02-22-2012, 05:51 PM | #1 |
Quarry Creeper Join Date: Nov 2011 Location: San Diego
| Chassis hitting servo horn?
I am running a Savox 1256TG servo in my Wraith kit and when I try to fully compress my wraith the back of the front bumper hits my servo horn so it is not able to compress all the way. Is this the case on all wraiths?
02-22-2012, 06:06 PM | #2 |
Rock Crawler Join Date: Jan 2007 Location: Northern Wyoming
| Re: Chassis hitting servo horn?
Mine did. I used a round bastard to clearance the bumper where the arm screw hit and all is good.
02-22-2012, 06:08 PM | #3 |
Pebble Pounder Join Date: Nov 2011 Location: Oregon City
Mine does this too. Bugs the crap out of me! I think its time for a custom front bumper |
02-24-2012, 03:47 PM | #4 |
Newbie Join Date: Jun 2008 Location: city of smile
i made a servo mount similar to stock but wider (axle truss mounting holes will be farther with the servo mounting holes), this will make the servo move backwards and clear up some space for the servo to move freely.
02-24-2012, 03:58 PM | #5 |
I wanna be Dave Join Date: Feb 2011 Location: Atlanta, GA
I added some spacers between the bumper and bumper arms...solves the problem. Add just enough to clear the servo horn. You can use anything from shock spacers and plastic from Axial trees.
02-24-2012, 05:56 PM | #6 |
I drilled and countersunk new holes in front of the stock holes on the servo plate to move the servo and drag link back a little behind the tie rod. Gotta flip the servo so the horn clears the diff cover and use a longer drag link, an AX-10 upper link fits perfect.
02-24-2012, 06:26 PM | #7 |
Mine is clearing fine...just like my Honcho.
02-24-2012, 07:17 PM | #8 |
Quarry Creeper Join Date: Dec 2011 Location: Huntington Beach
| Re: Chassis hitting servo horn? My servo arm was hitting the front bumper as well after I started using a Racers Edge aluminum clamp on arm which is a bit thicker than the stock plastic arms. To fix it I just got out the dremel and a half-round file to make room for the horn and screw.
02-24-2012, 08:15 PM | #9 |
Quarry Creeper Join Date: Jul 2009 Location: Long Island
i just made a new servo plate and moved it back 1/8th"
02-24-2012, 11:37 PM | #10 |
Rock Stacker Join Date: Jan 2008 Location: Auburn, CA
file the bumper down where the horn hits. takes 3 min and works. just did it to mine
02-25-2012, 11:58 AM | #11 |
Maybe its a kit vs RTR differance? they give you some different rod choices so maybe I spaced the front axle more foreward than normal.
02-25-2012, 04:09 PM | #12 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
There's 3 different sizes of mounting brackets in the kit. Not sure about the RTR version. I just used the shorter (not so deep) one. |
Chassis hitting servo horn? - Similar Threads | ||||
OK, need a bit of help with the honcho, servo hitting crossmember | Slowkrawl | Axial SCX-10 | 17 | 03-06-2010 09:05 AM |
Servo horn hitting crossmember on Honcho? Fix it! | generalee7 | Axial SCX-10 | 16 | 01-27-2010 06:41 AM |
Servo hitting my shocks. | DaSamurai | 1.9 Scale Rigs | 1 | 09-20-2009 06:03 PM |
