05-24-2012, 12:26 PM | #1 |
| Axial Wraith Anti-Sway Bars
I was browsing for a few parts for my wraith and I noticed these are now being produced. I figured that I'd have seen people running them by now, but I searched and didnt find any talk about them. Axial Racing - Press : Download : Images / Press Releases Front and rear Axial Wraith Anti-Sway Bar Kits....MSRP = $45, but I got mine from Amain for $39 each. |
05-24-2012, 12:31 PM | #2 |
Quarry Creeper Join Date: Apr 2008 Location: PNW
| Re: Axial Wraith Anti-Sway Bars
Hmm looks like a currie anti-rock, I would be interested to see if it had the same effect of providing traction. I may have to try them out.
05-24-2012, 12:35 PM | #3 |
| Re: Axial Wraith Anti-Sway Bars |
05-24-2012, 01:08 PM | #4 |
I think HR or Integy offers something similar. I know for a fact that I could have used it when I re-built the Pirate Bronco. I fact, I'm certain any top heacy scaler could use this thing and greatly benefit. |
05-24-2012, 01:31 PM | #5 |
| Re: Axial Wraith Anti-Sway Bars Oh, they do. But I really dont like either of those companies or their products and avoid them when I can. I agree too. My Wraith is mostly stock, but has a fast motor that crawls well.....so I figured a front kit would be nice. |
05-28-2012, 12:07 AM | #6 |
Quarry Creeper Join Date: Jun 2008 Location: LaPorte
has anyone put one on and tested it yet?? I want this also
05-28-2012, 04:48 AM | #7 |
Newbie Join Date: Feb 2012 Location: Melbourner
I have the HR set and it is the only thing that makes my wraith controllable.
05-28-2012, 08:10 AM | #8 |
RCC Addict Join Date: Dec 2008 Location: Sonora, CA
Will this work with a VP servo chassis mount on the front and a 4ws set up on the rear using the stock Axial servo mount ?
05-28-2012, 09:22 AM | #9 |
Rock Crawler Join Date: Oct 2011 Location: Lake Worth
I have the VP CMS kit and the HR sway bars and saw a huge difference in handling. If the Axisl ones had been out when I got the HR ones I would have bought those instead. I really havnt had s bit of problems the HR ones though to be honest. |
05-28-2012, 02:14 PM | #10 |
Pebble Pounder Join Date: Sep 2011 Location: USA
They are on my next order. Hoping it helps a little with high speed roll overs and don't affect crawling in a negative way. Sent from my iPhone using Tapatalk |
05-29-2012, 12:19 PM | #11 |
| Re: Axial Wraith Anti-Sway Bars The whole point of a sway bar is performance in cornering and anti roll. If you put it on a crawler it will hinder your crawling capabilities quite a bit because each arm works in unison to fight the sway. If one wheel runs over a rock the other will want to move up with it as the suspension compresses.
05-29-2012, 02:20 PM | #12 | |
| Re: Axial Wraith Anti-Sway Bars Quote:
BTW, mine showed up today and I just finished installing them....if I can get out of work at a decent hour today, then I might get to drive this thing. | |
05-29-2012, 02:40 PM | #13 |
| Re: Axial Wraith Anti-Sway Bars Yeah it depends on the bar but even the softest bar won't allow to flex as much as not having one at all and he said that he had hoped it wouldn't effect his crawling performance.
05-29-2012, 02:48 PM | #14 |
Crawling isn't only about articulation. |
05-29-2012, 02:53 PM | #15 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
05-29-2012, 03:48 PM | #16 |
05-29-2012, 05:26 PM | #17 |
| Re: Axial Wraith Anti-Sway Bars Yeah correct problem is when you come up on an obstacle at an angle and the rig can't form to the object and it (rolls) over because one wheel is hindered by the other wheel that is already on the object. That's why the sway bar will take away from crawler part but anyway your right it does enhance the rock racer part of the wraith and that's the reason I added the tube for the sway bars to be mounted.
05-29-2012, 06:05 PM | #18 |
Well, I installed the softest bar that came with the Axial kit and it doesn't seem to have much effect on the articulation. If you pick the front tire of the truck up, it will bottom out the shock before the opposing rear tire comes off the ground. I also notice that it's a lot more stable during high speed cornering.
05-29-2012, 06:11 PM | #19 |
RCC Addict Join Date: Dec 2007 Location: Rochester Hills
Very sweet Later, Farmer |
05-30-2012, 03:15 AM | #20 | |
Quarry Creeper Join Date: Jul 2009 Location: Long Island
Axial Wraith Anti-Sway Bars - Similar Threads | ||||
Sway Bars | Optiskate | Axial SCX-10 | 13 | 03-03-2012 11:03 PM |
HR sway bars for wraith F/R | ROLANDROCKSHOP | Axial Wraith | 34 | 11-20-2011 10:48 AM |
Sway Bars | Slowsteve | Axial Wraith | 8 | 08-22-2011 11:59 AM |
anti sway bars? | terrible | Axial SCX-10 | 0 | 04-16-2010 04:27 PM |
TXT Sway bars | Jeephead | Tamiya Txt-1 and Juggernaut | 6 | 01-16-2010 09:07 AM |
