02-25-2012, 10:01 AM | #1 |
Rock Crawler Join Date: May 2011 Location: Cali/Korea
| MMP ESC keeps rolling backwards on hills
Hey guys, I am running a Mamba max pro and 17.5 Novak Ballistic motor with no sensor wire on a 2s lipo. When going into reverse it always takes a bit to get in going in reverse, it takes a second after forward is what im saying. It also on the rocks at any incline just reverses and keeps rolling and I have no control until it decided to stop. After stopping I can continue moving forward but not until it stops moving completely. How can I fix this? thanks, LIK |
02-25-2012, 10:57 AM | #2 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
| Re: MMP ESC keeps rolling backwards on hills
Do you have castle link?
02-25-2012, 02:52 PM | #3 |
Newbie Join Date: Jan 2012 Location: USA
if its anything like my Castle SCT you will need to either get a castle link or read up in the guide on how to program it using the series of beeps. You should be able to adjust the drag brake. It sounds like you are using the FWD/BRAKE/REV with REV lock out feature which can be turned off. though by the way you describe it are you sure you dont have it setup backwards. you should have a green light on the MPP when moving forwards. you can also setup the delay between FWD/Brake/REV |
02-25-2012, 03:24 PM | #4 |
Use a sensor wire and set it up for crawler reverse along with some drag brake. Sensorless is best for go fast rigs
MMP ESC keeps rolling backwards on hills - Similar Threads | ||||
Castle MMP (MOA) ESC Settings. | Jcdelcarmen | Team Losi Comp Crawler | 4 | 12-08-2011 12:25 PM |
Tekin T8 (truggy) 2000KV Which ESC, MMP or RX8 | Agama | Electronics | 12 | 06-06-2011 12:33 PM |
