10-03-2012, 05:27 PM | #421 | ||
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
| Re: JIA's IFS Ultra4 build Quote:
The side panels I'm sending will be from the RTR Wraith if that will help you get started. Everything else in the box will be clear. Quote: | ||
10-03-2012, 05:29 PM | #422 | |
I meant your front hubs are missing. The SA rig is badass too! | |
10-03-2012, 09:14 PM | #423 |
Quarry Creeper Join Date: Jan 2012 Location: Bloomington
| Re: JIA's IFS Ultra4 build |
10-03-2012, 09:47 PM | #424 |
10-04-2012, 12:38 PM | #425 |
10-06-2012, 08:52 PM | #426 |
Making firewalls for these Ultra4 rigs. Last edited by JasonInAugusta; 10-06-2012 at 09:31 PM. |
10-06-2012, 09:56 PM | #427 |
Quarry Creeper Join Date: Sep 2010 Location: t(._.t)
10-08-2012, 01:19 AM | #428 |
Video I shot of young_version drifting his IFS Wraith. 3300kV Pro4, RC4WD AX2, and a lot of throttle. from Jason Carter on Vimeo. |
10-08-2012, 09:07 AM | #429 |
Quarry Creeper Join Date: Dec 2009 Location: Honolulu
| Re: JIA's IFS Ultra4 build A "must-have"!!
10-08-2012, 09:36 AM | #430 |
I wanna be Dave Join Date: Sep 2009 Location: Eastcoast CANADA
10-08-2012, 08:54 PM | #431 |
Result from the drift session. This was the driver's side rear tire. |
10-09-2012, 01:36 AM | #432 |
Moved the small 3-cell Li-Po for the winch and lights. Young_Version came up with the idea of battery placement and we tag-teamed designing the mount. I still need to clean up some of the edges and prime/paint the mount, but I couldn't be happier with function and battery protection. Super simple, fits the rig perfect, and the battery is locked in place. Two screws secure everything. One holds the battery clamp to the main battery tray, the other passes through the chassis and bolts the main battery tray in place. Video showing how it works. from Jason Carter on Vimeo. |
10-09-2012, 03:56 AM | #433 |
Working on packaging for all the electronics. Castle Creations BEC Pro and Futaba RX are mounted on the rear firewall. Up front there's a load of electronics. Tekin RX8, Castle Creations BEC, Thunder Power 3-cell 850mAh Li-po, Hitec 7980TH, and Thunder Power 2-cell Li-po mounted under the hood. Pretty cramped with the Exo steering rack in the way. Now that placement is sorted, I get to focus on a ton of wiring. Two batteries, two BECs, four servos, four MadDogRC lights, 3Racing light kit, switches, and a winch controller. |
10-09-2012, 04:43 AM | #434 |
REST IN ALOHA CHIP Join Date: Nov 2005 Location: *
Wow, it seemed as if moving the battery opened so many doors as far as placement for everything else. Looks super clean and organized. Good job! |
10-11-2012, 05:19 AM | #435 |
No doubt
10-11-2012, 11:42 PM | #436 |
Pebble Pounder Join Date: Aug 2012 Location: Minneapolis
All I've got to say is you're a machine! I've literally spent hours going through this thread. So many ideas it makes my head hurt! I can't count how many times I said "no way!" in amazement. Thanks for taking the time to document this build. |
10-12-2012, 04:37 AM | #437 |
Thanks, man. Got RusT's rig wrapped up today. DTP came over and worked on wiring for his lights. I decided to tackle an idea that's been floating in my head since DTP came back with his RC4WD goodie bag from Oregon. I'm running a 4PKS and have a ton of equipment in the rig. Front and rear steering, five light bars, two BECs, the RX8, 3Racing light unit, C.L.A.W V2 winch, and the micro servo in Stig's head. With front and rear steer, throttle, and winch all four channels on the 4PKS were populated. And I was happy. Until I got to drive RC4WD's AX2 transmission. So, to clear up a channel to shift the transmission I decided to put RC4WD's wireless winch controller to use. Pics tell the story. The circuit board of the RC4WD handheld control unit. I soldered some wire to the two switches so I can make a 5PKS. Gutted the winch controller board, heat-shrinked it, and made an adapter to plug my C.L.A.W. into the RC4WD board at the white plug. The controller board is powered by a Castle Creations BEC set to 7.2V. That BEC is powered off the Thunder Power 850mAh 3-cell Li-Po. Then it was time to rip the 4PKS apart. Started wire routing through the radio. The RC4WD transmitter board is housed in the empty pocket inside the 4PKS. Wires exit with the factory 4PKS bundle. I'll pick up pushbutton microswitches tomorrow and mount/wire them in. The system works great and once I get the switches installed in the transmitter I won't have to fumble with carrying an additional unit to operate the winch. So there's a simple 5PKS. Enjoy. |
10-12-2012, 07:41 AM | #438 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
Good thinking on the remote - I have been toying with the same idea on the 4PL but for a better independant 4WS control. Although it never dawned on me to use the RC4WD winch controller. On a side note - How are you liking the Claw winch? Have you had a chanse to compair it to Quicksand in respect to speed and power? |
10-12-2012, 12:23 PM | #439 |
I wanna be Dave Join Date: Jun 2005 Location: On the G-Train!!!!!
10-12-2012, 01:48 PM | #440 | |
I had a QS on my old RCP Wreckluse. That was the strongest, most reliable winch I've seen for RC. The C.L.A.W. is all metal construction and performs well, but nothing like the QS. QS has faster line speed and more torque. Last edited by JasonInAugusta; 10-12-2012 at 09:22 PM. | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-wraith/388684-jias-ifs-ultra4-build.html | ||||
RC Elétrico - o fórum de automodelismo elétrico! • Tópico: - Axial Wraith | This thread | Refback | 03-01-2013 02:33 PM | |
Axial Racing - Project Wrexo – Bender’s Latest Custom Build | This thread | Refback | 02-18-2013 03:40 PM |
JIA's IFS Ultra4 build - Similar Threads | ||||
Solid axle Ultra4 build | JasonInAugusta | Axial Wraith | 79 | 07-08-2013 09:32 PM |
DTP's KOH IFS Ultra4 | DISTURBIN' tha PEACE | Scale Videos! | 7 | 12-20-2012 09:21 AM |
JIA's IFS KOH Ultra4 Wraith Conversions | JasonInAugusta | Chassis and Suspension | 77 | 11-10-2012 10:27 PM |
IFS axial build | red_zook | General Scale Talk | 6 | 04-28-2012 08:43 AM |
Ultra4/KOH build of doom | Ruff11 | 2.2 Scale Rigs | 14 | 10-10-2011 08:11 PM |
