Thread: Anyone done a trailing arm rear suspension?
Old 09-02-2013, 11:11 AM   #21
Default Re: Anyone done a trailing arm rear suspension?
Originally Posted by Harley View Post
Describing it but naming it incorrectly is what everyone will get hung up on.
There are lots of things you need to handle when doing link mounted shocks.if the rod end is mounted at or abOve the center line you get a piss poor performing suspension unless you add "wobble stoppers" to the links. Reason is because of all the degrees of freedom the link and shocks have. The proper method is to mount the shocks below the centerline to make the force of the suspension align the link properly.
P.S. - never convince yourself you know how to do it, you'll never learn anything that way.
Having the shock end below the center line of the link only stabilizes the link under compression. It actually makes the link rotate worse during rebound.
Calderwood is offline   Reply With Quote
Old 09-02-2013, 11:11 AM   #22
Blue Monkey:
Wraith Trailing Arms, Blue Monkey RC
Tio Loco is offline   Reply With Quote
Old 09-03-2013, 01:00 PM   #23
I say make it out of metal so you can bend and weld each sides upper and lower together while still utilizing stock mount locations. Consider using the two truss holes on top instead of the stock upper mount. I think the trailing arm should be able to control axle wrap.
67mustang is offline   Reply With Quote
Old 09-03-2013, 02:15 PM   #24
4RunnerKid's Avatar
Originally Posted by 95geo View Post
Full bump will look something like this:
i approve of this message...
like others have said, it's still a standard 4-link setup but you are increasing the motion ratio on your shocks (more suspension travel for a given shock travel). many many many Ultra4 cars run this setup now.
i used the XR10 shock mounts for my "trailing arm" rear suspension. a few o-rings help resist link wobble and a rear sway bar keeps things in check. so far i'm pretty happy with the performance.
i'l be checking back to see what you come up with
4RunnerKid is offline   Reply With Quote
Old 09-03-2013, 02:52 PM   #25
BMRC trailing arms + DmG TA/Stiffy Kit
the DMG is offline   Reply With Quote
Old 09-03-2013, 09:41 PM   #26
That looks awesome. I would be interested to see how it drives at a fast speed.
Billy D is offline   Reply With Quote
Old 09-03-2013, 11:07 PM   #27
Why not build a radius arm and pan hard set up for high speed. With rods in on radius arm the pinion angle would be adjustable and incorporate a shock mount or multiple mounts into the arm. Then a pan hard to control side to axle movement
evan03 is offline   Reply With Quote
Anyone done a trailing arm rear suspension? - Similar Threads
Trailing Arm Suspension for a trailer neillarson General Scale Talk 11 07-03-2011 09:15 PM
Shortcourse 4-link vs. trailing arm desertmaxx Non Crawler RC's 4 09-07-2010 06:40 PM
trailing arm links mookie Redcat Crawlers 6 07-07-2010 06:43 PM
Torque Arm Rear Suspension on a Maxx? JamboreeTJ Traxxas Crawlers 4 02-21-2007 09:07 AM
