Thread: JIA's IFS Ultra4 build
Old 06-16-2012, 12:50 PM   #21
Default Re: JIA's IFS Wraith build
Very nice build. Should be great when it's done!
eemmaaxxxx is offline   Reply With Quote
Old 06-16-2012, 04:05 PM   #22
Totally loving it! Looks very tough. Keep it up
rockrigcustoms is offline   Reply With Quote
Old 06-16-2012, 05:00 PM   #23
sweet. more pics and a vid soon please.
desertmaxx is offline   Reply With Quote
Old 06-16-2012, 06:19 PM   #24
06 Super National Champ
JasonInAugusta's Avatar
Dremel action.
JasonInAugusta is offline   Reply With Quote
Old 06-16-2012, 06:43 PM   #25
damn JIA, (JIH??) outbuilding everyone else with hardly any tools, in a hotel room.
looks good man.
dieselfuel is offline   Reply With Quote
Old 06-16-2012, 07:15 PM   #26
looks good man.
Thanks.
Kila says I'm doing it Tony Stark style.
Old 06-17-2012, 02:18 AM   #27
Old 06-17-2012, 07:32 PM   #28
DISTURBIN' tha PEACE's Avatar
Haha!!! Nice job J.
DISTURBIN' tha PEACE is offline   Reply With Quote
Old 06-18-2012, 03:04 AM   #29
Spent about 10 minutes on this thing tonight.
After the above photos I trimmed the parts to fit with a saw blade in the Dremel, center drilled "tubes" with a 1/8" bit, and let it sit until today.
Made a trip to Home Depot and got a 3ft length of 1/8" steel rod and some Gorilla Glue Epoxy.
Came back, cut off a couple of lengths of the 1/8" rod, and pinned the two different cage sections together.
Only got the passenger side pinned, and it's still not 100%, but this is how it'll look. I still need to clean up (round off and debur) where I cut sections off the Exo cage. I'm going to trim down the Wraith's B pillar and pin it in the corner of the Exo cage I spliced in. Also need to trim the "tubes" that the rear shocks mount on. These will tie in to the Exo cage pieces I'm installing.
The top portion of the Exo's cage is being modded for use here as well.
Old 06-18-2012, 03:35 AM   #30
this is such a killer build jason!
ohh EPiC FAiL is offline   Reply With Quote
Old 06-18-2012, 08:55 AM   #31
Im Brandon
Brandon's Avatar
Build is coming together great J!
Originally Posted by JasonInAugusta View Post
I think Axial missed the mark on the Exo's steering. The lower steering post mounts should've been mounted to the aluminum chassis plate instead of the soft plastic sides.
Lots of reasons for the way it was done. You just happened to find the only spot where its inconvenient
Brandon is offline   Reply With Quote
Old 06-18-2012, 01:25 PM   #32
Thanks.
Yeah, I figured it had to do with the angle of the steering posts. Having them mount to the aluminum chassis would've required a bit more machine work...which would drive up cost. The plastic is also more forgiving on impact. Take the hit and return to shape.
I'll make new mounts in the future. For now, while building at the hotel, this will do.
Old 06-19-2012, 08:00 AM   #33
Very innovative build.
What is the wheelbase of this mashup? Can the wheelbase be set differently depending on where you cut the front end? Or is it set with one wheelbase for this mod?
Edit, found a picture in the first post. Looks like the IFS front version wraith is close to the 13.5" wheelbase.
Szczerba is offline   Reply With Quote
Old 06-19-2012, 08:13 AM   #34
Just skimmed through the build, so I may have missed it, but how close to a runner is your rig
MattH is offline   Reply With Quote
Old 06-19-2012, 10:55 AM   #35
I thought about this type of build as I own a wraith and an exo.... I just don't have the financial ballsack to pull it off! Congrats man.
Soulo747 is offline   Reply With Quote
Old 06-19-2012, 12:27 PM   #36
Matt, he brought it over to my house last night, it's exactly as the most recent pics. I do have to say it is totally badass. I am on the hunt for an exo now.
If you have both & some basic hand tools, it'll only cost you time & effort.
Old 06-19-2012, 01:28 PM   #37
Matt, I could have ran it right after the IFS swap, but I decided to keep going and do tube work as well. Instead of running it just to say I ran it, I'd rather build it completely then run it. I still need to find shocks I want up front and I have a shock idea in my head for the rear. Will have to see how it shakes out.
Soulo, like DTP said, it's just tools and time. I'll say I originally intended to use the Exo chassis and front suspension then get new parts to finish the robbed Exo, but I'm to the point that I've pretty much used a large portion of the Exo to build this.
I'm going to get back at it here in a few. Cage will be done today.
Old 06-19-2012, 01:51 PM   #38
This is just badass!!! I cant wait to see how this turns out JIA or is is JIH??? Anyway this will be my next project if all works out, I have a untouched Wraith chassis waiting for it
Now get back to work
k9popo is offline   Reply With Quote
Old 06-19-2012, 02:26 PM   #39
Anxiously waiting for pics and updates!!
tcm glx is offline   Reply With Quote
Old 06-19-2012, 03:38 PM   #40
Started work and only had the chance to make three cuts before the Dremel battery died. Stuck it on charge for now, but here's a few more pics.
The rear shocks are just stuck in that location for now. I don't have the rear shocks I want to use on hand so I'll have to track some down.
Also swapped the front Exo shocks out for the stock Wraith front shocks. They're longer and the spring rate is better for this rig. Powerstrokes might be in the future - still debating. Everything is in flux so we'll see how it shakes out.
Anyway, more pics.
Still plenty of work to do.
For those wondering what I'm using to make cuts, Dremel makes a neat little tool that's intended for use with wood.
I've found it cuts plastic instead of melting it.
Works well.
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-wraith/388684-jias-ifs-ultra4-build.html
Posted By For Type Date
RC Elétrico - o fórum de automodelismo elétrico! • Tópico: - Axial Wraith This thread Refback 03-01-2013 02:33 PM
Axial Racing - Project Wrexo – Bender’s Latest Custom Build This thread Refback 02-18-2013 03:40 PM
JIA's IFS Ultra4 build - Similar Threads
Solid axle Ultra4 build JasonInAugusta Axial Wraith 79 07-08-2013 09:32 PM
DTP's KOH IFS Ultra4 DISTURBIN' tha PEACE Scale Videos! 7 12-20-2012 09:21 AM
JIA's IFS KOH Ultra4 Wraith Conversions JasonInAugusta Chassis and Suspension 77 11-10-2012 10:27 PM
IFS axial build red_zook General Scale Talk 6 04-28-2012 08:43 AM
Ultra4/KOH build of doom Ruff11 2.2 Scale Rigs 14 10-10-2011 08:11 PM
