09-07-2012, 04:46 PM | #81 | |
| Re: Wraith lockers Quote:
09-07-2012, 06:34 PM | #82 | |
Pebble Pounder Join Date: Mar 2010 Location: Orlando
09-07-2012, 07:30 PM | #83 |
Rock Crawler Join Date: Jan 2010 Location: In the lair editing video
| Re: Wraith lockers |
09-07-2012, 07:49 PM | #84 |
RCC Addict Join Date: Sep 2009 Location: sacramento
| Re: Wraith lockers
you guys are going to love the new lockers ive been beating the hell out of them for a while now and no slop at all |
09-07-2012, 09:27 PM | #85 |
Rock Crawler Join Date: Jan 2012 Location: Hudsonville, MI
Just ordered a couple!!! Oh Hell Yeah!! Sent from my iPhone using Tapatalk. |
09-07-2012, 09:46 PM | #86 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
| Re: Wraith lockers
Wish I could afford these before NW Scale Champs... Looks nice!
09-12-2012, 01:32 AM | #87 |
Rock Crawler Join Date: Nov 2007 Location: Bay Area (RWC)
I just got a set of VP lockers today and took a few shots compared to the Felsenfest. They center up very very easy. |
05-13-2013, 09:42 AM | #88 |
| Re: Wraith lockers
Does the setscrews on the VP spool rest directly against the axleshafts? Or is there a plate they push against, and the plate rides against the axles? Do the VP spools only have setscrews on one side and the inner steel portion just "floats" in the center of the aluminum housing once everything is tightened? I know the setscrews on the Felsenfests only rest halfway on the ends of the Axial Universals, which in my case always results in loosening setscrews and mangled axleshaft ends. I run the Felsenfest spools in three other trucks without issue, but when run in a brushless Wraith they won't stay together for even a couple packs. And yes, I am OCD about clean metals and letting the Red loc-tite cure. Destroyed three sets of axles so far and even one Felsenfest spool, so I'm looking for a long term solution. I haven't "broken" an Axial universal joint yet, but I've worn out two sets in a year to where they had enough slop to destroy the wheel bearings in a few packs. For a while I was running the stock sintered spool JB Welded to the stock diff case, but I kept rounding out the center of the sintered mini spool. Can anyone tell me if the Vanquish VVD's are any longer than the Axial Universals? Longer axles would allow the Felsenfest setscrews to properly contact the axle and eliminate my loosening setscrew issue. |
05-13-2013, 11:43 AM | #89 |
The VP Lockers only have set screws on one side. I found I can not tighten them down. You just set them very close to the axle to get no binding. I do run VP axles up front this way but changed back to the felsenfest for the rear locker. I couldn't get the set screws to hardly touch the rear axle on my Wraith. I later bought felsenfest one piece 5mm axle. Problem solved. But the front, still keeping an eye out for making it better.
05-13-2013, 12:31 PM | #90 |
Metal shaper Join Date: Dec 2008 Location: Hog Eye, Texas
The VVDs are longer than the universals on the tangs. You will get full engagement with them inside the locker.
05-13-2013, 02:56 PM | #91 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
| Re: Wraith lockers
In the rear I bought some sweet titanium axles from CreeperBob!! He makes them with longer tangs so they engage fully into the locker. I am super happy with them so far. Front I have the Vanquish VVDs and they are perfect! |
07-08-2013, 10:48 PM | #92 |
Pebble Pounder Join Date: Apr 2013 Location: Thibodaux, LA
| Re: Wraith lockers
I'm running the ROC 412 on 3s and stripped 2 HR uni lockers in my front axle. Both lockers rounded out on the long shaft side. Has it been determined that the VP locker is the best? I've heard about another one called the last locker, anyone have experience with that one?
07-08-2013, 11:02 PM | #93 | |
Pebble Pounder Join Date: Nov 2012 Location: united kingdom
Damn, I just bought the HR uni lockers and I have the same set up as you. I hope I didn't waste my money. Maybe I should return them and just get the vanquish lockers... | |
07-08-2013, 11:12 PM | #94 |
Rock Crawler Join Date: Aug 2010 Location: Saint Marys, OH
I've got a pair of Grip Fab V2 spools in my rig, awesome fit, better than the HR ones, IMO.
07-08-2013, 11:18 PM | #95 |
| Re: Wraith lockers
I just don't know man. The first I thought was a fluke, but after waiting 7 days on the second one and not even getting a full pack out of it, I'm kind of pissed. I will be emailing them with pictures to see if they can remedy my situation, but in the meantime I'm going to go with a different brand. Either Locked Up, Last Locker or VP.
07-09-2013, 02:35 AM | #96 |
RCC Addict Join Date: Mar 2009 Location: Chilton
| Re: Wraith lockers
I am running 2 VP lockers in one rig and have had no issues with them and I have 3 other rigs I am running the Grip-Fab V2 SS spools in and so far I am really liking them. Grip-Fab is also now coming out with a V3 ARB SS locker that should be just as good also. The only issue I have had with the felenfest lockers is with the Wraith tangs not being long enough for them to get a good bite on them. Its not the lockers fault but axials for the short tangs on the axle shafts. For price and ease of install I vote the Grip-Fab spools. I have seen the new Locked up lockers but have no idea on them since I have not used them but he usually has good stuff and they are suppose to be hardened steel so they should last and def be better that aluminum stuff just not as light. |
07-09-2013, 09:26 AM | #97 | |
Quarry Creeper Join Date: Aug 2011 Location: Antioch by a rock!
GripFab "Grip-Lok" V2-SS Spool - Super Shafty | |
07-09-2013, 09:34 AM | #98 |
| Re: Wraith lockers
The GripFab Spools are awesome! He's coming out with an ARB licensed one too! |
07-09-2013, 09:42 AM | #99 | |
RCC Addict Join Date: Oct 2011 Location: Crawlerado
Regardless of what locker you choose, I would STRONGLY suggest going with CreeperBob's Ti Shafts on non-steering axles (I would also suggest requesting the tangs to be extended 2mm), and VP VVD's on steering axles. Last edited by TheScaleAddict; 07-11-2013 at 07:34 AM. | |
07-09-2013, 09:44 AM | #100 |
| Re: Wraith lockers
The new locker from Locked up RC is really nice. Extra weight down low and the tightest fit on the tangs of any locker I've ever had come through the shop. Ring gear bolted up flawless and it dropped right in. Everything is happy, happy, happy!! |
Wraith lockers - Similar Threads | ||||
Replace Hr Lockers With Berg Lockers | Yawzer | General Crawlers | 5 | 12-29-2008 10:51 PM |
