12-22-2011, 02:07 PM | #1 |
Pebble Pounder Join Date: Jan 2010 Location: CA
| Caster on rear axle for 4WS setup
I was wondering how the caster should be set on the rear axle when doing 4WS? Should I try to get it at zero or should I clock the chubs to give a little castor? I am using stock chubs and knuckles
12-22-2011, 02:12 PM | #2 |
I run zero in the rear.
12-22-2011, 02:14 PM | #3 |
RCC Addict Join Date: Jan 2009 Location: Jacksonville Illinois
12-22-2011, 02:28 PM | #4 |
| Re: Caster on rear axle for 4WS setup
Yep, you want zero.
12-22-2011, 03:45 PM | #5 |
RCC Addict Join Date: Oct 2008 Location: Alpine,CA
I don't know about those guys above me, but i run Zero. |
12-22-2011, 07:27 PM | #6 |
Alright, zero it is! Thanks
12-22-2011, 09:48 PM | #7 |
RCC Addict Join Date: Sep 2011 Location: Peoria, AZ
Hey guys just finished my wraith tonight and I also added the 4WS and don't know exactly what you guys mean by zero caster on the rear axle, or is that for both axles. Can you guy please school me on this cause I'm lost. Harley thanks for the wiring diagram for the 4PL 4WS and the winch it worked just fine. Last edited by muddywaters; 12-22-2011 at 09:59 PM. |
12-23-2011, 06:14 AM | #8 |
Sometimes, I make things. Join Date: May 2009 Location: Mt. Upton
Zero Caster means the c hubs will be straight up and down, as opposed to the front having a positive (I think, can't recall how it works) caster with the top of the c hub leaning back towards the center of the rig and the bottom tipped towards the front. I have been wondering how the rear caster will effect performance, I plan to mess around with it on my rig. Right now it is at zero and its working nicely but want to try out some positive and negative to see if there is a sweet spot.
12-23-2011, 07:53 AM | #9 | |
| Re: Caster on rear axle for 4WS setup Quote:
12-23-2011, 09:51 AM | #10 |
| Re: Caster on rear axle for 4WS setup With you wraith sitting on a flat surface, you want the chubs straight up and down. The splines on the chubs are pretty coarse so moving it one spline moves it alot. On mine I could not get it perfect but it is close. If I move it one spline either way it gives me positive or negative caster. Sweet looking wraith!
12-29-2011, 10:16 AM | #11 | |
Thanks Psycho-Savvy, followed your instruction and got zero caster now for the rear 4WS. | |
Caster on rear axle for 4WS setup - Similar Threads | ||||
Rear caster?? | Chaotic Crawlers | Superclass Crawlers | 4 | 09-30-2011 06:53 AM |
4ws and rear axle angle? | mrklaw | Tamiya CR-01 | 2 | 08-02-2009 10:18 AM |
AX10 Rear Axle Setup | J71 | Newbie General | 5 | 02-06-2009 06:06 AM |
Question about front & rear caster on a custom rock-crawler with 4-wheel steering... | Chadworkz | General Crawlers | 6 | 11-22-2008 11:44 PM |
anyone else set up their front axle with some caster? | Slyp Dawg | Axial AX-10 Scorpion | 5 | 02-11-2008 10:54 AM |
