   #107
running into the same problem with those axles on alot of attempts with other chassis.
lagz2point0 is offline   Reply With Quote
Old 10-14-2011, 09:01 AM   #108
20K Club
Harley's Avatar
This will likely be converted to AX10 axles with long beef tubes.
Old 10-14-2011, 10:01 AM   #109
"HOLLYWOOD"
Mini's Avatar
I think you need to fix the glass on your tabel looks a little off lololol
Mini is offline   Reply With Quote
Old 10-14-2011, 10:17 AM   #110
20K Club
Harley's Avatar
I pushed it a little far
Old 10-14-2011, 10:46 AM   #111
Did you try mounting the lower links inboard of the dual sheer mounts?
Also you could run XR lockouts with cut down stock shafts to narrow the rear axle.
4xFord is offline   Reply With Quote
Old 10-14-2011, 10:51 AM   #112
20K Club
Harley's Avatar
Mounting inside the mounts was tough on the diff side. No room for a nut. Could be done though if you took the mount off first and used a button head.
XR lockouts did go on but yes you need to cut down shafts and there isn't enough meat on the shafts to do that IMO.
Old 10-14-2011, 01:27 PM   #113
i felt like this also. Runn'in into a little more work than i thought. Among other things, i have to make all new links and might have to use calculus.
Think about it this way, if you just go back to ax10 axles, ehh, it will probably be bad ass, but wraith axles...
Push it thru man!
16hp is offline   Reply With Quote
Old 10-14-2011, 01:41 PM   #114
Well the mounts are super easy to pull off due to the design. Why not just try that? Unless you ordered a set before, KC said he wasn't going to make any more long beef tubes.
Old 10-14-2011, 01:47 PM   #115
20K Club
Harley's Avatar
That wasn't really my biggest concern. I could build some crazy curved links like we build for the MOA's but my concern is width mostly. I'm at a little over 11.5" now and without special wheels it's not gonna be where I want it.
I read he isn't making them. I can always just go have some turned though. They are a simple product.
Old 10-14-2011, 06:33 PM   #116
I hear ya, they are better suited for a shafty super really, they are Damn near as wide as my super berg axles!
Old 10-14-2011, 06:35 PM   #117
Thats sad to hear these could of made some nice sporty axles if they werent so wide.
DRCrawlGood is offline   Reply With Quote
Old 10-14-2011, 07:16 PM   #118
Starting to dig in.
wonderful table. DIY or purchased? Send me a PM its super cool!
daign is offline   Reply With Quote
Old 10-14-2011, 07:25 PM   #119
Let me know when you dont want that table anymore.
To bad the axles are so wide.
johnnie walker is offline   Reply With Quote
Old 10-14-2011, 09:14 PM   #120
20K Club
Harley's Avatar
Built
Here is the build thread: http://www.rccrawler.com/forum/chit-...re-frames.html
