Wide wheels for my wraith I' ve bought a wraith a month ago, It is a rtr version, but I've started to equip it a lil bit. I would like on it wheels wider, but in 2.2 I've found nothing, in 3.2, there is a problem, wheels are 14 or 17mm hex, so, I can't put them on my wraith. I think 2.8 wheels should be a good choice, does anybody test a wraith with wide wheels? |
What overall width are you looking for? |
Re: Wide wheels for my wraith Quote:
Re: Wide wheels for my wraith axial 8holes work great for making it wider. |
These wheel are 4.0 wheel no? Do you have a link to see these wheels? |
Re: Wide wheels for my wraith http://www.rccrawler.com/forum/axial...-new-pics.html That is my rig with axial 2.2 wheels. |
Re: Wide wheels for my wraith You could put 17mm hex head adapters on and run bigger wheels that way if you wanted. |
Re: Wide wheels for my wraith I put on 17mm adapters and put on 3.8 tires and wheels from a Summit |
These are the only ones that popped up with a Google search. ST Racing 14 mm Clamp Wheel Hex Adapter Blue (SPTST3654-14B) | RC Planet at first I thought just use 14mm hexes from a T-Maxx untill I read this 12mm to 14mm hex wheel adapter DrHonda? Would take some wok since pin and axle are different sizes. |
I've been thinking of going 2.8 Lemar, you can also get them at RC4WD - The Ultimate RC Products |
