Thread: my new wraith (progression)
Old 04-22-2012, 12:07 PM   #81
Default Re: my new wraith
i got the baja claws for a decent price. when i get another set of wheels ill be ordering a set or the iroks for sure.
crawler nut is offline   Reply With Quote
Old 04-24-2012, 05:21 AM   #82
im working on narrowing a set of stock axial beadlocks to mount the baja claws on. i'm going to shoot for the 3/4-1" wide wheel and hopefully ot will be narrow enough. we'll see what happens. may just have to order a set of the wheels i origionally wanted.
Old 04-24-2012, 02:22 PM   #83
Default Re: my new wraith (progression)
Okay...total noob question here, but how did you mount your receiver box and stock ESC in the back?
Sh0rtBus is offline   Reply With Quote
Old 04-24-2012, 02:25 PM   #84
The wires were a bit tight but they worked with a bit of re routing. I used a piece of .040 lexan as a solid base over the existing tray then just used double sticky tape to hold everything down
Old 04-24-2012, 02:26 PM   #85
Doing it again I'd run the rx in front of the esc though. Everythimg will have plenty of slack
Old 04-25-2012, 06:09 AM   #86
The only thing on mine that looked like I wouldn't have enough slack was the signal wire from the servo. So I extended probably 6 inches and now I can put the rx box pretty much anywhere I want.
Old 04-25-2012, 06:13 AM   #87
yeah i extended mine as well. but my light wires were almost to short. i was barely able to put the led control in the box.
Old 04-25-2012, 06:18 AM   #88
May have to get a sheet of lexan at my LHS when I grab my 32p 10T pinion later today. Maybe I can make a battery tray for the front, too.
Old 04-25-2012, 06:22 AM   #89
yeah that would be nice but i bought a nice battery to fit right on the old rx box mount. it works perfect
Old 04-25-2012, 06:28 AM   #90
Don't think I'm going to find a 5000mah 2s to fit there, though. Besides....I want the weight up front.
Old 04-25-2012, 06:35 AM   #91
mine is a 3300 its a 2s2p. but the 5000mah weight would be nice
Old 04-25-2012, 12:10 PM   #92
Okay, so I'm disappointed in my LHS. They didn't have the pinion I wanted, nor do they keep them in stock. Guess I'll have to order one online.
Old 04-25-2012, 02:38 PM   #93
That's lame. A hobby shop without pinion selection. What the crap? Mine has all sorts of pinions. He even got me hooked up with an mmp for $109 and change after taxes. Not to bad if you ask me
Old 04-28-2012, 01:05 PM   #94
got my baja claws in the mail yesterday, and man are they big. im going to be grooving them soon but here is how they look on the wraith. this will be the last thing done for a while as i have another project. anyways i can't wait to see how they work, but im sure they'll work better when i get around to grooving them.
next to the ripsaws
Old 04-29-2012, 10:14 AM   #95
so i got to try out my new baja claws yesterday. for the terrain and type of rocks i have around here to wheel on they are working great so far. they hook up really well, but i still want to groove them up.
Old 04-29-2012, 10:50 AM   #96
If you grove them they will work even better. Take the large lugs and cut it into three small lugs then the smaller lugs in half. I have mounted mine backwards they seem to grab ledges and pull the vehicle up. Where i live we have alot of lava rock and they work great.
k goodrich is offline   Reply With Quote
Old 04-29-2012, 10:58 AM   #97
i have my fronts mounted backwards and my rears mounted normal.
Old 05-06-2012, 09:57 AM   #98
i bought a used but new to me radio for 4ws last week, and it finally showed up. now i just nee to get another pair of c-hubs, knuckles and another vp tie rod and drag link. not the best but for the price i couldnt pass it up. $50 for tx/rx
Old 05-10-2012, 06:23 AM   #99
just went front the HH 25t to a HH 27t torque master expert. not a ton of difference, just wanted the 25t for a new build. i know now that i will never buy another motor as long as john is in business. these are the best of the best brushed motors IMO.
Old 05-10-2012, 01:52 PM   #100
I was going brushless but now I'm going to try out that HH25t..How do you like it?
JustinM is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-wraith/367932-my-new-wraith-progression.html
Posted By For Type Date
axial link piece This thread Refback 03-06-2013 06:50 PM
my new wraith (progression) - Similar Threads
Wraith Skins for m_energy's Wife's Wraith Krawler Konceptz Paint and Body 2 10-18-2011 11:29 AM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
