03-01-2012, 11:51 AM | #1 |
Quarry Creeper Join Date: Feb 2012 Location: AZ
| Just getting started
About six years ago, when I was living in CA, I got into comp crawlers and did very well in the local comps. I moved to AZ in 07 and sold off everything for some extra cash to buy dirt bikes for myself and my two sons. Fast forward five years and I decided to see what was happening on rccrawler, and found the wraith. I was bitten at first sight . I just got this last week and have started doing things that are free first, then I'll start adding parts. I've seen a bunch of pictures of batteries moved to the front. Having done the comp thing, I knew I wanted the weight up front so I moved mine as well. I'm not sure if anyone has taken out the cross brace that I did, but I don't have any ill effects from it. I cut up the battery tray and was able to lay it flat. This allowed me to get the wires out of the passenger seat I'm waiting for a servo wire extension and the Rx will go in the rear. I made me a plate out of thin lexan to mount the box. Threw a coat of flat olive drab on it and then some steel wool to get a semi-gloss/satin look. More mods to come....... |
03-01-2012, 01:54 PM | #2 |
RCC Addict Join Date: Feb 2012 Location: Ca.
| Re: Just getting started
Your rig looks great. What did you screw the stock battery plate to when you moved it up front and where is your speed control now located? I also like your new rear plate, very clean.
03-01-2012, 02:33 PM | #3 | |
| Re: Just getting started Quote:
In the picture, you can see the two screws mounting the tray to the holes where the cross brace was mounted that I took out. I added a couple zip ties for a nice secure fit. One more just because Last edited by dunerinaz; 03-01-2012 at 02:35 PM. | |
03-01-2012, 03:03 PM | #4 |
Great, thanks for the additional pics and explanation. Nice
03-01-2012, 05:06 PM | #5 |
Newbie Join Date: Dec 2011 Location: Maryland, USA
Very nice. I'm digging the OD paint and am a little mad at myself for not thinking of doing that. I just painted mine black today to match my 1:1 Jeep. I also like the placement of the electronics. I'm waiting on a servo extension to come in the mail too.
03-01-2012, 06:25 PM | #6 |
Newbie Join Date: Aug 2008 Location: Long Island ( land of no rocks)
Looks good!! Like the color, and the battery tray mod!! Sent from my iPhone using Tapatalk |
03-01-2012, 07:03 PM | #7 |
MODERATOR Join Date: Oct 2010 Location: RC Land
Nice start. I like your color choice Next stop..... Get rid of the bendy twisty stock links Keep us posted |
03-01-2012, 08:05 PM | #8 |
| Re: Just getting started Awaiting parts from Mcmaster Carr for the links. I'm using 3/16 solid stainless and turning down the ends and threading them for the traxxas rod ends. I have a small tubing bender, so it should make thinks a little easier.
03-09-2012, 06:03 PM | #9 |
Just an update. Made my own links today, lowers anyway. I think they turned out pretty good. They're 1/4" stainless with 8-32 all thread. Getting the bends they way I wanted them was a little time consuming. I purposely made the rear lowers a few millimeters short to angle up the diff and get the driveshaft up for more clearance. I also hacked the rear of the cage off. The part I added will be painted flat black to match the rest of the cage. Upper links will be next. |
03-09-2012, 07:32 PM | #10 |
RCC Addict Join Date: Nov 2009 Location: cleveland,Tn
rig looks awesome man going in the right direction on this build. gotta stupid question but why run the shocks upside down?
03-09-2012, 08:39 PM | #11 | |
And thanks for the compliment. | |
03-09-2012, 08:42 PM | #12 |
On a side note, does anyone make skid plates for the diffs? I can see these things wearing away quickly with a lot of crawling on rocks. My front is getting worn down with not much time on the rocks.
03-09-2012, 08:55 PM | #13 |
Newbie Join Date: Jan 2012 Location: NE Texas
Love the stance. Lowers look good. I wanna make a set of links. These pics sure help my know what I want mine to b like. Great job.
03-10-2012, 08:39 PM | #14 |
Links are finished. I like the way they turned out. I also rebuilt the shocks today. I focused on making sure the piston was smooth and everything assembled correctly (I found missing parts in mine) and what a difference it made. So much smoother and better feeling. Too bad it took me doing it right. They should be built correctly the first time. Last edited by dunerinaz; 03-10-2012 at 08:41 PM. |
Just getting started - Similar Threads | ||||
Looking to get started, Need some help! | ToyotaStovy | Newbie General | 5 | 01-16-2010 06:11 AM |
Just Getting Started | MattBraxton | Newbie General | 4 | 05-14-2009 05:58 AM |
trying to get started!! | gunit19gameover | Newbie General | 4 | 05-30-2007 11:10 AM |
Getting started | matt423 | Newbie General | 2 | 02-27-2007 12:07 PM |
Help getting started | osbornl1 | Newbie General | 2 | 05-25-2006 02:05 PM |
