Thread: Kyle's Unemployment Wraith
Old 02-28-2012, 08:49 AM   #101
DRN
Default Re: Kyle's Unemployment Wraith
what size are your SLW rims?
DRN is offline   Reply With Quote
Old 02-28-2012, 09:33 AM   #102
Originally Posted by lostinkorea View Post
Sick Wraith brother,
Had a couple questions, where did you get the small hinges you did the hood with? Second, where are your Electronics mounted now that you have the TCS toolbox in the back?
Thanks,
LIK
Thanks for the props man
tower hobbies has them there dubro small nylon hinges cat# 119
That's not a TCS box it's a RadioShack 2x3 electronics box with scale diamond plate cover I bent and made. Very easy to do I must say. It has my MMP in it and the stock axial radio box has the lighting,receiver, and BEC in it tight fit everything has been sealed with RTV.
bagged86 is offline   Reply With Quote
Old 02-28-2012, 09:42 AM   #103
Originally Posted by muddywaters View Post
Looks awesome Kyle,. What did you use to mount the winch and extend the bumper more forward. I also have that Jeep body coming soon can't wait to get it and come up with a color scheam.
I bought the CKRC mount but of course it didn't work with my setup so I bought a sheet of .030 Lexan and made another mount and painted it black. If you want to just buy the ckrc mount and trace the front and make your own. As far as the extending the bumper out I used aluminum rod and cut them 1/2" long and drilled the center out the use longer bolts. I will buy another body later and do a crazy paint job lol. Hope this helps
Old 02-28-2012, 09:44 AM   #104
2.2 1" wide with 475 hubs
Old 02-28-2012, 10:47 AM   #105
Cool I'll look into that, tracing out the CKRC mount and make it out a a sheet of aluminum.
muddywaters is offline   Reply With Quote
Old 02-28-2012, 01:42 PM   #106
that'll work the lexan is pretty strong though.
I wish I had the time to make a bumper with a winch mount,lights and the extentions needed with the cms kit out of tubing.
Old 02-28-2012, 01:45 PM   #107
made my plates to set the cooler up where i wanted to and made a rag top probably changed to gray though
Old 02-28-2012, 01:45 PM   #108
Old 02-28-2012, 04:18 PM   #109
Beautiful and badass at the same time bro, love it. Thanks for the info!
LIK
OFFROADRCKOREA is offline   Reply With Quote
Old 02-28-2012, 05:08 PM   #110
are those tires better than the stockers because i want to find a good tire
RcBashertruck is offline   Reply With Quote
Old 02-28-2012, 05:58 PM   #111
DRN
Awesome thanks man.
Old 02-28-2012, 06:09 PM   #112
Kyle what hardware are you using for the Hinges, I have a set of hinges coming in but it did not come with the hardware. I also like the HighLift Jack I just ordered one yesterday also 1/10 scale.
Old 02-28-2012, 07:18 PM   #113
I wouldn't know about the stock tires I built this bolt by bolt
But I will say after I cut these they really started working amazingly.
Old 02-28-2012, 07:21 PM   #114
2mm buttons screws with nylon locknuts I got them from the stock 1/18 losi pro chassis after getting my mini juice chassis. they seem to be the right size.
Old 02-28-2012, 07:23 PM   #115
Muddy water placement is key on the jack I almost broke mine in half last time out lol
Old 02-29-2012, 09:02 PM   #116
bagged86,
Thanks for the info and the tip on the Highlift Jack. I'm searching on the 2mm button screws with lock nuts.
Old 03-02-2012, 09:06 PM   #117
Awesome Wraith Kyle!!
I have a couple of questions.
Who makes the output shafts your using on your transmission?
Where did you get the scale diamond sheet you used to cover your radio box?
Thanks
MarkG35 is offline   Reply With Quote
Old 03-03-2012, 07:03 PM   #118
Thanks
Thanks man
Crawler innovations makes them very tough to tear them up highly recommended
I got the scale diamond plate from CKRC it comes with two 9x11 sheets you can cut it with scissors like paper very easy to work with.
Old 03-03-2012, 07:09 PM   #119
Well a trip to two Best Buys and thinking I would get just the GoPro hero and left with the more expensive GoPro Hero 2 and then headed to Sports Authority to pick up the BacPac LCD screen. RadioShack because we were at the mall and got mini HDMI cable to watch it on the big screen. Now where did I leave my 400 dollars oh yeah at the service counter along with the frown on my wife giving me the look LOL
Old 03-04-2012, 09:22 AM   #120
We are GoPro for launch
Kyle's Unemployment Wraith - Similar Threads
Kyle's LN/CC bluice Team Losi Comp Crawler 52 06-08-2011 12:23 PM
kyle's plan old jeep herman712 2.2 Scale Rigs 3 01-21-2011 08:03 AM
Who's enjoying Unemployment? stubs179 Chit Chat 35 02-16-2010 02:57 PM
