10-10-2013, 05:32 AM | #1 |
Pebble Pounder Join Date: Sep 2013 Location: Mechanicsburg, PA
| Pinion and Spur shaft size question
I am upgrading to a 32p 56/14 also buying a 32p 60/15 to test that out. I like the idea of going to metal. Would that be strongly recommended? What is the pinion and spur shaft size I need to work with a Holmes 13t CrawlMaster in a Wraith? Any recommended sites to purchase these from? Thanks |
10-10-2013, 05:59 AM | #2 |
| Re: Pinion and Spur shaft size question
Search? 56t spur dtxc9397 60t spur DTXC9396 You need an steel 1/8" pinion for your motor. I like associated. |
10-10-2013, 07:16 AM | #3 |
Thank you. So you don't think a steel spur is worth the money? Spur are they they just universal for scale RC? No certain thickness required? I see it references a Key #16. I do understand gearing quite well after being a cyclist/triathlete my whole life. I just don't understand what parts will works. |
10-10-2013, 07:21 AM | #4 |
| Re: Pinion and Spur shaft size question A steel spur will be louder, heavier and you won't have any issues with a plastic 32p spur. Not all spurs will bolt up but both of the part numbers that I posted will work.
10-10-2013, 07:07 PM | #5 |
I'll tell you right now your going to want s different ratio. 4:1 isn't low enough and both options you just listed give you 4:1. Pick something more in the range of 56/10-12, that way you won't smoke your new HH motor right off the bat. As for the steel spur, they are great, but chances are a plastic 1 will work just fine for your application.
10-11-2013, 05:03 AM | #6 | |
| Re: Pinion and Spur shaft size question Quote:
I am glad you saw that and posted. You are absolutely right. I don't know what I was thinking when I posted that. Apparently I was not thinking. | |
10-12-2013, 01:43 PM | #7 | |
I found them Here but only after converting 1/8 to 3.17mm using this conversion chart. I wonder if these manufactured in Taiwan pinions are any good? | |
10-12-2013, 04:56 PM | #8 | |
Pinion and Spur shaft size question - Similar Threads | ||||
AX2 gearbox. 60T,32p spur. 55turn. Max pinion size? | Axa | General Crawlers | 0 | 09-05-2013 05:53 AM |
Pinion and Spur question? | Ffnye79 | Axial SCX-10 | 4 | 10-26-2012 02:04 PM |
pinion and spur gear size | jcolvin | General Crawlers | 1 | 04-25-2012 10:13 AM |
Novak Mongoose 380 Pinion shaft Size?? | skullking | Electronics | 9 | 07-12-2011 06:19 PM |
Pinion or Spur Question | BMFOTP | General Crawlers | 6 | 04-17-2009 06:02 AM |
