12-03-2011, 10:50 PM | #21 |
Quarry Creeper Join Date: Aug 2011 Location: Australia
what do you mean, "The HS7980TH will be running at 6V straight off the MMP ...".
12-03-2011, 11:14 PM | #22 |
Pebble Pounder Join Date: Dec 2009 Location: virginia beach
he means that the bec inside of the esc puts out 6 volts and thats what the rear servo will run off of. the forward servo will run off of the external BEC on the bumped up voltage to make more torque. sorry not trying to hijack was just reading and thought I could answer his question.
12-04-2011, 02:31 AM | #23 |
thanks, i seriously am a noob went it comes to wiring and stuff like that.
12-04-2011, 11:34 AM | #24 | ||||
Rock Crawler Join Date: Oct 2008 Location: Somewhere near the lake in IL
I'll go through all the wiring when I get to that point. This build is going to have WAAAYYY too much wire between 4WS, a servo winch, and maybe some lights. Last edited by WarTrader; 12-04-2011 at 11:38 AM. | ||||
12-04-2011, 12:32 PM | #25 |
| Drive Train Part 1
I was going to make my own links for this build today but I realized I didn't have any link ends so onto the transmission. I'm using a stock case but a good bit of the guts are are aftermarket. This tranny is going to see some serious horsepower through it so I filled it up with all metal gears. As you can see the top shaft is also being replaced by one from SuperShafty.com, wow this top shaft is a good bit more beefy! Check it out! The reason I'm swapping that out is I'm going with 32P gears and wanted a stronger slipper. I'm going with a all steel one from RRP. Talk about beefy ..... I got everything buttoned up with little pain and bolted my motor up! I'm not going to be able to run the spur gear cover, that's not really a problem as this Wraith is being built as more of a crawler that my other one. This one isn't getting all the water proofing I did on the other build. WarTrader Does Wraith |
12-04-2011, 01:29 PM | #26 |
RCC Addict Join Date: Nov 2011 Location: cold state
What gearing? Spur? Pinion?RRP?
12-04-2011, 02:16 PM | #27 |
12-04-2011, 04:04 PM | #28 |
12-04-2011, 05:44 PM | #29 |
beefy transmission man. nice build.
12-04-2011, 05:58 PM | #30 |
| Go here this will explain everything you need! http://www.rccrawler.com/forum/axles...imate-mod.html Thanks |
12-04-2011, 07:22 PM | #31 |
Thank you
12-21-2011, 06:09 PM | #32 |
Quarry Creeper Join Date: Dec 2011 Location: Flat Hills of Florida
| Re: WarTraders Wraith V2
Subscribed
12-22-2011, 10:36 AM | #33 |
I've not abandoned this build but this silly christmas-family-work thing seems to be keeping me out of the shop. I've delrin jackets for the links cut, I still have to cut the all thread mate them up and bend them. I promise it won't be too long off though. I've even order some new toys for the build and I'm waiting for one thing to be released before I make a final decision on the front end...
12-22-2011, 06:22 PM | #34 |
nice man, cant wait to see the front end decision |
12-22-2011, 06:27 PM | #35 |
Pebble Pounder Join Date: Dec 2009 Location: Silverton
I just finished my Wraith kit today with all of the VP produts made and a Tekin pro 4 3300kv MMpro and cc BEC. 14/56 32p gears and 5.5 TSL swampers and it runs like stink. And it well run slow also. My only complaint is it turns to sharp. This is fine when slow running but at high speed, I think i well turn down my EPA and try that next. I have had dual steer on my crawler with 7954hss servos frt and rear and no BEC for over three years and never have had a problem with lack of tq. It well move rocks when you move the steering wheel. Sounds like you well have a bullet proof rig. |
12-24-2011, 05:31 AM | #36 |
Rock Stacker Join Date: Dec 2011 Location: Mansfield
I like 4WS! Nice build!
12-24-2011, 05:32 AM | #37 |
I'm ordering the Hitec 7945SH today so guess my upgrade if I do 4RS is bigger servos lol.
12-24-2011, 09:48 AM | #38 |
Rock Stacker Join Date: Oct 2009 Location: Ontario
| Re: WarTraders Wraith V2 |
12-24-2011, 10:24 AM | #39 | |
| Re: WarTraders Wraith V2 Quote:
No, the front axle will not be installed on chassis in this orientation. Remember you''re looking at the pic and can see both diff covers........Wartrader has it correct. | |
12-24-2011, 10:28 AM | #40 |
I dunno, if you flip the one closet to us around to the front(pretend we are looking from the rear) so the pumpkins are both to the left. It will put both ring gears to the right.
