10-05-2011, 12:06 AM | #1 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
| Suicide Switch Steering
Something new from CKRC that looks like it may be fairly effective not to mention has a bada** name Anyway here is the link CKRC's Suicide Switch Steering Upgrade Kit (Wraith) [ck180020] - $31.99 : CKRC Crawlers, RC Rock Crawlers I may order one and do a review |
10-05-2011, 12:16 AM | #2 |
RCC Addict Join Date: Oct 2008 Location: Alpine,CA
Am i the only one that see's this for $32 ? |
10-05-2011, 01:03 AM | #3 |
Rock Crawler Join Date: Jan 2006 Location: Derbyshire UK
Good idea, but most of us will have the parts/skills to make that kit up for a lot less $$$$$
10-05-2011, 07:07 AM | #4 |
Pebble Pounder Join Date: May 2011 Location: Port st. lucie
Looks very interesting. Will that setup increase or decrease the amount of torque applied while turning? Meaning, Will my servo work harder. Or make easier for it to turn. Or no effect? This setup would successfully allow the use of a servo savor. Which would improve handling at higher speeds! Yes, I do understand that would take away the ability to crawl. Last edited by buzzbuzzard; 10-05-2011 at 07:22 AM. |
10-05-2011, 07:17 AM | #5 |
Pebble Pounder Join Date: Aug 2011 Location: schererville
Great idea. Glad I made mine from all thread, extra rod ends, and stainless tubing for sleeves. Already had everything. sent from my on the go rcc updater. |
10-05-2011, 07:53 AM | #6 |
Pebble Pounder Join Date: Aug 2008 Location: Wichita Falls
10-05-2011, 08:12 AM | #7 |
There is a reason we don't use a setup like that. A tie-rod keeps the wheels turning the same amount (percentage of throw as distance depends on Ackerman). Two drag links does not accomplish that. To prove that, try and attach another drag link to the other side of you standard setup. I think you will see ill effects at speed.
10-05-2011, 08:19 AM | #8 | |
Is that because of the slop in the ball joint? Which would cause a delay? Last edited by buzzbuzzard; 10-05-2011 at 08:23 AM. | |
10-05-2011, 08:24 AM | #9 |
10-05-2011, 08:28 AM | #10 |
| Bummer, Thanks Bro. Almost had a solution for me needing a servo saver.
10-05-2011, 08:31 AM | #11 |
Pebble Pounder Join Date: Aug 2011 Location: phoenix (Ahwatukee)
| Most of that effect could be counteracted with a longer servo horn, but then again longer servo horn= less torque for steering. But in this application I don't think we have room for a longer horn or we will be hitting the diff cover.
10-05-2011, 08:37 AM | #12 |
| Same reason I can't use a servo saver. Clearance of the diff. The saver won't clear the tie rod. Can't move the tie rod.
10-05-2011, 08:45 AM | #13 |
I see absolutely no reason to use this.
10-05-2011, 09:07 AM | #14 |
| Indeed Harley. There is no need for servo saver. The tension from the saver won't allow the wheels to turn at slow speeds. Or at all while at idle. I have experianced this in my trials. However, I have no plans of crawling with my RTR Wraith. I'm gonna get the kit and start over for that. The Wraith I have now. I have plans to put a front indepenant suspension. Straight axle at high speeds=violent wrecks. Having saying that. I still need to use the Stock diff.
10-05-2011, 09:09 AM | #15 |
10-05-2011, 09:17 AM | #16 |
10-05-2011, 09:18 AM | #17 | |
10-05-2011, 09:28 AM | #18 |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
If the servo arm went up instead of down, you would actually see a good effect from the ackerman created. As is, it going to be toed in while turning. Fail, and x2 for the price!
10-05-2011, 09:31 AM | #19 |
you could make that for less than 1/3 of the price. IMO ckrc, just say no. |
10-05-2011, 09:36 AM | #20 |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-wraith/340773-suicide-switch-steering.html | ||||
New Wraith Steering - TheToyz Forums | This thread | Refback | 10-05-2011 09:07 AM |
