Thread: Diff issue while building Wraith kit.
Old 10-25-2011, 08:33 PM   #1
Default Diff issue while building Wraith kit.
Ok, getting late and i am going nuts here. I know i am doing it the right way, but if i look at the directions it says i am installing the diff backwards in the housing. For the front, install the diff with the gear facing the short side. Installed as per the pics. Easy enough. But when i turn it clockwise (direction my rtr driveshaft turns to go foreward) the diff goes in reverse. But I watch a few build videos, and that is the way it says to install it. Am i missing something? Awful tired at this point, so maybe?!?
stricker76 is offline   Reply With Quote
Old 10-25-2011, 08:38 PM   #2
can be installed either way,depending on the way you choose you will have to reverse your motor.
michael is offline   Reply With Quote
Old 10-25-2011, 08:55 PM   #3
So seeing as the kit is getting the drivetrain out of my rtr, ill flip them around, correct?
Old 10-25-2011, 08:57 PM   #4
yes, my rtr came with the diffs reversed.
Old 10-25-2011, 09:38 PM   #5
Yep, thats how Axial got around the short shaft issue everyone is haveing assembling the axles according to the directions.
transambill is offline   Reply With Quote
