Thread: who else makes steering links for the wraith??
Old 10-28-2011, 07:01 AM   #1
Default who else makes steering links for the wraith??
Ok so vanquish has been out of stock for a while, at least every time I check so who else makes them?
Also, kinda bummed I bought hot racing lower axle/shock mounts, have you seen the new axial ones? Oh man adjustable and really sweet looking
william g is offline   Reply With Quote
Old 10-28-2011, 07:05 AM   #2
You can make them yourself with parts from the hardware store. They are easy and cheap.
Here is one that I built for my rear steer:
I used all thread and sleeved it with aluminum. The only tools I used were a pair of sidecutters, my dremmel to bevel the edge of the all thread (so that the rod ends threaded easier), a cheap hand bender and a small pipe cutter.
JeremyH is offline   Reply With Quote
Old 10-28-2011, 07:07 AM   #3
Sometimes, I make things.
crazyorigin's Avatar
I have some Stage3 tie rods on mine but I am not overly happy with them, they fit the stock axial ball sockets and have a lot of up/down travel, some thick o-rings would fix it bur I find it frustrating that they do not come with the kit, I wish I had just bought thbe VP ones. I am going to try to make the ones I have work before replacing them but if I did it over again I would get the VP units.
crazyorigin is offline   Reply With Quote
Old 10-28-2011, 07:26 AM   #4
Avoid the level 3.
Mine bent the first time I ran into a desk chair (the one on wheels!) Bent up and the plastic balls (the original plastic ball).
It also doesn't clear the diff cover without trimming.
I might make my own one up. I did for my AX10.
Oze30 is offline   Reply With Quote
