05-02-2012, 08:29 AM | #1 |
RCC Addict Join Date: Feb 2012 Location: UK
| Cage mod help? Hello. I want to do this mod. http://www.rccrawler.com/forum/attac...0-p1000519.jpg What are the aluminium links called? I know the other parts are rods ends. Also what size would they be? Kind regards |
05-02-2012, 10:05 AM | #2 |
| Re: Cage mod help?
all they are is axial ax10 aluminum upper links. i did the same thing to my wraith. it also looks really cool and clean if you cut and bend the tube thats already there.
05-02-2012, 10:55 AM | #3 |
| Re: Cage mod help?
Do this instead, don't need to buy any link parts. Had to bend and heat a little more to get it where it's best. I like it! Definitely a spot to take your time with. Now to mount my spare tire! Got the down tube notched perfectly and the attaching screw head is nice and flush wiht the other tube. Used a 3x18mm self-tapper left over from my kit. |
05-02-2012, 11:36 AM | #4 |
Newbie Join Date: Mar 2012 Location: Utah
| Re: Cage mod help?
On mine i used bic ben bodies glued to the extra rod ends. It was free and it looks good after some paint like this: |
05-02-2012, 11:49 AM | #5 |
| Re: Cage mod help?
Thanks guys
05-02-2012, 01:06 PM | #6 |
Rock Crawler Join Date: Nov 2008 Location: missoula
I did this for electronic access! |
05-04-2012, 09:23 PM | #8 | |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
| Re: Cage mod help? Quote:
05-04-2012, 09:24 PM | #9 | |
I also like this mod but there is no rear roll bar and I kind of want the Jeep looks. Who knows what I will do. Great ideas all of you guys!! | |
05-04-2012, 09:45 PM | #10 |
| Re: Cage mod help? |
05-04-2012, 10:19 PM | #11 |
Rock Crawler Join Date: Nov 2009 Location: Commiskey
| Re: Cage mod help?
If you wave a lighter back and forth over the area where you want the plastic to bend it bends quite easily. Just bend a little past where you want it to stop and hold it there a minute till the plastic cools and it'll flex back a little bit but should roughly be where you want it to be. Also, don't keep the lighter in one place very long or the plastic will start to bubble and burn.
05-05-2012, 06:30 PM | #12 | |
05-05-2012, 06:39 PM | #13 |
Pebble Pounder Join Date: Sep 2010 Location: West Linn
| Re: Cage mod help?
I used a 106mm 30 degree bent link from an AX10 link kit I had in my garage. I ground down the ugly green down with my table sander and then used a slightly longer link end on one end to make up the extra length needed for the bent part in the link. Definitely a fun project, and makes a world of a difference in appearance and body clearance. I zipped my spare on the back and it hasnt moved, plus it covers up the empty space of the battery tray. Heres a shot of my brothers.. |
05-07-2012, 04:13 AM | #14 |
| Re: Cage mod help?
Done! :-) |
05-07-2012, 04:24 PM | #15 |
RCC Addict Join Date: Nov 2005 Location: Utah
| Re: Cage mod help?
I like the link mod but it always has bugged me how they are inboard from everything else. My solution, no links, cutting re using the chopped pieces: |
05-07-2012, 04:39 PM | #16 |
05-07-2012, 10:38 PM | #17 |
| Re: Cage mod help? It's dark and i don't feel like trying to get good lighting. Maybe tomorrow. I'll try to explain. Meh here's a lousy paint drawing that hopefully makes sense. Cut the verticle bar so it supports the diagnol bar, once you get all the pieces in front of you you will understand how to notch them so they fit together at the top.
05-08-2012, 02:38 AM | #18 |
| Re: Cage mod help?
Like the rear light holder! |
05-08-2012, 11:21 AM | #19 | |
06-26-2012, 11:40 PM | #20 |
Newbie Join Date: Jun 2012 Location: San Francisco
Cage mod help? - Similar Threads | ||||
cage mod | snohiker | Axial Wraith | 51 | 06-18-2013 11:58 PM |
Roll Cage/Exo Cage? | ZackMicF | Paint and Body | 6 | 07-04-2012 06:19 AM |
Front Dig Mod,steering mod & pushbar | TheButcher69 | General Crawlers | 1 | 11-06-2006 06:32 PM |
