02-01-2012, 11:55 AM | #1 |
Newbie Join Date: Oct 2004 Location: YANKTON,SD
| Did me esc fry?
My wraith has been acting up lately. Things like going from forward to reverse and it coasts until you let off the trigger and reapply. Other times when I first turn it on and pull the trigger it would lurch forward and quit, then I would have to turn both the truck and the control off to get it to work. Now last night i turned it on and the lights on the truck were flickering fast, then they went out, so I turned off and on and still nothing. I tried a different battery with same results, nothing. I have been playing in the snow alot lately so I thought maybe something got wet, I pulled the rx box apart and everything appears dry. Any ideas on what is going on. ESC, or the power switch, ???? Thanks Bryan |
02-01-2012, 11:56 AM | #2 |
| Re: Did me esc fry?
I just reread my subject line. Nice!!!
02-01-2012, 02:39 PM | #3 |
Rock Stacker Join Date: Jan 2012 Location: Canada
| Re: Did me esc fry?
Similar problems. Driving fine, then coasts and beeps continuously. No response to throttle or steering unless powered off (ESC switch or battery plug). Works again for a bit, then the same thing regardless of battery. Electrics stock with exception of HiTec servo (7954). Real bummer. I've ordered a BEC to try wiring the receiver and servo separate from the ESC. My theory right now is the ESC integrated BEC is becoming overwhelmed and buggering things up. Have no clue if this is the problem or not, but it is the lowest cost start. The Holmes Hobbies ESC and motor I would swap out to try are out of stock. |
02-01-2012, 03:26 PM | #4 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
| Re: Did me esc fry?
Willeh I had the same problem, put a bec on it and it fixed my problem. I wired the esc the way it was shown in the instructions. (castle BEC)
02-01-2012, 03:32 PM | #5 | |
| Re: Did me esc fry? Quote:
Awesome news, thanks for the info! I'm picking up the parts on Saturday. Will report my findings. Sorry if I hijacked your thread derbinator. | |
02-01-2012, 05:11 PM | #6 |
Quarry Creeper Join Date: Oct 2011 Location: Georgetown, On
| Re: Did me esc fry?
sounds like your esc is in lipo cut off mode.
02-01-2012, 05:41 PM | #7 | |
I am using nimh batteries so not sure if my esc would go into lipo cut off mode, if this is a real mode, or how to fix it. | |
02-01-2012, 07:06 PM | #8 | |
I installed the HiTec servo around the same time and it ran fine and then would just quit as described in the earlier post. I think if you follow the directions here you can turn off the Lipo Cutoff manually without the Castle link. Providing the ESC still powers up. | |
02-02-2012, 07:31 AM | #9 |
| Re: Did me esc fry?
Ya that would be the problem, it won't power up. Is there a chance it as simple as the on-off switch? Can I send the esc in to have repaired?
02-04-2012, 01:58 PM | #10 |
| Re: Did me esc fry?
Installed the BEC and changed the battery plugs to Deans... No love, still drives fine and then all of a sudden non responsive & beeping. What are the odds that the Receiver is the problem vs the ESC? Also a stupid question, but would any other radio signals interfere with it? Ie Cordless phone or wifi?
02-05-2012, 11:18 AM | #11 | |
Sounds like it is cooked. Everyone seems to say that the Axial customer service is great, maybe try giving them a call and seeing if they warranty it. I bought mine second hand so I'm kinda on my own. | |
05-28-2012, 08:11 PM | #12 |
Rock Stacker Join Date: Feb 2012 Location: Flinthills
| Re: Did me esc fry?
I'm having the same problems. Did you come up with a solution? I'm thinking it is the esc, but not sure.
06-03-2012, 07:46 PM | #13 |
Newbie Join Date: Sep 2011 Location: pikeville
| Re: Did me esc fry?
hey my receiver did the same thing, i changed the esc thinking that was the issue and then come to find out it was the rec, anyway a good way to know if it is a rec issue is if you have any steering
06-08-2012, 05:03 PM | #14 |
Newbie Join Date: Dec 2008 Location: In da desert
| Re: Did me esc fry?
Mine will act like it's out of range sometimes when I've used others at the same or greater range. It also is cranky at first power on sometimes and will only respond to steering inputs but not throttle. I'm wondering what the deal is...
06-08-2012, 05:15 PM | #15 |
RCC Addict Join Date: Feb 2012 Location: UK
| Re: Did me esc fry?
Are you using LiPo? Mine was cured by using a BEC too.
06-09-2012, 12:05 AM | #16 |
Rock Stacker Join Date: May 2012 Location: Tacoma
| Re: Did me esc fry?
Mine was was working then the steering went to right turn and stayed, then started working again , then forward and reverce quit , finally changed the TX & RX everything is good again . I contacted AXIAL and I`m getting ready to send mine in ,I`ll see how long that takes . If you call the number in the manual they will give you the 800 # for the new company that is handling there warranty stuff . If i remember it tomarrow I`ll post it .
Did me esc fry? - Similar Threads | ||||
Did I fry my rx or ??? | scoobydann | Electronics | 12 | 08-08-2010 03:19 PM |
Did I just fry my LNC ESC? | shelljeep | Newbie General | 24 | 02-09-2010 10:46 PM |
Will a 3s lipo fry my xl-5 esc? | jbrentd | Non Crawler RC's | 4 | 08-20-2008 12:51 PM |
Did I fry it | mudboger07 | Newbie General | 5 | 02-05-2008 07:54 AM |
Please help, I don't want to fry anything... | WRMorrison | Electronics | 18 | 12-31-2004 05:50 PM |
