08-09-2012, 10:24 PM | #281 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
| Re: JIA's IFS Ultra4 build
Nice legs.... Prosthetically speaking of course. |
08-09-2012, 10:31 PM | #282 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
JIA, all I have to say is amazing work so far. Im really impressed with this and one of my favorites. Been following and following and cant wait for more.
08-11-2012, 01:35 AM | #283 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
Thanks, Norm. I might have to hit you up for some parts. Got a package in today. SuperShafty top shaft and Castle BECs. You can also see Stig's legs. Made some progress. The pin for the slipper on the SuperShafty top shaft is a larger diameter than the stock pin/slipper. I could slot the stock Wraith slipper to fit the larger pin (and almost did), but I'll probably go with the Robinson spur. Last edited by JasonInAugusta; 08-11-2012 at 04:06 AM. |
08-11-2012, 02:52 PM | #284 |
Parts from Locked Up RC arrived. C.L.A.W. v2 with controller and scale rear hubs. Hubs installed. What do you guys think? Leave'm as is or shorten them? Now that I have the winch, I need to get work making a new front light mount/winch plate. |
08-11-2012, 03:03 PM | #285 |
RCC Addict Join Date: Oct 2007 Location: gervais
Shorten them
08-11-2012, 03:06 PM | #286 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
x2, If ther is enough material i'd shorten em up a little. Are those the nut replacements or the nut covers?
08-11-2012, 03:10 PM | #287 | |
| Re: JIA's IFS Ultra4 build Quote:
Four replacements and installation tool are now on the way. They'll be the better option to shorten. Last edited by JasonInAugusta; 08-11-2012 at 03:22 PM. | |
08-11-2012, 08:31 PM | #288 | |
Quarry Creeper Join Date: Oct 2011 Location: Livermore Ca.
With as much power your running the Robinson will be the better direction, probably smoke the factory in no time hahaha. Jason, you might have said this already but what was your reason going to the Irok's? Been reading up on my next tire purchase and you seem to not be a newbie (lmao) so I figured I'd ask. | |
08-11-2012, 09:41 PM | #289 | |
Newbie Join Date: Jan 2012 Location: Kamloops
08-11-2012, 11:56 PM | #290 | ||
Much appreciated! Did a little work with the C.L.A.W. tonight. Some of the stock black paint was flaking off the brass gear housing that bolts to the motor so I tore it down, stripped it all, primed it in white, then shot it with some Rust-Oleum Safety Red. Once reassembled it should resemble the Warn 9.0 RC. | ||
08-12-2012, 12:11 AM | #291 |
| Re: JIA's IFS Ultra4 build http://traxxas.com/gallery/electric/...-exploded-view Hopefully that helps, I bought the clutch hub and pressure plate for $5 and the rebuild kit for $10 that came with the friction pegs, slipper disc and spring/locknut. Already had traxxas spurs also, all you'll need that isn't supplied in those two part kits is the bearing, I believe 5x11x4 IIRC. |
08-12-2012, 01:16 AM | #292 | |
Got the winch back together. Need to get decals on it and then shoot some clear on the red parts. Going to cut the fairlead off of the stock mount and use a different one. I have about 100 delrin hawse fairleads here, might put one to use. Debating that KK hook as well. *EDIT* Found winch line that young_version gave to me when we were in the hotel. Got it spooled onto the drum. Tomorrow I'll make a new front light mount/winch plate. Last edited by JasonInAugusta; 08-12-2012 at 03:14 AM. | |
08-12-2012, 09:32 PM | #293 |
Working on getting the winch installed. Part of it involves a new front skidplate. Simplest thing to do was just Xerox the stock skid. Used template tape to stick the stock Exo skid on some suitable aluminum, then did rough trimming on the band saw. After rough trimming. Ready for the router lift. Trimmed on the router. And in place. Need to drill mounting holes but I can do it later. This part will get modified for a fairlead. |
08-12-2012, 09:46 PM | #294 |
When your ready for seats, hit me up. I also have delrin fairleads unless you want a viking one I have brand new I would sell ya for cheap. |
08-12-2012, 10:27 PM | #295 |
Won't need seats, Norm. Just some harness hardware and an extinguisher if you have it. Got the front skid drilled and cut for the fairlead. Now to make a new front light and winch mounting plate. |
08-13-2012, 01:59 AM | #296 |
Got the C.L.A.W. mounted. Had to make a new light mount/winch plate to get the winch where I wanted it. Tomorrow I'll finish shaping the front of the mount around the LED bar and drill/slot the bottom of the C.L.A.W. mounting plate. The winch line will run out of the bottom of the winch, under the LED, and through the fairlead. That plate is still in rough shape. When that's done it'll get paint and I'll be done with the front - finally. |
08-15-2012, 04:33 AM | #297 |
Finished modifying the C.L.A.W. base plate. Winch line is now routed through the bottom |
08-15-2012, 02:39 PM | #298 |
Cleaned up the edges of the winch plate and painted it last night. Got everything installed today. The winch plate/LED mount will rotate forward and fit tighter against the top of the Exo skid/bumper when I tie the Wraith cage to the Wraith portion of the front bumper. |
08-15-2012, 02:44 PM | #299 |
Clean install, looks great.
08-15-2012, 07:05 PM | #300 |
Quarry Creeper Join Date: Sep 2010 Location: t(._.t)
wow. always wanted one of those winches, but i cant afford it. looks good in your rig though. you work fast. |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-wraith/388684-jias-ifs-ultra4-build.html | ||||
RC Elétrico - o fórum de automodelismo elétrico! • Tópico: - Axial Wraith | This thread | Refback | 03-01-2013 02:33 PM | |
Axial Racing - Project Wrexo – Bender’s Latest Custom Build | This thread | Refback | 02-18-2013 03:40 PM |
JIA's IFS Ultra4 build - Similar Threads | ||||
Solid axle Ultra4 build | JasonInAugusta | Axial Wraith | 79 | 07-08-2013 09:32 PM |
DTP's KOH IFS Ultra4 | DISTURBIN' tha PEACE | Scale Videos! | 7 | 12-20-2012 09:21 AM |
JIA's IFS KOH Ultra4 Wraith Conversions | JasonInAugusta | Chassis and Suspension | 77 | 11-10-2012 10:27 PM |
IFS axial build | red_zook | General Scale Talk | 6 | 04-28-2012 08:43 AM |
Ultra4/KOH build of doom | Ruff11 | 2.2 Scale Rigs | 14 | 10-10-2011 08:11 PM |
