01-21-2012, 03:40 PM | #81 |
Rock Crawler Join Date: Oct 2008 Location: Somewhere near the lake in IL
| Re: WarTraders RUBI JEEP (Big Blue)
I was hoping to get all the electrics done but sadly I realized there were a few supplies that I really needed and of course my local hobby shop had only one out of 5 things I needed.... NOOO Comment. I finished up the paint on the body! I also mounted my TSL Super Swampers on some new Mayhem Monster EX. Dan and Debbie and Mayhem never ever fail to impress with the quality of the products them make and sell! I love the Dynamic Conconcepts Rubi body. I just coulding decide on how to set up my headlights. I really hated to partially fill the space with the large axial large body mounted bucket. I tried the stock locations but they don't line up with the headlights in the body. After making some plates and struggling with some hood mounting decisions I ended up with this! I'm loving how this is turning out. I going to have to wait for the mail man to get any further. Besides I've got a comp tomorrow soo Thanks for looking. Last edited by WarTrader; 01-21-2012 at 04:49 PM. |
01-21-2012, 04:36 PM | #82 |
RCC Addict Join Date: Nov 2011 Location: cold state
Turned out real good I might say!
01-21-2012, 05:02 PM | #83 |
| Re: WarTraders Wraith V2 |
01-21-2012, 05:02 PM | #84 |
RCC Addict Join Date: Sep 2011 Location: Peoria, AZ
Turned out sweet WaTrader, I also like that color. Did you cut the hood to put hinges on for easy battery access. Man I Can't wait to get mine in the mail. |
01-21-2012, 05:35 PM | #85 | |
| Re: WarTraders Wraith V2 Quote:
Here is what I came up with. | |
01-21-2012, 06:02 PM | #86 | |
01-21-2012, 07:41 PM | #87 |
Quarry Creeper Join Date: Aug 2011 Location: Australia
the rig looks SWEET, so does the bumper. nice build |
01-21-2012, 09:46 PM | #88 |
01-27-2012, 10:23 PM | #89 |
Quarry Creeper Join Date: Jun 2009 Location: HOBBY HQ
| Re: WarTraders Wraith V2 Getting Close!
I also mocked up the boatsides the AngryOne at Carter Fab and Machine made for me ! I also swapped out my shocks caps to STRC caps, and STRC aluminum Servo mounts. Now if I can get this cold knocked out and feel better I could get this thing done![/QUOTE] does he sell these? id love like 3 sets? |
01-27-2012, 11:09 PM | #90 |
i like the look of it. nice job
01-28-2012, 07:48 AM | #91 | |
| Re: WarTraders Wraith V2 Getting Close! Quote:
Yeah check the body and paint section. Thanks A little later today I'm stating all the wiring. Yeah cannot wait (insert sarcasm) | |
01-28-2012, 07:56 AM | #92 |
Rock Crawler Join Date: Dec 2011 Location: thurmont
if only i had money. the things i could create if i had money. i think i should get a job
01-28-2012, 08:36 AM | #93 |
Quarry Creeper Join Date: Jun 2008 Location: Albany
Those boatsides look great. Definitely liking the color too |
01-28-2012, 09:14 AM | #94 |
Pebble Pounder Join Date: Dec 2009 Location: Silverton
Nice job. I really like the color and your wheels. Check out my wheels. grin
01-28-2012, 06:06 PM | #95 | |
Angryone does some amazing work. It looks good online, once you get it in the sun it really pops. Thanks. Thanks! Your wheels look fantastic! | |
01-28-2012, 06:50 PM | #96 |
I got some more work done today. I wanted to get a lot more done but sadly I had some errands to run. I started off by making a electronics box. I've made these a few times and they work out really well and keep things nice and dry! I use water line nipples and a project box from Radioshack!(sorry for the dark pics I'm trying to learn how to use my camera and I got something wrong!) I cut some of the water line nipple off 3 ridges to be exact, and then glue it into the side of the box. This will allow me to run the wires out and then use a balloon to make a good tight water tight seal. The ribs on the nipple will hold the balloon and ziptie in place. Now I'm starting on to the electronics. I like to start getting all the outlying systems ready, and just plug everything in and test before I start actually hiding the wires and bolting things together. I'm starting with my servo winch. I've used 3Racing winches in the past and love them but I like the power of a servo winch a little more. I'm using a cheapo Hitec 645. They are available for $30.00, and I have a few others that I can use for spare parts if needed. I've killed one of these in the past, I accidentally hit the three way switch on the radio and over heated the servo without noticing. In this build and in my other wraith I will have a manual switch I use that will turn on the winch. It will still operate from the radio but when I'm not going to be using it it will be powered down to avoid accidents. I'm using Heyok's servo winch controller. I really makes it smooth and easy to do without fighting with drift or struggling with the pot. You start off by disassembling the servo and removing the main gear. You will need to remove the pin and the mount for the pot underneath the gear. You will end up with this look. Next up you remove the controller board. With the exception of the motor wires, I just cut all the wires. The wires on the motor I remove by unsoldering them. I then solder in the Heyok unit to the motor. I then reassemble everything, using dielectric grease I seal all of the case seams, the port where the wire enters, and put a large blob around the base of the main drive gear/output. This will give you a good reliable waterproof winch! All ready to install! There is more info available on servo winches from these sources. http://www.rccrawler.com/forum/elect...o-winch**.html |
01-29-2012, 04:59 PM | #97 |
I got into the meat of the electrical system today. I started off by making a lead that will connect the battery, esc, and BEC. I do this to keep my electronics more modular, which makes wrenching a lot easier. I then started to getting the bec ready by setting the voltage to 7v. I'm only using one for the front steering servo. I'm going to let the rear servo get it's power from my HH-BRXL. This will will supply the rear servo with 6v. I've tested everything after I complete each step. This makes problem solving much easier. After everything worked like it was intended to, I started installing the reciever, BEC and my servo extensions. I use servo extension for all my components again it helps to keep things easy when it comes to maintenance. I label each extension as I install them to keep things simple. My next step is to test one more time before I waterproof the radio box, and install everything for the last time. |
02-04-2012, 07:17 PM | #98 |
I finished this thing up today it has gone from a roller to a nice crawler! I buttoned up the electrical box, and made a power cut out for my winch. I then ran all the wires and got everything plugged in. If your wondering about why I run a switch on my servo winch it's because I accidentally bumped the button on my Tx once and burned a winch. Since then I like to put a power switch so that when I lean down to use the winch I just flip the switch and power the winch up so If my big dumb fingers bump the control no harm no foul. Since it runs I went to my favorite little rock garden to give her a easy shake down I was only running 2S. I added rear steer only on my 4pl eventhough others don't like it. For me it is a fantastic addition. It flows very very well for me (then again I drive a forlkift that is rear steer all day soo...). On a side note I had this almost ready to go and decided to change my mind and go with the 3300Kv Tekin Pro 4, and MMP. I'm currently only running one BEC for the front and relying on the ESC bec to power the rear servo at 6v. The BRXL is native at 6v and I set my Castle MMP to 6v. I switched the motor and the ESC back in and plugged in everything and tested the systems to make sure everything worked smootly. With the MMP I browned out everything, the BEC wasn't up to the task. It was soo bad that when I put any stress on the rear servo it actually would cause the RX to shut down for a split second and I'd have to wait for the whole system to reconnect. The BRXL powers the system flawlessly. On 2S this Torquemaster is fun but being such a low turn it just isn't making my eyes bug out in the torque dept. It is awsome in the wheel speed, braking is fantastic, and it climbs nice but it bogged down just a little too much a few times for my taste. Looks like I'm ordering another BEC LOL. Last edited by WarTrader; 02-05-2012 at 09:58 AM. |
02-04-2012, 07:49 PM | #99 |
Wartrader that wraith and Jeep body came out Bad A$$ brother. |
02-04-2012, 08:06 PM | #100 |
RCC Addict Join Date: May 2010 Location: Midwest
Hell yeah! Very nice |
