![]() | #21 |
Quarry Creeper Join Date: Aug 2011 Location: Australia
nice man, gotta love the panels, shimmering in the sun, looks sic.
![]() | #22 |
Quarry Creeper Join Date: Jan 2008 Location: Cumming/ North ATL
Rig looks great ![]() |
![]() | #23 |
RCC Addict ![]() Join Date: Mar 2007 Location: Penngrove
Feel like I spent all weekend making panels to mount stuff to this Wraith... First I prototyped an 0.028" thick Aluminum panel that might make its way into production, this panel is designed to mount either the 3", 4" or 5" MadDogRC - chino63 light bar to the top (or bottom) side of the Wraith roof. ![]() Next I prototyped another set of panels that definetly will be a production piece. These 0.060" black Styrene panels will allow users to mount our Wraith specific Delrin Rock Lights to the under side of the Wraith rockers. ![]() Lastly, I fab'd and painted an Aluminum tailgate panel that Ill use to mount a single rock light that I painted red as well as a d-ring for towage. ![]() Some install pictures coming tonight... |
![]() | #24 |
RCC Addict Join Date: Sep 2011 Location: Peoria, AZ
Pretty cool idea cant wait to see how they look on the wraith especially at night. ![]() |
![]() | #25 |
RCC Addict ![]() Join Date: Nov 2011 Location: cold state
Subscribe to this one for sure!! Looking sweet so far with light mods!
![]() | #26 |
Pebble Pounder Join Date: Dec 2009 Location: Silverton
Good looking setup. Where did you find lock nuts that would fit on the tie rod and drag link ends.
![]() | #27 | |
Donkey Punch Champion! ![]() Join Date: Oct 2006 Location: Minneapolis
| ![]() Quote:
![]() | #28 | ||
Thanks guys. Quote:
![]() Now on to an update; first I made up a wiring harness to hook up all these lights, it ended up as a two piece harness since the switch will be attached to the interior and I want to keep every thing modular. ![]() The new light bar panel can be used under the stock roof panel to ensure a sturdy base to attach the bar, it will also work under with the Dinky lid with the 3" light bar: ![]() The rock light panels attach to the inner case with zip ties, the Wraith specific rock light buckets attach with thin M3 hardware so as not to interfere with the interior: ![]() The outer holes of the rock light panels use M2.5x8mm screws in the stock locations, M2.5 hex nut will be used to hold in the interior: ![]() I also assembled the tail gate to the chassis, the M2.5x8 screws in the lower holes of the d-ring bracket go straight through the frame so that it's stout. Here is mock up with side panels, mmm... ![]() Hood mounts are Associated cross drilled socket head cap screws with some 3mm Aluminum spacers: ![]() And how could you not want a 2" light bar on the front bumper?...fits nicely in stock location... ![]() | ||
![]() | #29 |
Quarry Creeper Join Date: Feb 2009 Location: Livermore, CA
Nicely done. ![]() |
![]() | #30 |
Rock Stacker Join Date: Nov 2011 Location: united states
How did you cut the wheel wells so perfect?
![]() | #31 |
| ![]() Thanks Thank you Rough cut was made with a abrasive cut-off wheel on a Dremel. I finished the cut using the round end of my stationary belt sander. |
![]() | #32 |
Quarry Creeper Join Date: Oct 2011 Location: Livermore Ca.
Looking good, I really like the light and alum panels ![]() |
![]() | #33 |
Ok . Got ya. I've tried to do it with some tin snips. I can close but, that belt sander would be key. They look sweet.
![]() | #34 |
Pebble Pounder Join Date: Jan 2005 Location: Blanchard
This thing is sick! I really like that rear panel with the light and shackle mount.
![]() | #35 |
Guess I was suppose to praise your panels before I asked how ya did it.
![]() | #36 |
Rock Stacker Join Date: Mar 2009 Location: frederick
Can we get a pic of it all lit up to check out those lights???
![]() | #37 |
OK, you got pics! Didn't want to put any of the stock lights back on so I zip tied another set of the 1" rock lights to the front bumper. The angle is actually perfect to illuminate the rocks in front of the tires: ![]() Roof light came out pretty cool. I wish I would have not cut the opening in the top until after I measured it, now I have two 3/16" "air ducts" on each side... ![]() Rear panel turned out sweet: ![]() Now pics: ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
![]() | #38 |
Pebble Pounder Join Date: Oct 2005 Location: Sacramento
On the shocks you just added 12mm of tubing to the inside and thats it? Want to replace the stockers but want to stay the same length or tad shorter even. ALso mounting hardware, use the stock hardware? thanks! Great rig, dig those lights! |
![]() | #39 |
Holy !@#$ !!!! That is awesome!! What is the link for those lights??
![]() | #40 | ||
| ![]() Quote:
2" on the front bumper: MadDogRC - "chino63" Scale 2" LED Light Bar Standard rock lights are here and can be used on the front bumper but the Wraith specific one's on this truck aren't quite released yet...(cough, next week, cough ![]() MadDogRC - "chino63" Scale LED Rock Lights 3" on the roof is here: MadDogRC - "chino63" Scale 3" LED Light Bar We also offer 4" and 5" versions respectively: MadDogRC - "chino63" Scale 4" LED Light Bar MadDogRC - "chino63" Scale 5" LED Light Bar | ||
