05-25-2012, 09:58 AM | #1 |
Rock Stacker Join Date: May 2012 Location: Hemet
| binding issue
So i bought this steering system and it looks great but it binds up on the axle. It binds where it mounts to the axle then to the servo mount? i have my wraith lowered with the lowering kit that might be it? I am just wondering if this has happened to other people running a chassis mounted servo. I dont want to keep it at stock ride height because its way to high. Should i just return my steering set up and stay with axle mounted steering? This is the link to the steering system i bought. Chassis Mounted Steering Servo kit for Axial Wraith |
05-25-2012, 11:29 AM | #2 |
RCC Addict Join Date: Feb 2012 Location: UK
| Re: binding issue
Maybe you need to remove one of the upper links. This is advised for the VP kit to stop binding.
05-25-2012, 11:34 AM | #3 |
| Re: binding issue
i did i removed one and it still did, so I put it back in. Also the drag link is not hitting the links its hitting the top of the axle so i might try and bend it a little bit to where it follows the contour of the axle.
05-25-2012, 04:19 PM | #4 |
Rock Crawler Join Date: Jan 2012 Location: Hudsonville, MI
| Re: binding issue
Maybe your CMS is back (towards) the receiver too far. My VP CMS is maybe about 1/2" from touching my electronics plate - which mounts at the same point the receiver box does. I'm not exactly sure how the RC4WD CMS mounts. With the combination of the ackerman plates on the C-hubs and if your CMS is mounted in the correct spot (not pushed back too far), the drag link should be out of the way enough to not hit the axle. Maybe post a picture of the issue so we can see what's exactly happening. |
05-25-2012, 05:26 PM | #5 |
| Re: binding issue
ok so i just got my aluminum knuckles and hubs and then once i installed them i noticed that when i turn my wheels they are hard to turn by hand is this normal |
05-25-2012, 05:54 PM | #6 |
Pebble Pounder Join Date: Apr 2010 Location: Guam
| Re: binding issue |
05-25-2012, 08:13 PM | #7 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
| Re: binding issue |
05-25-2012, 09:16 PM | #8 |
| Re: binding issue
When I mean turn I mean turning one so all four will turn
binding issue - Similar Threads | ||||
binding issue | chrispy76 | Team Losi Comp Crawler | 6 | 04-01-2011 08:18 AM |
steering binding issue | JaredVW | Axial AX-10 Scorpion | 22 | 07-16-2010 12:10 AM |
DX6I Binding Issue | THnCS | Superclass Crawlers | 0 | 02-23-2010 08:10 AM |
Binding issue | davidg86 | Team Losi Comp Crawler | 8 | 08-24-2009 06:33 PM |
Binding Issue...Need some help | evaderman | Axial AX-10 Scorpion | 10 | 07-26-2008 05:48 PM |
