06-27-2012, 05:27 PM | #61 | |
| Re: Axial Wraith Anti-Sway Bars Quote:
06-27-2012, 06:01 PM | #62 |
| Re: Axial Wraith Anti-Sway Bars I hope you are kidding......because I was. |
06-27-2012, 11:15 PM | #63 |
Rock Stacker Join Date: May 2011 Location: Rancho Santa Margarita
I installed the front arms with the softest rear bar. The front bar is too wide. I did this because I feel the softest setting for the rear is still a bit too stiff. So I used the front arms for extra leverage on the bar. So far I like it. Still on the stiff side but it will do the job I want it too. |
06-27-2012, 11:27 PM | #64 |
Quarry Creeper Join Date: Jun 2008 Location: the White House
Hey Mikey,this is DD from BA. Where did you get your limiters or did you make them?
06-27-2012, 11:33 PM | #65 |
Hey Hey! Basic kit from team3six but I had to do some rework on the brackets as well as bending them up. But even with the kit you have to cut & sew up the straps. It did make life a little easier. |
06-27-2012, 11:40 PM | #66 |
Thanks,I would like a set on my RadWraith. |
06-28-2012, 06:41 AM | #67 |
| Re: Axial Wraith Anti-Sway Bars |
07-01-2012, 02:57 AM | #68 |
Newbie Join Date: May 2012 Location: JC
Finaly got to try mine out today on asphalt with the front and rear sway bars installed, solid bars take all of the torque roll out of her, running traxxas brushless as a basher. It seemed to crawl ok over some tree roots and sand bags. Next weekend I'll try to find some rocks to crawl over.
07-01-2012, 10:08 PM | #69 |
07-01-2012, 10:34 PM | #70 |
RCC Addict Join Date: Sep 2009 Location: sacramento
07-01-2012, 10:35 PM | #71 |
07-02-2012, 06:52 PM | #72 |
Interesting. When I put that bar on mine the linkage got into the springs & spring retainers. Glad it works out good for you. |
07-03-2012, 06:04 AM | #73 |
Rock Crawler Join Date: Aug 2008 Location: Wine Country
I got my front set last week and tried the softest rod first. Loved the way it changed my rig. I didn't loose too much on the articulation. But after about three packs I noticed the body was starting to roll a little more than when I first installed the kit. I think the rod started to break in. I'm just about to take it out again for a spin today. I only got the front set from axial. One of the better upgrades for the wraith. I think Axial should have it in the kit from the start.
07-03-2012, 06:29 AM | #74 |
07-03-2012, 08:30 AM | #75 |
Pebble Pounder Join Date: Apr 2010 Location: Norway
Can anyone measure the length of the lever arm on the Axial kit? cc torsion bar mounting hole to the very end both front and rear (if they are different length). The reason is because I'm not sure if they will fit with the Gmade XD piggyback dampers. |
07-04-2012, 01:36 PM | #76 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
| Re: Axial Wraith Anti-Sway Bars I bought the Axial kit for the front of the Wraith. Arms are about 1 3/4" on centers.
07-04-2012, 02:02 PM | #77 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
is it possible to make this one on your own, possibly using Piano wire or something? 45.00 for this kit (Ea.) is a touch steep imo for a swaybar setup. |
07-04-2012, 02:04 PM | #78 |
07-04-2012, 02:05 PM | #79 |
The diameter of the Axial rods is 3/32". If you can make your own lever arms and drill/tap for a set screw, you should be good.
07-04-2012, 02:14 PM | #80 |
Thanks! I can confirm that the front kit will fit with the Gmade dampers, but the rear kit will have a conflict with the piggyback reservoir if the arms are the same length as the front.
Axial Wraith Anti-Sway Bars - Similar Threads | ||||
Sway Bars | Optiskate | Axial SCX-10 | 13 | 03-03-2012 11:03 PM |
HR sway bars for wraith F/R | ROLANDROCKSHOP | Axial Wraith | 34 | 11-20-2011 10:48 AM |
Sway Bars | Slowsteve | Axial Wraith | 8 | 08-22-2011 11:59 AM |
anti sway bars? | terrible | Axial SCX-10 | 0 | 04-16-2010 04:27 PM |
TXT Sway bars | Jeephead | Tamiya Txt-1 and Juggernaut | 6 | 01-16-2010 09:07 AM |
