![]() | #1 |
Quarry Creeper Join Date: Feb 2011 Location: Forbestown, CA
Well my wife and I planned going this year, and my Matv is on the back burner til I get my garage sorted again, so with the local rc group crawling I had to run something, and I found out vp put out a metal version of a plastic axle housing I made last year and so i slapped it on and got this.. enjoy, In action pics tomorrow! also If anyone could make a panhard bar so I can chassis mount this and finish up hiding things on it would be awesome ![]() list of things in it Trans metal upgrade all but housing, 35t HH Electronics, a Jr 8911hv, wraith lightening system, castle bec, mamba micro esc, Atx 300 receiver, just a comment on this thing came with a new brand rc buggy and the thing was faster then my slash 4v4 out of the box, the controller allows easy adjustable at anytime to move the wheel simple to use 3 channel control with over steer, all with 2.4 system. worth the money for me not ruining my wrist like I do with drag racing, Ill take more pics of it also. battery, I ran 3 packs of these parkzone, 11.1v 1300mah 15c softpacks, they are cheep and easily abused. I typically only run thunder power but these little green things do the trick by far. Wheels, Clearly pitbulls these tires and rims have a bad history with me. everything I put them on since i bought them ruined the rims or broke my damn trucks, they stick to everything which is really good since we do sharp loose dirt hill climbs. but anyways drive shafts MIP, the special bag i think it was 54.99$ for normal size shaft and a dig size which is great since I had to bring in the front, oh I also turned around the motor and trans for a little weight forward. these shocks, I can not remember who did a really good timberwolf build around October last year but they described these losi short course shocks and I been using them on my heavy builds since, the black I want on the front, but I still need to cut away the electronic plate, but before I do that I wanted to see if anyone has done a pan hard bar for the short axles for this. Axles vanquish metal axles. I do not remember who makes the droop or raised shock mounts worth it though, I did mod the hood the upper bar near the dash i replaced with metal links to give a stronger support with the hood and magnet on the front to keep it down i do plan on making the electronics hidden very soon. with all said Its fun! and >.< I cant wait to go visit my family in California in.... july....... So I might just bum around and find the local crawler guys again, tried last year and missed a event. ![]() ![]() ![]() ![]() ![]() Last edited by Absurd; 03-09-2013 at 12:01 AM. |
![]() | #2 |
Quarry Creeper Join Date: Jan 2012 Location: Durango
Exaclty what I am building.. Looks great dude!
![]() | #3 |
Pebble Pounder Join Date: Sep 2011 Location: Medford
Any feedback on that JR 8911hv would be appreciated! Im planning on getting one soon! Thank you!
![]() | #4 | ||
| ![]() Quote:
![]() | #5 |
Well time for a update on this, 5 runs 10 gates 3 courses per run, and 1 of the 5 runs was at gravel rama which is located in koi area, we had a blast even with the heat.. and to the end I believe the heat was getting to me because I decided to break a few things... Started with a wood bridge then took off golf ball size chunks of rocks by ramming them with this beast.. and the guys are calling it a bear now ![]() So anyways with all the abuse I got some pictures Ill be ripping it down more this week to find its issues, currently I am running a plastic spur gear which I thought was making the skinning a alive cat sound but it wasn't and I have ALOT of play in the right front wheel now, so I am kinda worried I finished off the axle or locker ![]() To do's consolidate the rats nest, rebuild a rear roll bar switch the shocks front to back to front, and set the front mount lower while also putting high clearance links on the rear should give it a better performance less belly dragging, while all trying to make inner finder walls and a bed. Random question to anyone still reading this Has anyone made a scale snorkel for the wraith yet? Ok on to the porn. First weighing in at 6 pounds 5.1 oz's ![]() The rat's nest ![]() Carnage ![]() ![]() ![]() Oh should point out, The transmission if flipped will need modifying the interior or else it will make the WORSE noise of plastic on plastic you will ever hear... and I loveeeee making the local guys cringe ![]() Even with the weight, and everything set up low, the biggest issue so far was at a 45 degree angle uphill where I did not have a winch it took me 5 trys to get up it while the hood was up from rolling over Last edited by Absurd; 07-16-2012 at 10:34 AM. |
![]() | #6 |
So an update for 2013! braking one of my personal rules after i broke "never buy crappy losi" by a nightcrawler and been taking 1st and 2nd all last year in our sportsman i decided to buy a tekkin and try it out since others are having a blast with it. ![]() So stuff Adding to the bear... 1x Rc4wd 2speed Transmission "this thing i been waiting on since march last year, and got it today.. all i can say is WOW just WOW there is almost no slop, 100% metal no plastic, and they give a replacement of every screw and a extra pinion gear to use the spur gear. its the same tooth size as the Traxxas slash. Gear is plastic fully metal for everything else though. 1x Tekin SC 4x 5.5T "my first tekin I have always destroyed these with castles so I am a bit hesitant" 1x R.R. Slash 4x4 gear upgrade 60t 1x R.R. Slash 4x4 gear upgrade 64t 2x Proline 1.9 Baja claws "Vetra stiff foams" 4x Gunbolt gray vq rims with black beads. 1x 7.4v 2cell 6000mah Wildcatfuels Black ops hardcase 10awg. |
![]() | #7 |
Rock Crawler Join Date: Aug 2012 Location: 909 area
sweet
4wheelparts truck fest this weekend | TwistedXT | Colorado | 1 | 07-08-2009 08:36 PM |
Sunday Crawler Fest | JEFF THE JET | Missouri | 36 | 08-06-2008 03:48 PM |
e-fest | jetboat | Chit Chat | 0 | 01-04-2007 09:57 AM |
