10-17-2011, 08:53 PM | #1 |
Pebble Pounder Join Date: Sep 2011 Location: Medford
| Steering link and drag link - what's the best bang for the buck?
Looking to upgrade the steering linkage and drag link. I have the Axial aluminum C hubs and knuckles on it already. Anyone have these parts with upgraded linkages? Some I've seen have been messing with toe in/out. I want to avoid that! Obviously! So so there is the Vanquish and the Level 3rc. Any others? Thanks! Oh and pics if you have them!
10-17-2011, 11:07 PM | #2 |
Master Rocksmith... Join Date: Jun 2011 Location: Salina
Dollar for dollar, i'd say you cant go wrong with the Level 3... its only 17.00 bucks. and it looks pretty good, and is hella strong. only weak point i can see is that it has square edges, so it might get hung up a bit more often than a round steering link, in real rocky conditions. but it hasn't really bothered me. |
10-18-2011, 09:54 AM | #3 |
Pebble Pounder Join Date: Aug 2011 Location: phoenix (Ahwatukee)
^^How well do your baja claws grip? Vanquish link on mine with a CKRC drag. |
10-18-2011, 10:27 AM | #4 |
Pebble Pounder Join Date: Oct 2011 Location: Ontario
I see ckrc isnt very well liked around here, but has anyone tried the suicide switch set-up? Ordered a pile of stuff from them before i found this place, then saw all the negative reviews. Lol. Guess ill see.
10-18-2011, 10:43 AM | #5 | |
10-18-2011, 12:18 PM | #6 |
Rock Crawler Join Date: Nov 2009 Location: poteau
best bang for the buck can mean different things. cheapest now, or cheapest in the long run. i went with the vanquish links. a little more expensive, but they will last. no worries about having to change them later due to bending or wearing out. so for me that is the best bang for the buck. the level 3 works pretty good, a friend of mine had it on his but swapped it out for the vanquish. he was running the stock drag link until it broke at the mount. swapped that with an aluminum one we made, then he broke the level 3 tie rod after jumping his wraith and landing the tie rod on a rock. it broke at one of the bends next to the diff cover. that said, i would guess the cheapest route would be to just build your own. |
10-18-2011, 12:32 PM | #7 |
| That'd why you see I have 1/2 a vanquish kit and 1/2 a CKRC kit. The CKRC kit hit the diff cover and the rod ends were to fat and they rubbed the stock wheels. I just bought the Vanquish link and kept the drag link from CKRC. Seems to work very well.
10-18-2011, 12:35 PM | #8 | |
Quarry Creeper Join Date: Oct 2011 Location: Georgetown, On
I am going to run two drag links to the servo arm and see how it works. will post pictures when its setup, will be sometime later in the week. | |
10-18-2011, 12:37 PM | #9 |
10-18-2011, 12:42 PM | #10 |
I see what our saying about bang for the buck vs value and longevity. The vanquish seem to be the best of all. With both tie rod and drag link and being made of Ti, they will last for the long run rather than having to buy more aluminum ones multiple times. How strong are th Vanquish plastic ends? |
10-18-2011, 12:54 PM | #11 |
| Think he means something like this. Its the one i have on order. CKRC's Suicide Switch Steering Upgrade Kit (Wraith) [ck180020] - $31.99 : CKRC Crawlers, RC Rock Crawlers |
10-18-2011, 01:01 PM | #12 |
| very strong. my 9 year old daughter was running it flat out and caught a tire on a fence post. pulled the tire out of the beadlock, spun the truck around and flipped it a couple times. no damage at all (except having to remount a tire!) |
10-18-2011, 01:21 PM | #13 |
Pebble Pounder Join Date: Jan 2011 Location: vienna
| nice - thats how i drive. I too went with vp, the rod ends are strong 4mm i think
10-18-2011, 02:22 PM | #14 | ||
[QUOTE=strap624;3333502]^^How well do your baja claws grip? Vanquish link on mine with a CKRC drag. the claws were ok, but with this new cut job, im assuming they will be better? Quote:
and the drag link is an axial 70mm link i had lying around from previous projects. Quote:
10-18-2011, 06:08 PM | #15 |
Rock Crawler Join Date: Oct 2009 Location: Michigan
I made my own out of 1/4 .049 wall aluminum tube, seems pretty strong so far. |
10-19-2011, 05:54 AM | #16 | |
Rock Crawler Join Date: Mar 2008 Location: 920 Valley of the Fox
How long do you think a stock servo would last with that setup? Esp. if you want to crawl a little... The Traxxas Stampede has a similar setup, & it sucks! (mind you it is almost a 20 year old r/c design) There is a reason they put bellcrank steering on the Slash, when it was designed, instead of the Stampede setup. Even though the Slash/Stampede are nearly identical except for the chassis. And for $31.99, you could get a QUALITY steering setup like the Vanquish Last edited by R/CMaxximus5.0; 10-19-2011 at 06:05 AM. | |
10-19-2011, 07:03 AM | #17 |
No offense taken. I wasn't sure, thought it might work well for a rear steer setup. And my stock servo only lasted 1 outting anyhow. LOL
10-19-2011, 07:48 AM | #18 |
There are a ton of problems with that CKRC setup. It is a terrible design. It makes each tire turn differently throughout the cycle. That's a huge DO NOT BUY.
10-19-2011, 07:59 AM | #19 | |
Seems like CKRC will sell any crap they can to make a buck! | |
10-19-2011, 08:10 AM | #20 |
| Anyone wanna buy one? Lmao! Wish i had found this place before i placed that order! Live and learn i guess.
