01-03-2012, 10:26 PM | #1 |
Rock Stacker Join Date: Mar 2009 Location: frederick
| pinion gearing on RTR Wraith..............
i have a bone stock Wraith (for now). i was wondering how low i can go on pinion size?? I have a 14t in box. is that too low for the stock set-up?? i don't do alot of hi-speed driving, mostly crawling. thanks
01-04-2012, 05:38 PM | #2 |
Quarry Creeper Join Date: Dec 2011 Location: SW Arkansas
| Re: pinion gearing on RTR Wraith..............
I just installed a 14t on mine with a 87t spur. Stock 20t motor. The difference in power and torque is amazing.
01-07-2013, 04:08 PM | #3 |
Quarry Creeper Join Date: Jan 2013 Location: Julian, CA
Picked up a used Wraith today. Has some off sized gears on it now. 75/27. Going to pick up these gears tomorrow^^^
01-07-2013, 07:14 PM | #4 |
Newbie Join Date: Nov 2012 Location: Central Maine
I set mine up with 32 pitch gears, running 14/60 to start out with.
01-07-2013, 07:24 PM | #5 |
Rock Stacker Join Date: Dec 2012 Location: burlington
I plan on picking up a 87/14 this weekend if my 27T axial motor arrives. Sent from my DROID RAZR using Tapatalk 2 |
01-07-2013, 07:28 PM | #6 |
i couldnt find a 60tooth 32p online, what are you running
01-07-2013, 07:29 PM | #7 |
Explain pitch for me please?
01-07-2013, 07:33 PM | #8 |
Newbie Join Date: Nov 2012 Location: Hong Kong
I use 15T pinion, but I only do crawling. Here is my full technical modifications: Wraith - Battery moved to front, 88T spur, 15T pinion, 55T motor, front wheel weight 410g each, rear underdrive and dig system installed. You can see how it performs from the youtube link below: Crawling on the beach rock - Axial Honcho and Wraith - YouTube |
01-07-2013, 07:38 PM | #9 |
32 is more pitch then 48 and is stronger? i think
01-07-2013, 08:06 PM | #10 |
Rock Crawler Join Date: Oct 2009 Location: Michigan
| Re: pinion gearing on RTR Wraith.............. The Pitch on a 32 pitch gear is the size of the teeth. The 32 pitch gear has bigger teeth than a 48 pitch gear. The bigger teeth are stronger, but the larger teeth and the way they mesh make them louder and not as smooth as a set of 48 pitch gears. Running a stock Wraith trans geared correctly (for crawling 14/87) you will be fine with the 48 pitch, I also like to run a slipper clutch to help save my gears in a bind. Wraith is a mixed group......some like it fast, some crawl. If you like to go fast a brushless setup is the way to go, geared correctly and monitor your motor temps. Crawler guys/girls need to almost run and gear it like an AX10....small pinion big spur and over drive the front axle. |
01-08-2013, 06:37 PM | #11 |
I first started cutting gears on a gear hobber in 1977 and have hobbed.shaped and shaved gears for over 20 years.I do agree that the larger tooth of the gear will make more noise but most of the noise comes from the quality of the gears you buy. I'm sure almost all of the plastic gears are molded with very poor quality. A lot of the noise comes from the bad profile of the tooth and runout in the gear. Ive found if you set a little backlash on one side of the gear and you rotate it 180 degrees it will bind up or have way to much backlash. I'm also very surprised at the cost of the gears that are out there for this hobby. Makes me want to buy a used gear hobber and start cutting teeth again. It would be fun to cut gears other than 64,48and 32 pitch. I think of the different ratios I could come up with 42 and 36 pitch gears. Helical gears would be fun also as you would have more tooth contact with the same width of gear. If you have any more questions on gears just let me know |
01-08-2013, 07:28 PM | #12 | |
Quarry Creeper Join Date: Feb 2012 Location: AZ
| Re: pinion gearing on RTR Wraith.............. Quote:
01-08-2013, 07:49 PM | #13 |
Yes it would but you would have to worry about the side thrust of the helical gears. They would push in opposite directions so you would need a thrust washer or bearing to keep the friction down from the side thrust.Or run them on bearings at each end of the shaft. A lot of helical gear setups we did used a cupped shaft that ride on a ball on each end to offset the thrust of the gears.
01-09-2013, 08:47 AM | #14 |
| Re: pinion gearing on RTR Wraith.............. |
pinion gearing on RTR Wraith.............. - Similar Threads | ||||
Pinion gearing?? | kennyj | EnRoute Berg | 2 | 05-23-2010 07:44 PM |
Pinion gearing | general lee | Chit Chat | 13 | 01-28-2010 03:40 PM |
Gearing ratio: 18t pinion and 81t Spur with a 35T Tekin. Good or bad? | liftmys10 | Axial SCX-10 | 2 | 01-26-2010 10:41 AM |
Smallest Pinion / Lowest gearing w/ GD-600??? | EvilTwin v2 | Axial AX-10 Scorpion | 2 | 05-26-2008 06:50 PM |
Axial RTR Gearing Question | Tyson | Newbie General | 7 | 05-17-2008 09:42 PM |
