Thread: my new wraith (progression)
Old 02-27-2012, 06:00 PM   #21
Default Re: my new wraith
Got a 35t motor. What tooth pinion should I use? I was using an 18 tooth with my 55t and it got way way to hot.
crawler nut is offline   Reply With Quote
Old 02-28-2012, 03:52 AM   #22
here's some pics of the tail lights. wanted to go with round ones but couldn't find any right off the bat so i just used the stock ones.
Old 02-28-2012, 06:07 AM   #23
been thinking of a rear deck cover. got a piece of cardboard cut to size. may make a change or 2.
Old 02-29-2012, 03:56 AM   #24
made my lexan rear deck cover and had some left over so i attempted a windshield. but it didnt come out to good. i didnt like the windshield kit because it was held on by zip ties.
Old 02-29-2012, 04:04 AM   #25
we had our first snow of the year here where i live so i got to test it out. this thing does awesome in the snow. even with the stock tires, but the weighted ones did a lot better.
Old 02-29-2012, 06:38 AM   #26
i used 2 of the body panel screws to mount the rear and i was going to hing the front so i didnt have to undo a crap load of screws to get to the battery. all it needs is 1 screw on each side right by the upright to hold the corners down. good idea or stupid?
Old 03-01-2012, 03:13 AM   #27
i havent done a whole lot of work with lexan before. i want to redo my windshield. what is the best way to heat and bend it?
Old 03-01-2012, 04:35 AM   #28
took it to the rocks and the snow again today. this is one of the funnest crawlers ive ever had.
cliff hanger
Old 03-01-2012, 08:55 AM   #29
Wraith looks good.
JustinM is offline   Reply With Quote
Old 03-01-2012, 09:18 AM   #30
Originally Posted by JustinM View Post
Wraith looks good.
thanks. this thing is a blast to work on and even more fun to drive
Old 03-01-2012, 01:19 PM   #31
Yes its is Waiting on the mail so i can get my parts
Old 03-01-2012, 02:47 PM   #32
Every time I look at it I think of what I can change next. It wheels killer even with the 4200mah battery still in the rear. Also I broke the front bumper yesterday, right at the top 2 mounts.
Old 03-03-2012, 12:36 PM   #33
my motor works great and doesnt get hot at all with the 2s. with the 3s it got hot pretty quick. should i go from a 16t to a 13t pinion or something like that? also painted my deck lid and made a lexan piece for the bottom of the battery tray to make it solid. i also made my deck lid to open like a hood for easy access to what ever is in there, battery elecrtonics, etc.
Old 03-06-2012, 03:37 AM   #34
i decided to upgrade to some aluminum shocks. i had a set of the integy long aluminum shocks laying around that were for my ax10. im just going to use them until i buy something shorter. i used the stock wraith shock springs on them to keep it low to the ground.
it made it the same length as a stock shock at ride height
these shocks have way to much travel. i put some old spacers on the shafts to limit the shocks
Old 03-06-2012, 04:55 AM   #35
Originally Posted by crawler nut View Post
just went and checked it out. first it came up with nothing but then i found it. it looks the set comes with all 3 gears and its only $28.99. the stock axial trannys always make me a bit nervous.
Searched all over the RCC site and could not find this gear set! Could you please post the part numbers! Thanks!
Chunks is offline   Reply With Quote
Old 03-06-2012, 05:54 AM   #36
on CKRC there is a set of all 3 gears for $27.99. model#SSCP1000T
rrp is a much higher quality and the 2 gears are only $5 more total than CKRC. RRP part#1551 is the idler gear $14.95, 1552 is the lower diff gear $19.95
Old 03-06-2012, 06:59 AM   #37
here are a few pics of the shocks on the rig.
gained quite a bit of flex. think im going to have to put a longer spacer in the shocks
Old 03-06-2012, 07:00 AM   #38
it makes my ax10 look like a 1/16th scale
Old 03-06-2012, 07:11 AM   #39
Great sites! Much Thanks for the info! CKRC is one site I never even heard of before! Both added to my favorites list!
Old 03-06-2012, 07:23 AM   #40
id personally go with robinsons for the gears. much better quality and machine work
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-wraith/367932-my-new-wraith-progression.html
Posted By For Type Date
axial link piece This thread Refback 03-06-2013 06:50 PM
my new wraith (progression) - Similar Threads
Wraith Skins for m_energy's Wife's Wraith Krawler Konceptz Paint and Body 2 10-18-2011 11:29 AM
