01-09-2012, 02:07 PM | #1 |
Newbie Join Date: Dec 2011 Location: Sacramento
| Help with drag link and tie rod.
So I got these from VP couple weeks ago and having issues with the alignment. I can get it to go straight and it seems like the front tires are off caster(think that is the word. The driver wheel looks like it is tilted inward). I thought I measured right and it still wants to pull to the left. What am I doing wrong. Any advice!?! Help?!? Thx in advance. 07trd4x4 |
01-09-2012, 03:11 PM | #2 |
| Re: Help with drag link and tie rod.
add a spacer on one or both sides of the drag link to center it.
01-09-2012, 04:23 PM | #3 |
Rock Crawler Join Date: Jun 2010 Location: UTAH COUNTY
Make sure both of you c hubs are aligned the same. Did you set your trim on your tx?
01-09-2012, 05:35 PM | #4 |
01-09-2012, 05:37 PM | #5 |
01-09-2012, 05:44 PM | #6 | |
Quarry Creeper Join Date: Dec 2011 Location: Huntington Beach
| Re: Help with drag link and tie rod. Quote:
This may or may not be of help. When I first got my VP tie rod and drag link installed I could not get it to track straight. I am new to RC and the Radio did not come with any instructions. I did not know there was a steering trim knob on the radio. But once I discovered it, labled ST-Trim under the flip up cover, I was able to center the steering and servo horn at will. | |
01-09-2012, 06:02 PM | #7 | |
Thanks for the input I did figure that out and it is annoying ( I am OCD) that the trim is not in the center. Completely clockwise. ;) Last edited by 07trd4x4; 01-09-2012 at 06:07 PM. | |
01-09-2012, 07:48 PM | #8 |
Rock Stacker Join Date: Dec 2011 Location: Virginia
| Re: Help with drag link and tie rod. I dont think they are ever in the center. None of my RC`s are ever in the center no matter what.When i got my VP i did end up taking them back off a few times to center everything. It still doesnt look center when you look at them but it tracks straight with very little steering trim, so it`s all good for me |
01-09-2012, 08:14 PM | #9 |
Quarry Creeper Join Date: Jul 2009 Location: SW Hell
Good to know, I just ordered mine...pheww...
01-09-2012, 08:17 PM | #10 |
Newbie Join Date: Dec 2011 Location: WA
If you have the stock wheels I'm guessing that the draglink rod end on the knuckle is binding inside the wheel. Mine did and I had to play with it until it fit inside the wheel.
01-09-2012, 11:48 PM | #11 | |
I will have to try it tomorrow. Thx!! | |
01-10-2012, 10:58 PM | #12 |
Rock Crawler Join Date: Nov 2007 Location: Bay Area (RWC)
I ordered there kit and had a huge toe in problem. So I called VP and they sent me a new Tie Rod. Said something like I must of got there archerman tie rod by mistake. So I installed the new tie rod and its allot better, but I still see some toe in. I also noticed the rim rubbing on the drag link rod end so I lightly trimmed the rod end with the Dremel, just a tad and it fixed it. But I still wonder if I got something wrong as I dont think VP would require you do this. I also tried rotating my C-Hubs one notch forward and that didnt help. So I may call VP again and ask. |
01-10-2012, 11:20 PM | #13 |
Mine isn't that bad. Man that is way off.
01-10-2012, 11:21 PM | #14 |
Hear I thought I was the only one with this problem. Thanks all for advice.
01-11-2012, 07:58 AM | #15 | |
Rock Crawler Join Date: Nov 2009 Location: Commiskey
With the wheels not pointing strait, try running the stock ackerman arms or add a small spacer on the tie rod, drivers side end, between the rod end and tie rod itself. | |
01-11-2012, 11:24 AM | #16 |
Looking at mine this morning after reading this comments. Sorry about the cell picture hope you all can see And when I adjust the rod it starts to bow inn |
01-11-2012, 02:59 PM | #17 | |
Ahh I didnt even think about the stock arms. Good idea. Thanks. I will try that. I got the tie rod issue pretty much fixed. The picture was before I did a Nip/Tuck.. I left a message with VP. While at VP's site I was looking at there tie rod picture and I see there C-Hubs are clocked all the way forward and it looks like there's some toe it too.. | |
01-12-2012, 02:13 AM | #18 | |
Put the stock arms on and swapped the hex's for some Traxxas ones that are 1/8" thicker, problem solved. My c hubs are not clocked either way but in the center. | |
01-12-2012, 09:59 AM | #19 |
I just emailed VP through their tie rod problem thread and it looks like the knuckle arms on my vp knucks may be the problem I have a new set on the way. I'll post up when I get them and let you guys know if it fixes the issue without any modification.
01-12-2012, 04:28 PM | #20 |
Thanks!!!!
Help with drag link and tie rod. - Similar Threads | ||||
new vanquish tie rod and drag link | bighemitex | Axial Wraith | 21 | 10-23-2011 05:56 PM |
HELP on Vanquish Tie Rod & Drag Link | Jordan714 | Axial Wraith | 4 | 09-06-2011 07:45 PM |
Double drag link no tie rod? | day215 | General Crawlers | 10 | 07-02-2011 09:11 PM |
KK high clearance tie-rod vs. CKRC OTA tie-rod vs. ?? | BigB_117 | EnRoute Berg | 64 | 07-06-2009 11:20 PM |
Tie Rod/Drag Link Setup? | Hyperlite33 | Axial AX-10 Scorpion | 4 | 06-24-2008 03:58 PM |
