![]() | #361 |
Pebble Pounder Join Date: Jun 2017 Location: United States
What oil do you use in your shocks?
![]() | #362 |
I think 20w. But when I looked at the bottle it IS 30w ! Hang up and Drive Last edited by mikemcE; 08-13-2017 at 04:53 PM. |
![]() | #363 |
When I have been looking at Shock oil the numbers are like 4.2. What kind of oil are people using for shocks?
![]() | #364 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
Silicone shock oil. 4.2 is a weird designation, it's usually in wt (20-30-etc) or CST (rougly 10x more, but not linear).
![]() | #365 |
Teach me to watch YouTube vids trying to learn how to set up shocks. He had 4.2 oil that he showed
![]() | #366 |
Newbie Join Date: Aug 2017 Location: canton
Anyone got a recommendation for a better gear set out of the transmission, just grounded mine done to nothing. Manual says gear set, to be more specific it is the middle gear in the trans. Is that idler gear? Sent from my SM-G930T using Tapatalk Last edited by hillclimber; 09-03-2017 at 10:08 AM. |
![]() | #367 |
![]() | #368 |
That or Robinson racing!
![]() | #369 | |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
| ![]() Quote:
![]() | #370 |
Quarry Creeper Join Date: May 2019 Location: North Highlands
![]() | #371 |
Quarry Creeper Join Date: Nov 2015 Location: US
This is what you need. Find this stuff. The model is an older one and support in the aftermarket is fading.
![]() | #372 |
![]() | #373 |
| ![]() Exactly and not a whole lot has changed. Anything GH on the original list is probably hard to find these days but they were minor things anyway. STRC and Hot Racing still make equivalent bearing caps and I would go for the Vanquish 1 piece servo mount these days over what is on the original list. https://www.rpphobby.com/product_p/vps07970.htm The biggest change is that bushings on the inner pinion bearing is no longer the best option for big power. More than a few companies offer axle housings with larger 5x13 or 5x14 inner bearings that hold up way better. I believe all of Vanquish's AR60 axle housings have been upgraded to the larger inner bearing as well as SSD's AR60 housings and Dlux offers the stock housings modded for a larger inner bearing as well. |
![]() | #374 |
Well, maybe you guys can help, because trying to upgrade without links can get expensive. I ordered the Axial 32P spur and pinion as recommended. But they aren't going to work with the current slipper. Do I need to replace the entire slipper assembly to upgrade? Or did I get the wrong spur gear? (no holes for bolts). |
Harley's Axial Wraith Build - Jimmy's 4x4 Ultra 4 KOH Style | Harley | Axial Wraith | 2725 | 02-11-2020 08:19 AM |
Wraith Beginners Guide | Harley | Axial Wraith | 1058 | 06-24-2019 07:52 PM |
Harley's Complete XR10 Guide | Harley | Axial XR10 | 319 | 07-14-2014 01:00 AM |
Harley's Wraith #2 - Built for Vanquish | Harley | Axial Wraith | 66 | 11-05-2012 07:17 PM |
Harley's Wraith Sportsman | Harley | Axial Wraith | 123 | 01-21-2012 06:35 PM |
