Thread: threaded inserts
Old 02-07-2012, 10:28 PM   #1
Default threaded inserts
Has anyone put brass threaded inserts on the wraith axles like the guys did on xr10s? I searched and did not find anything. But to me metal on metal threads always felt better and for a cheaper upgrade over full metal axle cases. seems like a good idea to me. Just wanted to see what other were thinking.
doublej is offline   Reply With Quote
Old 02-07-2012, 11:04 PM   #2
Default Re: threaded inserts
i suppose it would make em super strong.
joelKID984 is offline   Reply With Quote
Old 02-08-2012, 12:28 AM   #3
The axle case is a one piece design, so there are not really any places to add the inserts on it. The wall thickness of the plastic is too thin to use them in the upper link mounts holes.
The deal with the XR is it adds clamping force to the top and bottom axle case halfs, and the upper link mounts.
4xFord is offline   Reply With Quote
Old 02-08-2012, 01:38 AM   #4
i know its not needed like on the xr10s but for the diff cover and bearing supports it would be nice.
Old 02-08-2012, 02:07 AM   #5
The diff cover uses 2mm harware, and doesn't see any load. The bearing carriers would be nice to do, but IIRC there isn't enough material for the insert there.
threaded inserts - Similar Threads
DIY Beadlock Threaded Inserts Altered-Images Losi Mini-Rock Crawler 9 02-16-2009 03:11 PM
New Tire Inserts Available Now!!! kreepykrawler Tires and Wheels 1 06-09-2007 11:35 AM
Inserts? lvl1 Tamiya Clod Buster 2 11-13-2005 02:10 PM
Krock inserts or no inserts sportracer Tires and Wheels 1 10-19-2005 12:27 AM
inserts firstumustcrawl General Crawlers 0 03-06-2004 06:11 PM
