02-11-2012, 07:21 PM | #81 |
Quarry Creeper Join Date: Dec 2011 Location: Flat Hills of Florida
| Re: BONDO's WRAITH BUILD
Sure, If we can do 9K RPM neutral drops with your new Prius ?
03-02-2012, 07:30 AM | #82 |
New custom made Beadlocks and a new body in the works, guarenteed to be shiney Also, I broke a Axial universal. Snapped clean like it was cut with a hacksaw. Now running dogbones F&R, still steers great so fook it. |
03-03-2012, 09:29 AM | #83 |
These are the Golden Horizons Beadlocks I've had for a few months now, when purchased they were Anodized orange but after installing a different body the color wouldn't work anymore so I stripped the anode off. Now since thye looked a little plain I knocked out some holes and used a Uni-bit to give a 2 step looking hole. Also installed some Ultra Soft Venom "Switch backs" I found on Ebay for $3.70 a pair, all four delivered for under $12.00, what a bargin. But after trying to put them on the rims I had seen why. They were a bit to big and would easily pull out (another sexual enuendo) from under the beadlock ring ? So I cut and removed a section and glued the tire back together and they fit nice and tight, a quick test should prove they hold or not but I'm confident since they will. |
05-04-2012, 07:24 PM | #84 |
| Re: BONDO's WRAITH BUILD |
05-05-2012, 09:34 AM | #85 |
RCC Addict Join Date: Aug 2008 Location: Paulina
Bondo- it's nitrostarter from RCM. Killer build! Love the 4WS and all the hop ups! I'll definitely be getting a Wraith to build up soon.
05-05-2012, 04:34 PM | #86 | |
| Re: BONDO's WRAITH BUILD Quote:
Heres my most recent build still under construction, it's just a little more extreme than my Wraith LMK what you think, http://www.rccrawler.com/forum/large...ple-steer.html . | |
05-06-2012, 09:50 AM | #87 |
Quarry Creeper Join Date: Feb 2007 Location: Lleida
05-06-2012, 10:39 AM | #88 |
They are the standard 4mm banana plugs but I dremeled a slot so the wire could be soldered from the side.
07-04-2012, 06:37 PM | #89 |
07-04-2012, 09:28 PM | #90 |
Quarry Creeper Join Date: May 2012 Location: Houston
Sweet man, how you liking that Viper motor? I was thinking about one myself.
07-05-2012, 08:08 AM | #91 |
The Viper motor was very nice but since my rig is pretty heavy I opted for a Tekin SC4x 3000kv 550 motor to bump the power up a bit, it runs a little cooler due the larger rotor and more torque. For a wraith or any crawler that doesn't weigh as much as mine I'd highly recommend the Viper stuff. |
12-17-2012, 02:37 PM | #92 |
Quarry Creeper Join Date: Jan 2012 Location: Bloomington
Mind posting a vid of the 5.5t? |
01-30-2013, 03:06 PM | #93 |
I've ben testing these the last few weeks for RC4WD in my Ridgecrest and I assure you they are supper badd assed ! Ben trying to break them on 3s and Tekin 550 motor and couldn't do it, the are still smooth as butter and show little to no wear after 25 some odd packs. RC4WD XVD CVD RIDGECREST/WRAITH TESTING - YouTube RC4WD Extreme Duty XVD Axles for Axial Wraith |
BONDO's WRAITH BUILD - Similar Threads | ||||
First build..Mini Wraith | 671 Crawler | Losi Mini-Rock Crawler | 22 | 10-18-2012 07:18 PM |
My Wrecked Wraith build | TXJeeper1 | 2.2 Scale Rigs | 87 | 03-27-2012 11:45 AM |
Bondo's Creeper | bondo303 | Venom Creeper | 14 | 01-20-2012 08:55 PM |
my wraith build | Slap204 | Axial Wraith | 0 | 11-14-2011 10:47 AM |
Wraith build | pwrwgn2000 | 2.2 Scale Rigs | 2 | 10-17-2011 07:27 AM |
