Servo recomendations Hey wraith owners in your experienced opinions what would be the best high torque/some speed servo. Also on Hitec servos like the 7990 and the 7980 would they fit on the vanquish chassis servo mount or ever the regular mounts with 4ws |
Re: Servo recomendations This is one of the most widely asked questions. I see your quite new, a small tip , if your clearly not attempting a search no one will answer your questions. |
Re: Servo recomendations A lot has to do with how much you have to spend. With the tall tires of the Wraith you need a high torque servo with up to 300 oz. of torque or as close to that as you can get. Harley has a great break down on all recomendations for upgrading your Wraith. Hitech 7955, Hitech 7954SH, Savox SC-1256TG, Futaba S9351, hope some of these help. Also keep in mind when upgrading the servo, its not a bad idea to upgrade the steering links to a stonger aluminum setup. And by the way try not to worry about sarcasm from know it alls. "thumbsup" |
Re: Servo recomendations Quote:
And add a BEC helps when adding a high torque servo is a good idea also. |
Re: Servo recomendations no the 7980 and 7990 will not fit the vanquish mount as it is only wide enough for your standard size servos. radiopost makes some really nice servos and they are low profile the red cased one has alot of torque RADIOPOST Sync Differently |
