Thread: Robinson slipper 56T Gen3 Slash
Old 05-15-2012, 06:27 PM   #1
Default Robinson slipper 56T Gen3 Slash
Will this fit onto the Wraiths top shaft?also what other parts do I need in order to run this on my Wraith Trans? I cant seem to find the rebuild kit with the spring and the nut on RPP that was mentioned by Harley, Is there a way that I can just run this using the parts from the stock top shaft?
Robinson Racing HP Slipper Unit 56T Gen 3 Slash
sixhundred71 is offline   Reply With Quote
Old 05-16-2012, 12:55 PM   #2
Default Re: Robinson slipper 56T Gen3 Slash
No you need a top shaft from SuperShafty.com
Later,
Farmer
Farmer is offline   Reply With Quote
Old 03-25-2015, 08:38 AM   #3
Actually yes providing you already have the RR Gen3 Wraith Sipper unit and then you purchase the 56T 32P slipper for the Slash 2wd. This is what I did and I realized you can use the backplate from the Wraith slipper with the spur gear for the Slash slipper. It fits perfectly no mod. The Wraith backplate has the added collar on it needed to push is out a little.
dpartin is offline   Reply With Quote
Robinson slipper 56T Gen3 Slash - Similar Threads
Robinson Gen 3 slipper sixhundred71 Axial Wraith 17 07-31-2015 02:08 AM
robinson racing slipper 48p kmas Axial Wraith 3 05-11-2012 11:08 PM
Robinson Racing Wraith Slipper unit & gears IN STOCK RPP Hobby RPP Hobby 0 01-13-2012 10:27 PM
robinson slipper pad question NeXt559 Non Crawler RC's 0 01-09-2010 10:53 AM
