10-11-2011, 05:16 PM | #1 |
Pebble Pounder Join Date: Aug 2008 Location: Wichita Falls
| Anyone get full lock to lock steering with stock radio?
I just tried to reprogram my hitec servo to lock to lock, then when i hook up my radio it only goes about 50%.. anyone else experience this?
10-11-2011, 05:23 PM | #2 |
Sometimes, I make things. Join Date: May 2009 Location: Mt. Upton
Play with the ST/DR dial on the right side of your control panel on the radio. It will limit your steering, but dont set it so it steers too far as it may travel past your CVD shafts capable angles.
10-11-2011, 05:24 PM | #3 |
| Servos typically don't move full lock to lock of their travel. They move 90 degrees typically. This is pretty standard and the same as what the stock rail does. Some radios you can bump up to 120% but you lose torque as you increase the travel because you effective lever arm gets shorter as it arcs.
10-11-2011, 05:27 PM | #4 | |
10-11-2011, 05:29 PM | #5 |
| +1! That did the trick, I set EPAs on servo at lock position so I can just max out that switch. Thanks.
10-12-2011, 08:25 AM | #6 |
Another tip to power the Hitec programmer, it says you need a rx pack from 4.8v to 6v, I figured I could just use my BEC lead since its set at 6v, WRONG! But the stock axial radio has a rx pack built in to hold the AAs, and it worked perfect for the programmer, thats nice that axial added that as upposed to their previous radios.
