08-06-2013, 11:37 AM | #221 |
| Re: Jeremy's RCC Giveaway Wraith Kit Build
Harley said that replacing the gears with a bls157 set is the strongest.
08-06-2013, 11:40 AM | #222 |
I think replacing the servo with a 7950 is the strongest.... |
08-06-2013, 11:41 AM | #223 |
| Re: Jeremy's RCC Giveaway Wraith Kit Build |
08-06-2013, 12:31 PM | #224 |
08-06-2013, 12:50 PM | #225 |
Thats why I originally put them on the truck.....I already had them. Then, I broke a gear. Not a problem....only $30 for a gearset. I can make the main gear last through two breaks (cut off the stop and flip the gear around). I have had to buy at least 5 gearsets for these servos. At some point a person realizes they must cut their loss and buy a product that isnt going to blow up on each run....
08-06-2013, 02:05 PM | #226 | |
RCC Addict Join Date: Feb 2005 Location: Vancouver Island B.C.
| Re: Jeremy's RCC Giveaway Wraith Kit Build Quote:
08-07-2013, 09:16 PM | #227 |
I have not been able to keep the Maxx shafts from breaking rather quickly. Ive even tried strengthening the inner part of the male shaft and it just shifted the weak point to the yoke ears. In preparation for the upcoming G6 at nats, I installed a set of MIPs. I had to use the longer yokes on both ends of the rear shaft to get the length I needed. |
08-07-2013, 09:19 PM | #228 |
RCC Addict Join Date: Mar 2011 Location: Katy / west houston
It's about time!!! I can hear the squeaking already! What's different on yours? I have the Wraith MIP kit, it fit fine? |
08-07-2013, 09:22 PM | #229 |
Yeah, I will certainly miss those smooth and quiet Maxx shafts... The flipped rear axle added to the length. |
08-07-2013, 09:26 PM | #230 |
Why did you flip the rear?
08-07-2013, 09:27 PM | #231 |
Accident.
08-07-2013, 09:27 PM | #232 |
08-07-2013, 09:30 PM | #233 |
I did not have to do that, I have a flipped rear as well.
08-07-2013, 09:34 PM | #234 |
Well hell, I dunno then. These were AX10 MIPs. I thought they were the same as the wraith MIPs except the longer yokes. Is that not true?
08-07-2013, 09:36 PM | #235 |
IIRC, the shafts are longer. Let me go measure...
08-07-2013, 09:42 PM | #236 |
08-07-2013, 09:53 PM | #237 |
Wraith max 5 1/2" AX10 max 5 1/4" ROWDY I know what your laughing about get your mind out of the gutter, this is some serious shaftsman talk here. |
08-07-2013, 10:05 PM | #238 |
Rock Crawler Join Date: Apr 2008 Location: Boise, Idaho
| Re: Jeremy's RCC Giveaway Wraith Kit Build MIP's, I've had great luck in my rigs. I have yet to break one.
08-07-2013, 10:13 PM | #239 |
08-07-2013, 10:14 PM | #240 |
