03-20-2013, 05:11 PM | #741 |
I wanna be Dave Join Date: Jun 2005 Location: On the G-Train!!!!!
| Re: JIA's IFS Ultra4 build
Race Day accent pack..........You gonna use all of them? |
03-20-2013, 09:06 PM | #742 |
Pebble Pounder Join Date: Oct 2008 Location: mid state
Awesome build! im waiting on all my parts to come in to start my IFS build. sp im wondering how long does it take you to do a conversion now that you have several conversion done?
03-21-2013, 03:18 AM | #743 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
| Re: JIA's IFS Ultra4 build |
03-21-2013, 03:35 AM | #744 |
Rock Crawler Join Date: Apr 2012 Location: Chattanooga
JIA, you sir know how to make an awesome thread! Thanks for helping and inspiring those of us who want to go a little outside the box..... ;) keep up the great work ;)
03-21-2013, 10:11 AM | #745 |
I wanna be Dave Join Date: Sep 2005 Location: *
Un fawking real JIA!!! Simply amazing work!!! Sent from your house when you were gone to work |
03-25-2013, 05:03 AM | #746 | |
| Re: JIA's IFS Ultra4 build Quote:
But...I just put stuff together that other people make. I've been working late getting things ready for the upcoming G6 that's April 5th-7th. Should be done with this by then. | |
03-25-2013, 08:00 AM | #747 |
Rock Crawler Join Date: Sep 2008 Location: Nashua,NH
Sweet look with the new skins on. Oh an good luck at the G6.
03-27-2013, 06:02 AM | #748 |
03-29-2013, 03:00 AM | #749 |
Newbie Join Date: Nov 2012 Location: luxembourg
wow thats absolutely amazing. by far the most awesome rig i`ve ever seen in this forum |
04-01-2013, 06:53 AM | #750 |
Newbie Join Date: Mar 2013 Location: Australia
Hey I have just built myself one of these and I need some help. I built it with a brushless system and the standard clutch just doesn't cut it. I have been through your thread numerous times trying to find the clutch your using. Can you please tell me what clutch system your using? Any advice would be greatly appreciated Thankyou |
04-01-2013, 07:15 PM | #751 |
he is using the traxxas revo clutch system its a bolt on hop up i do believe.
04-02-2013, 01:23 AM | #752 |
04-04-2013, 01:18 PM | #753 |
to the people that are doing this ifs conversion. what epoxy/glue are people using to put the cages together with? i tried some 3m epoxy and it didnt hold? i pinned the cage together using rod and epoxy and after 24hrs for it to cure it just poped apart with minimal force? i do beleive jason is using so fancy stuff that he had? so whats everyone else using im thinking of giving jb weld a try? bob |
04-05-2013, 12:43 AM | #754 |
Pebble Pounder Join Date: Apr 2007 Location: Nowhere
How does it crawl compare to a wraith?
04-05-2013, 06:32 AM | #755 |
Rock Stacker Join Date: Mar 2013 Location: Newmarket
Bob on my roll cage I am using some Axial set screws. I threaded it in on one side and the other side I drilled out just smaller then the set screw. It was only just undersized, so i could push it together the first mm or two before it stopped. I then heated the slightly undersized side a bit and applied pressure until it popped together. I have beaten the crap out of it and so far so good. My next update on my build thread this weekend will include pictures if you need them. I only used pins to hold the one up right tube into the corner of the b pillar. Last edited by MotoSoul; 04-05-2013 at 06:35 AM. |
04-05-2013, 02:55 PM | #756 |
great idea moto. are you just eye balling the center of the tube?
04-05-2013, 03:20 PM | #757 |
I did just eye it up for when I drilled it out. It does take some practice to get it down though. I had to sand a little bit as mine didn't stay exactly centered on two of my holes. If I were to do it all again I would use thin metal pins to hold it together for mock up and then once everything is perfect I would drill it out larger to except the set screws. I thought about doing a small change to one of the cuts I did, but I literally could not pull the set screw joined tube apart without risking snapping something. Can't say it turned out bad as all my wraith roof skin holes lined back up in the end.
04-06-2013, 02:02 PM | #758 |
Small update: Got it up and running. An hour prior to the start of the Shaka Brah Classic II G6. The first stage of the G6 was a night stage. Got to the G6, unloaded, people checked out the rig, went through the drivers meeting, and we ran the 1.9 class. Course was 75 gates (two missing) and we had to run two laps for a total of 146 gates. Finished the 1.9 in two hours and thirty minutes or so. Grabbed the IFS and went out to do a lap to see how the rig would do on the course. Lost the left rear RC4WD drive flange wheel nut between gates 20 and 21. Spent about 20 minutes looking for it, gave up, installed a regular wheel nut and went on. Drove the rest of the course and crossed the start/finish line...only to find out Parker was keeping time! Then it was hammer time. Two laps, 146 gates in 46 minutes. Had so much fun I put in another lap. |
04-06-2013, 07:50 PM | #759 |
Quarry Creeper Join Date: Sep 2010 Location: t(._.t)
glad to hear it finished. always wanted to do a G6, but first i need a rig capable enough to be competative in it. |
04-06-2013, 10:20 PM | #760 |
What's crazy is that if you take out the 20 minutes spent looking for the last wheel nut I ran those gates in 26 minutes. Ran today's stage and had a servo mount screw loosen on the rear axle. Quick fix and back in action. Very happy with how it's performing. |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-wraith/388684-jias-ifs-ultra4-build.html | ||||
RC Elétrico - o fórum de automodelismo elétrico! • Tópico: - Axial Wraith | This thread | Refback | 03-01-2013 02:33 PM | |
Axial Racing - Project Wrexo – Bender’s Latest Custom Build | This thread | Refback | 02-18-2013 03:40 PM |
JIA's IFS Ultra4 build - Similar Threads | ||||
Solid axle Ultra4 build | JasonInAugusta | Axial Wraith | 79 | 07-08-2013 09:32 PM |
DTP's KOH IFS Ultra4 | DISTURBIN' tha PEACE | Scale Videos! | 7 | 12-20-2012 09:21 AM |
JIA's IFS KOH Ultra4 Wraith Conversions | JasonInAugusta | Chassis and Suspension | 77 | 11-10-2012 10:27 PM |
IFS axial build | red_zook | General Scale Talk | 6 | 04-28-2012 08:43 AM |
Ultra4/KOH build of doom | Ruff11 | 2.2 Scale Rigs | 14 | 10-10-2011 08:11 PM |
