01-26-2012, 01:54 PM | #1 |
Newbie Join Date: Dec 2011 Location: Jacksonville , FL / Gatlinburg , TN
| HH Torquemaster Pro
I just ordered the Holmes Hobbies Torquemaster Pro 27 turn 5mm webbing . I was gonna get the 35 turn but wanted a little more wheel speed if needed . I'm gonna be doing some low speed crawling and hill climbing and wanted to know what would be a good gear ratio to run with this motor . I ordered an 87 tooth spur and 14&16 tooth pinion to get started . Dont wanna burn the motor up in the rocks . Also is it alright to run this motor with my stock AE-2 ?
01-26-2012, 02:11 PM | #2 |
This is pretty well covered in the motor and ESC thread. Read it. Gearing will be ok. An 84 may be better.
01-26-2012, 03:00 PM | #3 |
| Re: HH Torquemaster Pro
Thanks Harley . Also what kind of spur gears can i run . I'm keeping it 48 pitch right now . Didnt know if i had to use only spur gears for axial or what . Dont know if there's a certain hole pattern . |
01-26-2012, 04:19 PM | #4 |
Rock Stacker Join Date: Dec 2011 Location: Virginia
Been waiting on my HH motor for almost 3 weeks now Good Luck
01-26-2012, 04:21 PM | #5 |
01-26-2012, 04:28 PM | #6 |
He just emailed me Harley Said he had some other winds as well as a full selection of Torquemasters in stock. I ordered the same one in your build thread,so i may look at the TQ`s, what do you think? Sorry to the OP, not trying to highjack your thread
01-26-2012, 05:03 PM | #7 |
Gears ?
01-26-2012, 07:35 PM | #8 |
| 27t is a good equivalent.
01-26-2012, 07:35 PM | #9 |
01-26-2012, 08:47 PM | #10 |
I'm sorry , I have read post 2 and most of your post on here over and over Harley and really appreciate everything you post on here but I just can not find the answer . If you could please just let me know it would be greatly appreciated . Just need to know if I need to use axial specific spur gears . For example would it be a Robinson for Axial ?
01-26-2012, 08:50 PM | #11 | |
HH Torquemaster Pro - Similar Threads | ||||
Holmes Torquemaster Pro should come with a warning! | YYCADM | Electronics | 22 | 11-13-2011 04:06 PM |
R1 w/ HH TorqueMaster Pro 540 Handwound | nafie | Electronics | 2 | 07-16-2011 10:12 AM |
MM Pro vs HH Torquemaster | BEELZEBOB | Electronics | 5 | 11-09-2009 02:33 PM |
Holmes Hobbies TorqueMaster P-94 Pro Handwound | JohnRobHolmes | Holmes Hobbies | 79 | 03-19-2009 07:29 PM |
