Thread: JIA's IFS Ultra4 build
Old 06-19-2012, 03:59 PM   #41
Im Brandon
Brandon's Avatar
Default Re: JIA's IFS Wraith build
Good progress.
I'm still hoping you give the EXO narrow wheels a try with a pair of the big 2.2's. They fit pretty well and give you a much better width/offset to match the rear. Plus the wheel design matches the stock wraith wheels.
Brandon is offline   Reply With Quote
Old 06-19-2012, 04:05 PM   #42
06 Super National Champ
JasonInAugusta's Avatar
Still undecided on wheels/tire combo. Just something else that's in flux with the rest of the build.
*EDIT*
Here ya go, dammit.
But you already know what they look like.
Honestly, I liked the width with the Integy wheels, just never put the rears on because they're a PITA with those tiny screw that hold the hub/nut on.
Was debating VP wheels for it. Hopefully VP gets some Exo CVDs out soon.
JasonInAugusta is offline   Reply With Quote
Old 06-19-2012, 04:36 PM   #43
R.I.P. Chip
jason's Avatar
You're gonna be pissed when Axial has this rig on the shelves in a month.
jason is offline   Reply With Quote
Old 06-19-2012, 04:38 PM   #44
Would be my luck.
Old 06-19-2012, 05:34 PM   #45
lol, I think you got more than a month before it's on a shelf, but I wouldn't be surprised if it came out in a couple years. I think you are on to something. I've seen one like this before, but as more and more IFS builds are done, the more the demand for a factory truck like this will become.
Good job by the way!
lccguy is offline   Reply With Quote
Old 06-20-2012, 01:54 AM   #46
More progress. Simple, really.
Sharpie and Dremel are the tools I've been using. I used the hack saw pictured earlier to cut the chassis and that was it.
Finished getting the left side of the Exo cage grafted into the Wraith cage. Pinned the driver's side Wraith B pillar to the Exo cage.
Also cleaned up all of the areas where I cut "excess" off of the Exo cage.
Again, the shocks are not where they will be when done, so don't give me shit about shock angles on the rear.
Got this far, going to pin the passenger side Wraith B pillar and that'll be it for tonight. I went ahead and uploaded these pics because the internet here at the hotel isn't the greatest and takes a while.
Old 06-20-2012, 02:15 AM   #47
Ohh mean!! Didn't realize this was your build. Haha...been watch'n all your post on FB. Thats sum serious work you've done. Looks killah!!
Pau Hana is offline   Reply With Quote
Old 06-20-2012, 02:27 AM   #48
REST IN ALOHA CHIP
YoUnG_vErSiOn's Avatar
No one has done or thought of this yet, you sir are the first. keep em coming JIA!! Welcome back, and what a better way to roll out the red carpet than with this, the beginnings of a quite unique build.
WELCOME BACK *
YoUnG_vErSiOn is offline   Reply With Quote
Old 06-20-2012, 02:31 AM   #49
REST IN ALOHA CHIP
Ironman Wrexo!, cause you are like Tony Stark in a cave with primitive tools.
Old 06-20-2012, 04:11 AM   #50
We're up doing the house search thing so I messed around a bit more.
Stuck the Exo light bar on, along with DTP's old body panels. I left the rear loose, but this helps me see what I'll need to do when it comes time to panel it.
Not too sure of this light bar. One of the Chino units will likely go on. Less cabling and a cleaner look.
Old 06-20-2012, 05:20 AM   #51
DISTURBIN' tha PEACE's Avatar
Sick work Stark. Just sell it to me already, it has my name on it.
DISTURBIN' tha PEACE is offline   Reply With Quote
Old 06-20-2012, 09:13 AM   #52
Im Brandon
Brandon's Avatar
Originally Posted by JasonInAugusta View Post
Here ya go, dammit.
Perfect!!
The Axial CVD's are out, they held up well with 2.2's and a castle 3800 4 pole. They may not be as fancy as VP's when they come up but they are up to the task if you need something now.
TowerHobbies.com | AXIAX30415 AX30415 Axial Front Universal Joint Axle Set EXO (2)
Old 06-20-2012, 11:09 AM   #53
What I like most about this build is the fact that you used an Exo for the front end. It would be cool to put the independent rear on as well. I've seen people do this with traxxas slash/stampede 4x4 drive trains, but with the Axial stuff it's essentially "stock". Very cool.
ik632 is offline   Reply With Quote
Old 06-20-2012, 11:29 AM   #54
What would be the point of putting on the indy rear??? If he did that he might as well never have even cut it up
k9popo is offline   Reply With Quote
Old 06-20-2012, 12:01 PM   #55
You'd want the independent rear because they tend to handle better and are a little tougher. It's like building a very tall and top heavy Exo. Someone may do that purely because they like the way it looks. Not everything we do in the hobby makes a ton of sense from a "why did you hack up two perfectly good trucks to make a new one" point of view
But, the builds I saw the guys used front/rear independent suspension because they had the parts and the trucks were already hacked up. The solid rear is more scale looking, but the independent suspension from the traxxas is designed for racing and much more robust to jumps and bashing. I think the idea was to eliminate the issues they were having with breaking the Axial axles (there are a bunch of youtube videos showing people snapping the front axle on the Wraith when running on a stadium course). That was before the aluminum rear lockouts were also available. These builds were a few years ago when the Wraith first came out before the Exo was available.
The problem is when you use the Wraith for bashing or racing like a stadium truck, you find it's not intended for that. I agree that it's probably a waste to cut the Exo up to swap the front and rear, but some may like the larger more square look of the Wraith. I'm sure over time we may even see Exo's with Wraith rear axles strapped to them.
Old 06-20-2012, 12:30 PM   #56
That looks SOOOOO SICK!!!!! Turned out awesome!!!
Going Up! is offline   Reply With Quote
Old 06-20-2012, 08:21 PM   #57
if your looking for a better rim, I been using my 2.2 bio hazard wheels from rc4wd, most of their 2.2 have a good off set it clears the steering on the exo great job on the build, also the exo engine i been using one on my wraith and really cool seeing someone else doing it too!
Absurd is offline   Reply With Quote
Old 06-20-2012, 08:47 PM   #58
daaaaammmnn!
dieselfuel is offline   Reply With Quote
Old 06-20-2012, 08:54 PM   #59
WOOPOOW!!
Ah man its looking BA Keep the updates coming!
Colby is offline   Reply With Quote
Old 06-20-2012, 09:54 PM   #60
Thanks, guys.
I have a set of wheels in mind (RC4WD Predators) but they hit the Exo knuckles. Will have to see what I can do. Would like Walker Evans wheels on it.
Cage/tube work is done. The only thing left to do is finish the three tubes at the forward overhead portion of the cabin behind the light bar. I shortened the Exo piece to fit what's left of the Wraith cabin.
A pic from earlier in the thread of the area I'm talking about.
young_version gave me some shocks that are perfect for what I want to do on the rear.
No idea what they're from - maybe the Venom Creeper - but the length is right for what I'm doing.
I also picked up a RC4WD driver today. He will go under the knife later tonight. Should be pretty cool. Some say he naturally faces magnetic north, and all his legs are hydraulic.
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-wraith/388684-jias-ifs-ultra4-build.html
Posted By For Type Date
RC Elétrico - o fórum de automodelismo elétrico! • Tópico: - Axial Wraith This thread Refback 03-01-2013 02:33 PM
Axial Racing - Project Wrexo – Bender’s Latest Custom Build This thread Refback 02-18-2013 03:40 PM
JIA's IFS Ultra4 build - Similar Threads
Solid axle Ultra4 build JasonInAugusta Axial Wraith 79 07-08-2013 09:32 PM
DTP's KOH IFS Ultra4 DISTURBIN' tha PEACE Scale Videos! 7 12-20-2012 09:21 AM
JIA's IFS KOH Ultra4 Wraith Conversions JasonInAugusta Chassis and Suspension 77 11-10-2012 10:27 PM
IFS axial build red_zook General Scale Talk 6 04-28-2012 08:43 AM
Ultra4/KOH build of doom Ruff11 2.2 Scale Rigs 14 10-10-2011 08:11 PM
