11-17-2011, 06:17 PM | #21 |
RCC Addict Join Date: Feb 2005 Location: Minneapolis
11-17-2011, 06:23 PM | #22 |
Newbie Join Date: Oct 2011 Location: Roseville
awesome thanks!
11-17-2011, 07:01 PM | #23 |
ok im having another problem.. im replacing the knuckles as well with strc knuckles and the larger bearings wont fit in the strc knuckles.. any1 know why they arent fitting?
11-17-2011, 07:29 PM | #24 | |
Quarry Creeper Join Date: Sep 2011 Location: Spring Texas
It's a good product. Good luck --- I am here: http://maps.google.com/maps?ll=30.078702,-95.460166 Axial Wraith and Losi SCTE | |
11-17-2011, 07:30 PM | #25 | |
Quarry Creeper Join Date: Mar 2008 Location: Pittsburgh
ETA: Francois beat me to it. | |
11-17-2011, 07:33 PM | #26 | |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
11-17-2011, 07:36 PM | #27 |
| I think that I read is that the bearings are a very tight fit and may require a little dremel work on the knuckle. I can't say for sure, but I think that is what I read.
11-17-2011, 07:42 PM | #28 |
Go super light with Mrs Dremel.... --- I am here: http://maps.google.com/maps?ll=30.078768,-95.460145 Axial Wraith and Losi SCTE |
11-17-2011, 07:57 PM | #29 |
One note, just inside big bearing seat if the knuckle, I grind a two notches so I can later use a punch to remove the bearing easier. For installation, you might try freezing the bearing and heating the knuckle up. |
11-17-2011, 08:47 PM | #30 |
Rock Crawler Join Date: Nov 2009 Location: poteau
personally i would hang on to the $50. for most people, you will either be replacing the stock motor due to smoking it, OR you will need to regear your truck. this seems to depend on what you plan on using it for, as with most upgrades. if your gonna crawl with it, the motor will go quick!! might spend $10 and get some lead rope, or solder to wrap those front rims with for a little weight to. oh yeah, get some CA glue (super glue) your gonna need it |
11-18-2011, 04:48 AM | #31 | |
Rock Crawler Join Date: Oct 2010 Location: Chezzetcook Nova Scotia
when i saw the screw I thought, how could I be so dumb.. | |
11-18-2011, 04:53 AM | #32 | |
I tried the Delrin for a Steering link and its like you say, WAY to flexible. Even more than the stocker. I do however have Delrin lower links with Revo ends and they seem plenty strong. If I grab the 2 links and squeeze I can get a bit of flex but it helps with barrel rolls down long hills. My lower links are straight. If I put a bend in them they would be too flexy. | |
11-18-2011, 07:29 AM | #33 |
Rock Crawler Join Date: Jan 2010 Location: In the lair editing video
so much you can do for free or on the cheap, do the drive shaft mod with piano wire and shoe goo to beef up drive shafts, flip the lower shock mounts, and invest in some hubs and knuckles. I keep the flexy steering link because the design doesnt incorporate and servo saver. The steering link allows your servo to survive big impacts. I also stick with dog bones for durability. Just go out and enjoy it, it's loads of fun in stock form! |
11-18-2011, 01:05 PM | #34 |
Thanks for all the help everyone! I reminded myself why i dont work on vehicles or R/C's when im tired. I got the new knuckles put on and got everything back together just to realize that i put the damn knuckles on the wrong sides! oh well, at least it doesnt take long lol
11-18-2011, 01:08 PM | #35 |
Pebble Pounder Join Date: Jun 2010 Location: Gresham
get another 7 bucks and get a cc bec.
11-18-2011, 11:04 PM | #36 |
well.. now another problem.. i got it all back together and my steering is VERY tight.. its not free at all and with it all on my tires only turn about an inch.. what could be wrong this time? lol
11-18-2011, 11:13 PM | #37 |
actually nevermind.. nothing is working.. i cant even give it throttle. so, when i turn it on it beeps a couple times then just sits there and the servo kind of twitches and the lights on the front blink very very slightly.. any ideas? Last edited by lamar2626; 11-18-2011 at 11:21 PM. |
11-19-2011, 06:13 AM | #38 |
I think you have bad luck and it s time to sleep. For your steering pb, do you install the knuckles and C hubs at the good side? For knuckles it s write on it but for C hub, you can made a mistake --- I am here: http://maps.google.com/maps?ll=30.078842,-95.460081 Axial Wraith and Losi SCTE |
11-19-2011, 09:33 PM | #39 |
i actually moved the steering by hand freely and it didnt bind anywhere.. so that is good.. but something seems to be wrong with the receiver.. i literally have no control of the vehicle. It just sits there and twitches and the lights slightly flicker. any ideas? bad receiver?
11-19-2011, 09:44 PM | #40 | |
